Old 6th April 2004, 11:51   #1  |  Link
weirdaznboi923
upmixing mono to 5.1
i know thats a really stupid question, answer is problably no, but i was just wondering because i want to upmix my home videos, but the camcorder records in mono (from 2000, sony CCD-trv37).
weirdaznboi923 is offline   Reply With Quote
Old 6th April 2004, 16:51   #2  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Why you wanna up-mix it...
Coz of DVD compliance maybe ???
AFAIK, DVD standard supports also mono (1ch) AC3 !!!
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 6th April 2004, 17:57   #3  |  Link
Tuning
I'm back! :D
Tuning's Avatar
I think it is possible to insert some reverberation in mono files using sox and encode to ac3 using BeSweet.
Check sox documentation for reverbration...
Tuning is offline   Reply With Quote
Old 6th April 2004, 21:20   #4  |  Link
Asmodeus
juzer
Asmodeus's Avatar
If you have mono PCM wave just create besweet mux file (some_file_name.mux ; this is plain text with .mux extension) like below:
mono.wav
mono.wav
mono.wav
mono.wav
mono.wav
mono.wav
If this won't work , create 6 separate mono files (mono1.wav, mono2.wav, .... till mono6).
Then just open this type of file in besweet like regular file and encode to ac3.
But MPEG standard allow mono ac3 (and AFAIR mp2)tracks on DVD.
Asmodeus is offline   Reply With Quote
Old 7th April 2004, 18:08   #5  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Re: CATT FIReVerb
Originally posted by kempfand
You can upmix to true stereo or 5.0, if you use convolution with suitable filters (impulse responese). But it takes quite some time and you need to know some details. To get an idea on how it works, see The FIReverb Suite™ - audio demonstration
Cheers,
Andreas
Thought this would only work proper with stereo sources as input...
Bye
