Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 22nd April 2004, 10:45   #1  |  Link
Wensleydale
The big cheese
Wensleydale's Avatar
What is the lowest bitrate acceptable to YOU?
How low do you chaps go on a progressive main movie?
Just curious.
Wensleydale is offline   Reply With Quote
Old 22nd April 2004, 13:15   #2  |  Link
Kedirekin
Good question. I'm curious what other people are using myself.
In my experience, average bitrate of 3,500 is about the minimum for 24 fps material, down to about 3,000 if there are large black bars (2.35:1 AR).
For full screen 30 fps interlaced extras, 3,800 is rock bottom, and I'm a lot more comfortable above 4,000.
[This might explain why I like transcoders so much. Many DVDs start out with an average bitrate around 4,500; on those DVDs 3,500 corresponds to about 78% in a transcoder].
Kedirekin is offline   Reply With Quote
Old 22nd April 2004, 16:22   #3  |  Link
influenza
Dutch strain
influenza's Avatar
Well It all depends on the q factor you can get. Do a OPV on it and see for yourself. On a progressive main movie you can go as low as 2200 and still get a q of below 9.
What can I do to protect myself against the flu?
By far, the single best way to prevent the flu is for individuals, especially persons at high risk for serious complications from the flu, to get a flu shot each fall.
influenza is offline   Reply With Quote
Old 22nd April 2004, 16:37   #4  |  Link
Wensleydale
The big cheese
How do I check the q factor?
Old 22nd April 2004, 17:14   #5  |  Link
influenza
Dutch strain
influenza's Avatar
You let cce create a vaf file (of the opv) and then select multipass and click on the button bit allocation. Fill in min and max and play with the bitrates. Q is showed in lower right of the screen.
Old 22nd April 2004, 18:02   #6  |  Link
Master Yoda
Master Yoda's Avatar
Me, i try not to go below about 3800 on on the main movie.But it also depends on the original bitrate.With extras i try not to go below 2000 if the original avg was about 3500 - 4000, i the extras original avg was about 5000 then i try to stay around 3000 - 3500.
Although on animamted stuff you can get away with a lower avg i think.Akira i used a avg of about 3300 - 3400.
I think it really depends person by person.If its a movie with alot of high motion in i may decide i want to try and keep the avg about 4200.If theres hardly any fast motion i may decide to go down to 3500.
UK PAL User.......
Master Yoda is offline   Reply With Quote
Old 22nd April 2004, 18:09   #7  |  Link
influenza
Dutch strain
influenza's Avatar
well obviously you cannot always choose when doing a full dvd backup (including all extras an menus). 4200 is quite high as most original dvds have an average bitrate of 5000 or so.
most movies will look outstanding at bitrates around 3000 and even below. Progressive stuff that is. Interlaced material requires much more bitrate.
Old 22nd April 2004, 21:23   #8  |  Link
D3s7
ScenAid
D3s7's Avatar
I personally have done main movies as low as 1900 and w/ 4/5 passes they look good
sometimes you don't have an option if you keep everything
ScenAid
May just replace the dog as man's best friend
http://www.scenaid.com
D3s7 is offline   Reply With Quote
Old 23rd April 2004, 16:52   #9  |  Link
Trahald
Wewkiee
Trahald's Avatar
my *normal* minimum is 2500 for movie (*16:9 or 4:3) and 2200 for (4:3) extras (at 1/2 d1 and interlaced)
my acceptable minimums are 1900 for movie and 1800 for extras.
unfortunately most of my backups need way more than 78% shrinkage
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 23rd April 2004, 18:20   #10  |  Link
DDogg
Retired, but still around
DDogg's Avatar
@influenza, sometime if you have time, could you do a 1% sample, derive the BR, and see if it agrees with your method above? I believe it should, but it would be good to have an independent verification. To save time there is a derived BR spreadsheet attached in the second post of this work thread.
/Add: @All - I don't understand when folks mention certain average bitrates in relationship to quality. ABR has nothing to do with quality, which is sorta what influenza said above. The source complexity solely dictates the BR needed for a certain quality, not the other way around and it is uniquely different for each source.
DDogg is offline   Reply With Quote
Old 23rd April 2004, 23:25   #11  |  Link
influenza
Dutch strain
influenza's Avatar
ddogg will do it if I have time this weekend. Ad otherwise you need to be a bit patient as I will be going on vacation for two weeks
Old 23rd April 2004, 23:44   #12  |  Link
DDogg
DDogg's Avatar
Thanks, it should take you less than 5 minutes to do everything The vacation sounds fun, anyplace special, or just hanging out?
Old 24th April 2004, 12:54   #13  |  Link
Kedirekin
@DDogg,
I suspect you do understand why people talk about their minimal exceptable ABR. It's human nature to make observations and then generalize based on those observations. Also, I don't agree with your statement that ABR has no relation to quality, but that's an age-old argument that I really don't want to wake.
Personally I'm surprised at the range of minimal acceptable ABRs that people are quoting. Heck, I've had SVCDs that I couldn't stand at an ABR of 2200.
Old 24th April 2004, 13:27   #14  |  Link
influenza
Dutch strain
influenza's Avatar
Of course there's a relationship between abr and quality. But that's not what ddogg meant (at least that's what I think ). I think what he means is that you cannot say that a certain abr will result in a certain quality.
You cannot say this bitrate will always result in that quality. Just like your statement that some svcd look bad at a BR of 2200. Some others will look excellent at that bitrate.
The question asked here is quite irrelevant though. What is the lowest bitrate acceptable to you is of course very subjective .
Old 24th April 2004, 19:36   #15  |  Link
DDogg
DDogg's Avatar
Originally posted by Kedirekin -
Also, I don't agree with your statement that ABR has no relation to quality, ...
A better phasing might have been to the effect that bitrate is only a peripheral byproduct. Bitrate is the container that 'holds' our cargo. Like any container of anything, it is secondary to what is in it. Its shape is dictated by the shape of the contents. Not the other way around. In our case, the "shape" is the compressibility of a given source. Erm, I think my wording was betraying my frustration with the subject, sorry :-o
... but that's an age-old argument that I really don't want to wake.
Why not? Its fun to talk about, especially with folks like you and 'flu'. Anyway, I don't think it is an area of argument that compression characteristics can be quantified in some manner. Compression is the core fundamental of our hobby. Better understanding its base fundamentals are important to enjoying the hobby. At least they are for me. Also, when you can quantify compression characteristics, you can also quantify the effects of various matrices, filters, resolution tweaks, DC precision, and a host of a zillion other things that were members in good standing of the "Subjective Brigade" :-)
Originally posted by influenza -
The question asked here is quite irrelevant though. What is the lowest bitrate acceptable to you is of course very subjective".
Yep, sure, but how subjective should it be? While I completely agree that what quality somebody is willing to personally accept is personally subjective, it does not have to be a personal mystery. What somebody is willing to accept can be generally quantified in advance. For me, it is a bitrate that can hold a Q of less than 28. That more than fits my display vehicle, which is a 12 year old 32" JVC and helps me to quantify my own subjectivity.
<chuckle> Trying my best to come back on topic, here are two radically different examples I recently ran into which speak to the original question:
1> "Good Fences" - 2 hour, 4:3, true interlaced, plus interlaced interviews and trailers. Spending 3 minutes doing a pre-encode sample showed it required a whopping 4058 Kbps to hold a Q28 on the main movie. The extras were about the same. To get all that on a DVD, and at a personal acceptable quality level, required 1/2D1 resolution for both extras and main. Knowing this up front saved me one heck of a lot aggravation and wasted time. Yeah, kind of an ugly solution, but it looked surprisingly acceptable, although slightly soft. There was no other way to do it, and still be happy with the outcome.
2> "Spirited Away" - 2 hour,16:9, Anim, Progressive. Only requires 1873 Kbps to hold a Q28. Didn't need to spend any more time thinking about it. I knew the space available would allow terrific quality.
So, my reply to the original poster's question is that every source requires a unique bitrate that can provide you with a close approximate to your 'personal level of acceptable quality', or better it. There are several techniques to divine that particular ABR. They are readily available to you, two of which are mentioned in the replies to this post.
Old 24th April 2004, 19:46   #16  |  Link
influenza
Dutch strain
influenza's Avatar
Why me
Old 25th April 2004, 00:38   #17  |  Link
Trahald
Wewkiee
Trahald's Avatar
Why me
i think he mistakenly thinks you are knowledgeable. (j/k)
anyways.. for me, i wouldnt go 1/2 d1 on my main (extras i have no problem with going 1/2D1). but i do have the option of reencoding the audio(s) smaller.. or even applying some light noise reduction(but not too much because im actually a noise 'fan' ). but for the most part i just live with what bitrate the movie gives me. i was very much into q based decisioning with svcd (tylo's d2sroba) since adding a disk was an easy option. d2sroba being automated didnt hurt either. but ive gotten away with it a bit with dvd and going with bitrate decisioning. for the most part i get away with it (since most movies give you a bitrate that is consistant with an acceptable q)
also, dvds tend to be alot cleaner than they used to be. although some movies are destined to need lots of bitrate to maintain an acceptable Q because there is alot of action and/or purposefully grainy i.e. saving private ryan or band of brothers.
for the most part.. this would benefit my extras since usually i rape them of bitrate for the main movie when maybe the main did not need as much bitrate as i gave it. i'll track my next few projects and see what happens.
Old 25th April 2004, 01:05   #18  |  Link
Matthew
jdgljlfljg
As stated above each source is different, I'm more interested in the q factor values in CCE's advanced settings.
I like these values to be very low, when they get up to around 5 on a consistent basis then I get pretty annoyed.
This is why I never keep extras =)
Matthew is offline   Reply With Quote
Old 25th April 2004, 16:46   #19  |  Link
DDogg
DDogg's Avatar
@Trahald, you may soon feel right back at home
@Matthew, getting average quantization under 5 is what I shoot for also. Q28 seems to get me there, but I have always been fuzzy on the exact relationship between OPV's unique "Q Value" and the actual average quantization. I guess it would have to be a direct correlation because of the way OPV works, but I never spent the time to directly verify it.
Old 1st May 2004, 13:29   #20  |  Link
auenf
avatar doesn't support IE
auenf's Avatar
2mbit bitrate can be fine, but it all depends on how much action there is, and how frequent the action is.
use the Q value as a rough indication of how well the video is getting compressed (over 9 means you will most probably have macroblocks).
FWI, i did LOTR1 extended at 2.1mbit
Enf...
Sometimes I get halfway through a paragraph explaining something, then I just completely forget what I was thinking about
which is when you will notice that the paragraph just ends rather abruptly...
auenf is offline   Reply With Quote
