#1 | Link | |
Dirac - BBC will rule future codecs
BBC's R&D is hard at work developing The Dirac Project
taken from their site: Quote:
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 Last edited by bond; 3rd May 2004 at 15:53. |
#2 | Link |
Hi
Many project say that they will be the best. None so far. Stop dreaming and use xvid or realvideo
Detritus Software |
#4 | Link | |
gone
#5 | Link |
! - User - !
Hey, come on. A company like the BBC has done preliminary resaerch and now offers it to the opensource community. I think this is great, eventhough they might be a bit late, taking into account the number of existing codecs.
Keep your tone warm and your sigs decent! |
#7 | Link | ||
also they say
#8 | Link |
Life looks better in HDTV
A friend of mine, from time to time, does some sub-contract work for the BBC and has spoken to a few people in their R&D department about this!
It all started when he asked one of these R&D guys what digital format the BBC was intending to use to store their massive library of 'live' broadcast material. Back in 2002 (when DVD and Mpeg2 was still taking off) he was told that the R&D department was working on something 'way better' than Mpeg2. "Was it Mpeg4"? my friend asked. "Absolutely not"! came back the reply. "What is it then"? It's a secret at the moment... but follow me and I'll show you some examples. Out came a shiny CD-R with approx 60 mins of broadcast quality audio and video on it... some soccer match I think it was... Anyway, apparently it was "the dogs bollocks"! Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear | |
#10 | Link |
It doesn't have an encoding app. Somebody needs to do program which utilises the encoding system provided by the BBC's library.
A/V moderator @ hydrogenaudio.org My weird old sh*t: http://www.nic.fi/~lhahne/ http://last.fm/user/Latexxx/ |
#11 | Link |
![]() Join Date: Oct 2001
Woah...this makes h264 seem fast.
I've thrown a bit of code together to go from AVS File to Dirac, and doing my first 50 frame encode as I type this. It's gonna take some time. I'll report back on quality and maybe screen shots if it encodes ok. Cheers, -Nic |
#12 | Link | |
! - User - !
![]() Ah, now come on Nic, you're not using your pocket calc again, are you?
#13 | Link |
@kilg0r3: I could have drawn the pictures quicker
Now im writing app to view the YUV files it decodes to. I think I did it at too higher a bitrate, 50 frames at 352x288 came out at 845,671 bytes. I'll let you know what it looks like soon ![]() -Nic |
#14 | Link |
For .yuv(single file with muliple Frames) you can use Avisynth with rawsource filter/plugin(http://www.avisynth.org/warpenterprises/).
AC-Chan(Robert Vincenz) |
#15 | Link |
It uses a .hdr and .yuv file for the yuv format. I've just written a little mfc app for viewing, which will suffice for now. But thanks for the tip.
Dirac definitely encodes ok. Slow but everythings working. Doing more tests at FD1 res. ill post pics ![]() Cheers -Nic ps Ok FD1 is too slow to even try. I had a shower and lunch and came back it had only done 2 frames. When I tried 352x288, the I Frames are fine but intermediate ones have weird artefacts on them. Also seeing I set the streaming preset the bitrate was extremely high. This codec needs a lot of work, but nice to see a opensource wavelet codec being developed... Last edited by Nic; 3rd May 2004 at 17:12. |
#16 | Link | |
I'm Shpongled
maybe suits your needs? |
#17 | Link |
Now that guliverkli made a DS splitter filter, and the source is at version 0.4.3, IMHO it's about time to have a Win32 binaries distributor with regular builds; anyone volunteering?!...
#18 | Link |
Agreed... a compile would be nice.
Cheers
#19 | Link |
Mr. Sandman
Here's my build (0.4.3 sources): http://ebola.gamersrevolt.it/dirac/dirac-0.4.3.rar
I did not check it coz i'm a bit busy but it should work.
#20 | Link |
Mr. Sandman
Sorry i couldnt edit the prev. message however i tested the build and it works.
| Thread Tools | |
| Display Modes | |
