27th April 2004, 22:49 | #1 | Link |
5.1 AC3 > 5.1 AAC under linux?
Hi -
Has anyone succeeded in converting 5.1 AC3 to 5.1 AAC under linux (using FAAC)? FFMPEG doesn't appear to support 5.1 AAC encoding, only stereo, and I haven't found anything that supports piping a 5.1 pcm stream to FAAC.
KpeX Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC Linux Audio/Video FAQ |
28th April 2004, 08:11 | #2 | Link |
hi, this is my first post here on the forums and i'm a noob :-)
I have to say that it was hard not to be able to post for 5 days but worth it - i learned a lot. but still i might have the answer to ur question though i ve never heard of AAC be4 and i dont know the exact definition for a 5.1 output (supposed 6 channels~ correct me if im wrong). after some minutes of reading man pages and an 'emerge faac' i came up with this: mkfifo audiodump.wav faac audiodump.wav test.aac & mplayer dvd://1 -vo null -vc null -ao pcm -channels 6 >/dev/null rm audiodump.wav and i got a 6 channels dump or so it seems as mplayer tells me its 6 channels and faac does a clean remapping of the channels. hope it helped Last edited by -NoXy-; 28th April 2004 at 08:14. |
29th April 2004, 19:58 | #3 | Link |
Thanks for the suggestion, I didn't have time to test until recently. Although the pipe appears to work, unfortunately, the resultant stream is pure static.
8th May 2004, 16:25 | #4 | Link |
That works for me. finally i am able to create 5.1ch AAC file. the problem is that faad2 has problem playing them for now. hopefully it will be fixed soon. this is what i used:
mkfifo audiodump.wav faac -q 75 --mpeg-vers 4 --obj-type Main audiodump.wav test.aac & mplayer dvd://1 -alang en -vo null -vc null -ao pcm -channels 6 >/dev/null rm audiodump.wav hope that helps you ! Regards Shemeta |
20th May 2004, 11:04 | #5 | Link | ||
Another method to directly transcode from 5.1 AC-3 to 5.1 MP4 on Linux might be the transcoder module in VLC, but I don't know if they handle 5.1 files correctly in the meantime. @KpeX: What is this stereo-only issue with ffmpeg, do they downmix the AC-3 output somewhere or only use Dolby Surround instead of Dolby Digital? Whatever the cause is, this might also mess up the result when using VLC for transcoding, because they use the ffmpeg library compiled with an external FAAC version, too (see their web forum). FAAC itself encodes all channels in an input file or bitstream, so it does not downmix or leave out any channels. The -I switch can be used if the channel mapping differs from standard WAV layout, but normally all AC-3 decoders already have them reordered that way at their output. And other Linux apps which might be able to handle 5.1 AC-3 to 5.1 MP4 transcoding are gmerlin and gstreamer, maybe Xine, too...
ZZee ya, Hans-Jürgen BLUEZZ BASTARDZZ on Myspace, YouTube and Last.fm INDIGO ROCKS on Myspace and Last.fm Last edited by hans-jürgen; 20th May 2004 at 11:18. |
20th May 2004, 15:18 | #6 | Link | |
hans-jürgen:
When I attempted to transcode to AAC using FFMPEG compiled with FAAC, the encoder defaulted to 2-channels (the AC3 was downmixed when decoded) even if I attempted to force the number of channels ( -ac 6 switch ). I will re-test the Mplayer-pipe method with the additional raw PCM switches, that sounds promising. Quote:
20th May 2004, 17:18 | #7 | Link |
Adding the additional FAAC switches resulted in a perfectly transcoded AAC stream. My successfull commandline(s):
$ mkfifo audiodump.pcm $ faac -q 100 -I 5,6 -P -R 48000 -C 6 -X audiodump.pcm -o audio.aac & mplayer blah.vob -aid 128 -vc dummy -vo null -ao pcm -nowaveheader -channels 6 Thanks to all, Edit: I have a doubt that the channel-mapping is correct using this command. Unfortunately I will not be able to look into this more at the moment. Edit2: See below for correct channel-mapping commandline (edited in here as well to avoid confusion)
KpeX Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC Linux Audio/Video FAQ Last edited by KpeX; 20th May 2004 at 19:09. |
20th May 2004, 18:47 | #8 | Link | ||
By the way, since I'm not a Linux user, I don't understand what mkfifo and mplayer are doing when using this method, but you can also feed the raw PCM bitstream directly to FAAC's stdin when using "-" instead of an input file name, like this: faac -q 75 -P -X -R 48000 -C 6 - -o test.mp4
ZZee ya, Hans-Jürgen BLUEZZ BASTARDZZ on Myspace, YouTube and Last.fm INDIGO ROCKS on Myspace and Last.fm Last edited by hans-jürgen; 20th May 2004 at 19:08. |
20th May 2004, 19:08 | #9 | Link | ||
$ mkfifo audiodump.pcm $ faac -q 100 -I 5,6 -P -R 48000 -C 6 -X audiodump.pcm -o audio.mp4 & mplayer blah.vob -aid 128 -vc dummy -vo null -ao pcm -nowaveheader -channels 6 The mkfifo command makes a named pipe called audiodump.pcm, which is also the filename mplayer dumps the audio to in this scenario. Although FAAC handles both kinds of pipes well, mplayer isn't as well suited to using stdout.
KpeX Audio FAQs: General | BeSweet | SVCD/MP2 | MP3 | Vorbis | AC3 | DTS | AAC Linux Audio/Video FAQ Last edited by KpeX; 20th May 2004 at 19:19. |
21st May 2004, 18:56 | #10 | Link | |||
http://forum.doom9.org/showthread.php?s=&threadid=74708 Quote:
By the way, there are also FAAC compiles for Linux and other *nix OS versions available on the web, e.g. on the Debian page of http://www.rarewares.org/, but also on BDP and others that you will find easily with http://rpmseek.com/. |
