#1 | Link |
ADDChapter: 1.2.0.2 is OUT
I can't find a thread dedicated to this amazing little tool ADDChapter ... A while back I asked 2COOL for a 2COOL Guide to help me add a blank chapter to the end of a movie to which he out did himself again (Thanks 2COOL). The reason is simple. Every program we use from Rippers to Strippers to Compression software removes P-UPs like they are the worst thing to ever plague mankind. It makes sense because we don't want Hollywood telling us when we can or cannot use the NEXT button on our DVD remote... am I right...? you know I'm right !
![]() There is some fallout from this though. I find that about half the movies from Hollywood have a little 00'00'00'15 chapter at the end of the main title. When the credits of a movie come along and you click next you jump to this little blank screen for 15/30ths of a second and then to the menu(assuming you have already cleaned out the FBI Warnings and Logos that sometimes come after the movie). This is a good thing but as I said only half at best work this way and when this little chapter is not there navigation problems can arise. OK, you say, what if that tiny chapter is not there? Well, when you click NEXT on your DVD remote, you jump to the NEXT TITLE not the menu, that's what happens. Unfortunately the next Title might be previews that you eliminated by deleting the Previews button on your DVD Menu with MenuEdit or DVDReMake and compressed to Still PICS with DVDSHRINK. You thought those previews were GONE GONE GONE... but when the movie is over you pressed NEXT and got a "NO SOUND" chopped up version of the preview anyway.... Boy are you pissed now...! In comes ADDChapter to save the day...! This tool, that works in microseconds can add that little 00'00'00'15 chapter to your movie. That way when you get to the credits and press NEXT you go to the tiny blank chapter for 15/30ths of a second and then poof back to the menu... If you have ever done this add chapter routine manually you know it is a nightmare of time and effort to make it happen. Give ADDChapter a spin. It turns out Mr. jsoto is producing some great tools.
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker Last edited by geffroman; 20th December 2004 at 02:50. |
#2 | Link | |
PGC Navigator in Training
Re: ADDChapter: Tool to add chapters to any Title
Alot of progress have been acheived with new tools now since a year ago and to me, that's very EXCOOLENT! Thanks to jsoto and others for their concern and contributions for the DVD backup community!
2COOL Last edited by 2COOL; 31st March 2004 at 09:52. |
#3 | Link | |
Dimad (http://www.dimadsoft.com - home of MenuEdit & DvdReMake). Q Can machine think? A Machine should not think. Machine must run. |
#4 | Link |
I have gone back to the problem I had the other day and tested the heck out of it with several DVDs. There seems to be a minor issue that is still causing me to mock strip to get normal functionality in all scenarios.
I am testing on multi episode DVDs both from Homicide Season Four and CSI Season Three. I add chapter to each episode by selecting Auto Select or Manual (have done it both ways to be sure). I have tried it with "Append to Last VOB" & "One Cell per VTS" on and off. In all cases I end up with an added working chapter on each episode. If I burn to disc it plays and advances through all chapters in my Sony and my Apex. Here is the gotcha... In IFOEdit I can advance through all original chapters with the chapter advance button. On the last original chapter the button grays out and cannot be advanced to the new added chapter. However, I can use the chapter pull down and select the NEW added chapter and IFOEdit does advance. If I mock strip the last chapter does NOT gray out the advance button in IFOEdit and can be advanced through to the end. I should add that the data that has this symptom is fully recognized by DVDReMake which I believe checks VOB and IFO information against one another. However, if I run an EXPORT from DVDReMake of the affected data without doing a mock strip first the symptom is the same. IfoEdit will not advance to the added chapter with the chapter advance button but the chapter pull down can be used to advance to the new chapter. This is also where the chapter time changes from 00'00'00'12 to 00'00'00'15 as I mentioned the other day. If I run a mock strip now it will work fine and I get 00'00'00'15 added chapter in the end. This affected data also opens and seems to functions in DVDShrink though I did not run it to completion and test that data.. The good news is that I run ADDChapter on a standard movie with one PGC in the title set (Something's Gotta Give) and everything is perfect - NO ISSUE! My question is one of total compliance. What is different about this new added chapter that could cause this? And where will it cause me a problem? It is a subtle issue but odd and I just thought I should share what I am seeing.
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker Last edited by geffroman; 31st March 2004 at 19:04. |
#5 | Link | |
2COOL |
#6 | Link | |
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker |
#7 | Link |
Just a Member
Hi all,
Sorry for the delay in answering, but I was traveling during a couple of days and didn't be on-line. PUOPs can be in IFOs (Menu and/or Titles), which are removed by AddChapter, but also can be in VOBs which are not. I can add a check to do it, but it will take some time to be processed, so a progress bar must be included.... Well, before that I have to finish the new version... (AddChapter now allows to insert custom stills). jsoto - |
#8 | Link |
Just a Member
Well, I only did a few tests (it is too late), so take it with care..., and please help me to test it.
EDIT: LINK DELETED. New link in a post below. BTW, I think there is something more to do in the case of custom still insertion. If you do a mock strip, IFOEdit deletes the still time.... May be I have to change playback duration in VOB Cell or at least in IFOs. Does anybody know which things I have to modify additionaly? jsoto Last edited by jsoto; 6th April 2004 at 02:12. |
#9 | Link | |
NEW INFO: Did more testing on Multi PGC. As you know I have been doing a mock strip on Multi PGC to solve advance button being greyed out in IFOEdit. I thought that was all. After running finished back ups I find strange behavior in DVD Player. 6 disc set CSI...
Update: Success... I stripped added chapters from Disc 1. I ran ADDChapter again. This time I made sure "Use One Cell per VTS" was OFF. I did have to run a mock strip but when it was done it played perfectly in DVD Player. So, Multiple PGCs do NOT like added chapters to share a single VOB ID. Looking forward to info on mock stripping issue for multi PGCs. UPDATE - 12APR04: I retested CSI Season 3 Disc 2 with latest ADDChapter 1.1.0.3 with success. There are two multi PGC Title Sets. Both added chapter successfully and functioned perfectly WITHOUT mock stripping in IFOEdit, WinDVD & DVD Players (Sony & Apex). Great work jsoto!
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker Last edited by geffroman; 13th April 2004 at 00:57. |
#10 | Link |
Just a Member
Hi all,
Found a bug in AddChapter, fixed in 1.1.0.2 - program map entry didn't follow word boundary rules (one byte per program, pad to word boundary with zero) BTW, I don't believe this bug was the cause of Multi-PGC problems. Same links: AddChapter_exe.zip AddChapter_src.zip jsoto |
#11 | Link |
Just a Member
Hi all,
Found a couple of bugs in AddChapter 1.1.0.2, introduced in v1.1.0.0. Fixed in 1.1.0.3 - VTS_VOBU_ADMAP table filled with wrong sectors for the new cells, except for the first one - VTS_VOBU_ADMAP wrong lastbyte if "use only one blank" was checked. Same links and the new ones: AddChapter_exe.zip AddChapter_src.zip Thanks to geffroman for point them out. jsoto Last edited by jsoto; 12th April 2004 at 18:55. |
#12 | Link |
Will try several other multi PGCs today but looks excellent so far. Great work jsoto!
#15 | Link | |
#16 | Link |
Just a Member
AddChapter 1.1.0.4
Changelog
Vers 1.1.0.4 (22-05-2004) Added: Ability to create different resolution and AR blank cells. IMO, its really a bug. DAR, format and resolution of video cannot be changed in the same VTS. So, the blank cell should have the same attributes. Please note AddChapter will not check the custom cell attributes. www.posunplugged.com/jsoto www.iespana.es/jsoto jsoto EDIT: I've also modified the tool BlankVob to include the new set of blank cells. Last edited by jsoto; 23rd May 2004 at 23:56. |
#17 | Link |
I have been having a problem with ADDChapter on some DVDs.
Sometimes the last original chapter will not forward to the new chapter and the player just sits there and hangs... I can hit the NEXT button and things move on as they should. This occur on Sony players as they are the pickiest about sticking to standards. But it does not happen on other players like Apex that seem to push on even if data is not perfect. I recently had this problem with Smallville Season 3...
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker Last edited by geffroman; 29th December 2004 at 01:08. |
#18 | Link |
Just a Member
Yes.... Sony, I know, I saw the same problem in VobBlanker, Sony players need the discontinuity bit in category cell byte.
IŽll fix it. jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
#19 | Link |
Junior Slacker
My Sony drives me crazy. It is practically a standards checker. It was sensitive to all the subtle bugs in early DVD-RB too. I hear Denon is quite good with inconsistencies and deinterlacing perfectly under most circumstances, including bad authoring.
#20 | Link |
The good thing about Sony is that it does help sort out bugs and helps me get things RIGHT... This way I know my discs will work no matter what maching I use in any room in the house...
| Thread Tools | |
| Display Modes | |
