Old 3rd April 2004, 16:05   #1  |  Link
itcth
How to print contents from "info()" to text file
I can check file information using "info()" .It show only on left side of screen.Please help me,how to print these information to a text file.
... I try "chr.dll" in conjunction with "Write()" but no luck.
Thnaks,
itcth is offline   Reply With Quote
Old 3rd April 2004, 20:09   #2  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Not possible - sorry.
Many of the properties are available as clip properties, though.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 4th April 2004, 03:23   #3  |  Link
stickboy
AviSynth Enthusiast
This should get you started:
function InfoToFile(clip c, string filename)
    endl = Chr(10)
    colorspaceStr = "Colorspace: "
    \               + (c.IsYUY2()
    \                  ? "YUY2"
    \                  : (c.IsYV12()
    \                     ? "YV12"
    \                     : (c.isRGB32()
    \                        ? "RGB32"
    \                        : (c.IsRGB24()
    \                           ? "RGB24"
    \                           : "Unknown"))))
    \               + endl
    frameSizeStr = "Frame size: "
    \              + String(c.Width()) + "x" + String(c.Height())
    \              + endl
    fpsStr = "FPS: " + String(c.FrameRate()) + endl
    fieldBasedStr = (c.IsFieldBased()
    \                ? "field-based (separated)"
    \                : "frame-based")
    \               + endl
    audioStr = "Audio: "
    \          + ((c.AudioRate() == 0)
    \             ? "none"
    \             : (String(c.AudioRate()) + " Hz, "
    \                + String(c.AudioBits()) + "-bit, "
    \                + String(c.AudioChannels()) + " channels"))
    \          + endl
    return c.WriteFileStart(filename, "colorspaceStr",
    \                       "frameSizeStr", "fpsStr",
    \                       "fieldBasedStr", "audioStr")
(There's a bug in AudioBits(); right now it returns bytes per channel, not bits. The script above does not correct for it, since I assume it will be fixed real soon. )
Is it useful to have this information in a text file?
stickboy is offline   Reply With Quote
Old 4th April 2004, 04:44   #4  |  Link
itcth
@ stickboy
Thanks a lot.I will try it now.
Old 4th April 2004, 05:06   #5  |  Link
itcth
@stickboy
With little modification.Your script works great.
Thank again.
Old 4th April 2004, 09:17   #6  |  Link
sh0dan
sh0dan's Avatar
AudioBits fixed.
I also added isAudioFloat and isAudioInt to the next version.
Old 4th April 2004, 17:41   #7  |  Link
itcth
@stickboy
...I use these information from info() to feed information to mencoder to encode to VCD.Mencoder has no ability to find out what frame rate,frame size.Therefore,every time i have to type commandline to introduce frame rate and others infomatiomn to mencoder.With assistant of your script ,i wrote another commandline to read infomation from text file and feed to mencoder.
...Apologize me for my English.It took me long way just to explain a simple need.If in Thai i bet only 2 sentences.
Regards,
