Thread Tools Display Modes
Old 24th March 2004, 09:42   #1  |  Link
redcheek
Nothing......
redcheek's Avatar
Easy RealMedia ProducerV1.94
Homepage: http://redcheek.net/erm
http://ermp.swtmedia.com
http://redcheek.net/erm/ermp_full.zip
http://rick.crazyasp.com
http://rick.crazyasp.com/ermp_full.zip
Easy RealMedia Producer is a software to generate RM/RMVB files
in batches,with a simple and very easy-to-use interface, and
customizable settings, Easy RealMedia Producer is perfect for
either novice or advanced content creators.
It uses the latest RealVideo10 codec.
Unlike other Real compressors,ERMP utilizes Real's core for
the encoding,instead of calling Helix Producer Plus by a command
line.
Feature:
more filter and settings than Helix Real Producer
customizable settings for every session.
batch produce
can shutdown computer when done
setting film end time
video color/brightness adjust
temp file locate at the same adresse as destion
encodage: CBR/VBR ehq -Mode audio/Video:
VIDEO OUTPUT: Realmedia (RV8/RV9/RV10)
AUDIO OUTPUT: stereo music RA8, Surround audio, 5.1 multicanal
Realaudio10, Realaudio lossless audio, Vorbis,HE-RAAC
AVISynth scripting support,support for avs directly
Easy-to-use interface, Drag and Drop supported.
Session Process Priority Adjustable
TrayIcon Supported,can minimize to system tray
Easy RealMedia Editor Inside
Batch edit process
Split a RM to pieces
Edit Property of RM file, just as Title, Author, Copyright,
Keyword, etc...
Merge, Join Real Media files to one file
1) is able to merge two files with different bitrate settings
2) knows how how to handle the new 4cc codes raac and racp
Filtres
Avisynth2.54
vobsub2.33&unrar.dll
ogg audio decoder
realmedia splitter
AC3Filter
http://redcheek.net/erm/erm.rar
http://rick.crazyasp.com/erm.rar
* New rate control
* Custom inloop filtering
* Real Audio 10 (HE-AAC, AAC) and 8 (cook, spiro)
* CBR, VBR and Constant Quality
* Read through AVISynth (VFW, DirectShow)
* EHQ with 1st-pass speed fix
* Custom B-Frames
Changelog :
2006-02-24 v1.94
*tray icon lost
*UI adjust
*Real11 Codecs
2005-11-25 v1.93
+AVS script add macro support
{SOURCEPATH} input file fullpath eg: c:\work\myvideo.avi
{SOURCEDIR} input file's path(path only,no filename) eg: c:\work\ ,(endwith \ )
{SOURCETITLE} input file's title(no path,no ext), eg: myvideo
{SOURCEEXT} input file'ext eg: avi
*pause function implement under win9x
+editor, filelistbox add tooltip
*other bugfixs
2005-8-30 v1.92
+add support for pause&continue.
*other misc update.
2005.8.21 producer 1.91,editor 1.72
some misc adjust for new realcodecs.
fixed editor setting bug[when set end time to a negative value].
2005.8.13 producer 1.9,editor 1.71
1.*update realcodecs [11Beta2].
2.*fixed two editor's bugs.
3.+add view log and clear log handle [global settings dlg].
4.*changed some ui control's tab order。
5.*fixed settings bug [LowBitrateBoost and rcBestPSNRMode].
6.+add session status support.
after encode finished,the tasklist will not be deleted, only have their status's changed.
four statuses: normal [normal color], pasued [color cyan],
finished [color green], error [color red].
only task with normal status will be encoded.
----try right click the list box.
7.+added rma commandline tool.
2005.5.23 producer 1.86,editor 1.7
1.*update realcodecs。
2.*fixed one editor's bug。
2004.12.15 producer 1.84
1.update erv4[1206].
2.fixed job file dump.
2004.11.03 producer 1.83
1.update erv4.
2004.10.20 producer 1.82
1.*adjusted auto shutdown monitor after [n] minutes.
2.*fixed bug with atrc audio codecs[maped to new codecs]
3.+add he-aac 32k,44k audio codecs
4.*fixed he-aac audio codecs
2004.7.20 producer 1.81
2.*adjusted avs script setting.
editor: fixed infomation.
2004.7.17 producer 1.8
1.+auto shutdown monitor after [n] minutes.
2.+save&load tasklist .
3.+support mkv output .
4.+now can change Priority while encoding.
5.*adjusted avs script setting.
6.add bitrate calculator.
*other fixes[ehq,1passfile,...]
editor: add file's bitrate infomation.
2004.7.11 producer 1.75
1.+can auto shutdown monitor .
2.+can select producerSDK's path .
3.+Separable 2-pass encoding .
2004.4.27 producer 1.62
1.*handled filename with special charator.
2.add some settings to RealVideo 10/9 codecproperties setting UI .
3.adjusted avs script setting.
4.*updated the chinese document.
*other fixes
2004.4.22 producer 1.61
1.*fixed a bug in video preview.improved the preview image's definition
2.+support RealVideo 10 'Elysian' features.
Curve Compression 2-pass rate control.
Inloop filter.
B frame .
3.+add english-only exe-file and chinese-only exe-file.
4.+add english document of rv10codecproperties.
2004.4.21 producer 1.6
1.+add rv10/9 codecProperties setting UI.
2.+add percent info text to system style's progress bar.
3.*update codec to real10core[release version].
2004.4.1 producer 1.56
1.+add input video preview to the manual crop dialog.
2.+set a special output filename.
3.*fixed a bug when set a special output path.
2004.3.31 producer 1.55
1.*Fixed: set title as filename(1.53,1.54).
2.*fixed: now video preview is valid for win98.
2004.3.30
1.*Fixed: memory leak in video preview(v1.52,1.53).temporarily droped video preview support for win98.
2.*fixed: disable video preview while encoding,and then press stop button would make a deadlock.
3.update encodercore to beta3.
2004.3.29 producer 1.53,Editor 1.33
1.*Fixed:can't leave title empty.
2.+visual adjust of cropping setting.
3.+add Exit to the context menu of TrayIcon.
4.*adjusted video color/brightness filter and other filter's order.
5.+Editor: support edit allow record,allow download, perfectplay
6.*other misc update.
2004.3.25 producer 1.52,editor 1.32
1.*Fix Video Preview bug in win98 (need dx5 or later)
2.*adjusted the english language resource and corrected the Traditional Chinese language resource.
2004.3.23 producer 1.51,editor 1.31
1.*Fix Bug in Reading Old Setting File
2.+Add Priority Adjust Support,Session Process Priority Adjustable
3.+Add TrayIcon Supported,can minimize to system tray
2004.3.22 producer 1.5,editor 1.3
1.+add Traditional Chinese language resource.support[simple chinese,Traditional Chinese,English]interface.auto select base on your system's
2.*Fixed: change style must restart program,or it will cause some unexcepted errors.
3.*Fixed:stop & restart encode sometimes cause a error.
4.+add support for allways on top feature.
5.+rename main exe's name to Easy RealMedia Editor.exe,and it will auto startup to Editor interface.
6.*editor can merge files with different BitRate.
7.+after enabled video preview,you can enable/disable it while encoding.
8.+add support for commandline call[see document about commandline]
9.+add "*.rpjf,*.xml" to the addfile filter,file with this extend name will be considered as RealProducer JobFile. and the settings in the ERMP is invalid except enable video preview while encoding.
10.+added:AVISynth scripting support,support for avs directly
11.+added: video color/brightness adjust
13.add FAQ to chinese document.
14.*full_version update
a.setup support [simple chinese,Traditional Chinese,English].
b.update VobSub filter to V2.33,add unrar.dll.
c.add msvcr70.dll for ogg decoder.
d.add AviSynth 2.5.4
e.update codec to real10beta2.[2004.2.27]
*other fixes
2004.2.13 producer1.42
1.+add support for ra10plus(HE-RAAC) audio code.
2004.2.11 producer1.41,editor 1.21
1.-drop support of old video code(RealVideo G2 With SVT).
2.*setting items can auto disabled when useless.
4.+add realmediasplitter_20040125,add "*.rm,*.rmvb" to the addfile filter.
this splitter enable you re-encode rm/rmvb files.
Editor
1.fixed:the setting button disabled when select one item.
2004.2.9 producer1.4,editor 1.2
1.+auto save task list, at auto restore at startup.
2.+add ablility to view video while encoding.
Editor
1.+add ability to set endtime as a offset value to the film's endtime.(just special a negative time)
2.+add chinese document of Editor.
2004.1.20 ProducerV1.32,EditorV1.12
1.+add english language resource. Support both chinese and english interface,auto select base on your system's
2.*file add duplicable
2004.1.17 ProducerV1.31,EditorV1.11
*Fix a bug in win98:once run & exit the program cause the system imagelist lost.
2004.1.16 Easy RealMedia Producer V1.3,Easy RealMedia Editor V1.1
1.*Fix Bug in Audio[+Delay/-Advance].
2.+add header columm to the task list box, and display some usefull infomation.
3.+list item can be reorder by mouse drag.
4.+the task list box support file drag in.
4.+auto remember the settings-save dir and last setting filename .
5.+auto remember the input dir,and last input filename
6.+support multi-select and then modify their settings
7.*Easy RealMedia Producer V1.3,EditorV1.1 full_version:
*add optional components to the full verion's setup:
1.Ac3Filter07b.
2.VobSub 2.23.
3.Elecard MPEG2 Video Decoder.
4.Ogg audio decoder
Easy RealMedia Editor v1.0prevew inside
support edit rm/rmvb in Real10 format.
Edit ability:
1.modify Title, Author, Copyright,Keywords,Description
2.cut file to piece
3.merge files.
4.can edit files which when edit use Helix RealMedia Editor will cause a Out of Memory error.
can edit in batchs.
redcheek is offline   Reply With Quote
Old 24th March 2004, 11:10   #2  |  Link
DanielSun
DanielSun's Avatar
Glad to see chinese in your homepage !
I am testing it ! Thnak you for your work !
Regards
Danielsun.
DanielSun is offline   Reply With Quote
Old 24th March 2004, 13:34   #3  |  Link
Marcel
creating mobile media
It failed on converting an AVI (DivX 5.1.1 non-Pro/AC3 encoded).
OK, it failed much faster than a GUI that calls the producer via command line, but it failed.
Same with same AVI, audio encoded as MP3 CBR (128kBit/s).
Both clips can be displayed fine via directshow on my PC.
*** 2004-03-24 13:26:45 New Session Start.  Jobs:1 ***
---2004-03-24 13:26:45 Start Encode Job  1, (K:\vid_test\test_ermp\Abraham-AC3.avi)->(K:\vid_test\test_ermp\Abraham-AC3.rm)!
	2004-03-24 13:26:49 Init Job Failed (K:\vid_test\test_ermp\Abraham-AC3.avi)!
---2004-03-24 13:26:49 Job Encode Failed(K:\vid_test\test_ermp\Abraham-AC3.avi)!
*** 2004-03-24 13:26:49 Session Finished. Finished:1,Success:0,Fail:1.
My settings can be found here.
Why is it called "Easy"?
Marcel is offline   Reply With Quote
Old 24th March 2004, 13:35   #4  |  Link
kilg0r3
! - User - !
kilg0r3's Avatar
looks very nice!
  • it should be possible to set startup latency to a max of 60.
  • it would be nice to be able to viw and and edit the audience/job file
  • it would also be nice to see and edit the commandline
  • there are more than three ehq modes IIRC
    an option to swithc off inloop filtering would be great
  • does it automatically use the new rate control?
  • AND, if you are very ambitious, you could try to implement somthing like the functionality of the DVD2svcd-Plugin RoBa
thank you very much for your efforts!
Keep your tone warm and your sigs decent!
kilg0r3 is offline   Reply With Quote
Old 24th March 2004, 19:44   #5  |  Link
damrod
damrod's Avatar
no screenshot??
it's programmed in which language?
Projects :
(dev stopped) DamBatch, MBatch
(generate mkv/mp4 files with aac(+)/vorbis/mp3 and x264/xvid/real or simple avi with h264/mp3 for fast reencoding using mencoder)
Website : Damrod.com
damrod is offline   Reply With Quote
Old 25th March 2004, 02:40   #6  |  Link
redcheek
Nothing......
redcheek's Avatar
Originally posted by Marcel
[B]It failed on converting an AVI (DivX 5.1.1 non-Pro/AC3 encoded).
in your video cropping setting
make sure (right-left) is 4 multiple and (bottom-top) is 4 multiple
you may try a new video cropping setting or just set it disabled to look whether it will work well
Old 25th March 2004, 04:24   #7  |  Link
redcheek
Nothing......
redcheek's Avatar
Originally posted by damrod
no screenshot??
it's developed using vc6+sp5+producersdk10_beta2
Interface support Simplified Chinese, Traditional Chinese and English language,auto select base on your system's.
this is the english interface screenshot:
Old 25th March 2004, 08:24   #8  |  Link
redcheek
Nothing......
redcheek's Avatar
25/3/2004 update to v1.52
*adjust the english language resource and correct the Traditional Chinese language resource.
work screenshot
Old 25th March 2004, 09:03   #9  |  Link
iradic
please write some english readme... (or help )
ok this is not realy needed - but you could upload exe only zip (without extra apps) avisynth is first on the list ... filters also
(i'm on dial-up)
thanks...
iradic is offline   Reply With Quote
Old 25th March 2004, 09:45   #10  |  Link
kilg0r3
! - User - !
kilg0r3's Avatar
@ iradic: there is a link to the light version on the hompage.
Old 25th March 2004, 09:49   #11  |  Link
redcheek
Nothing......
redcheek's Avatar
(i'm on dial-up)
thanks...
ok it's done
may be i need improve my english first beforce write something english....
Old 25th March 2004, 14:10   #12  |  Link
Marcel
you may try a new video cropping setting or just set it disabled to look whether it will work well [/B]
well, source was 720*576; I cropped left 10, right 10, top 80, bottom 80. That gives an image of 700*416; 700 MOD 4 = 0, 416 MOD 4 = 0.
Or would have been left 10, right 710, top 80, bottom 496 the correct values for cropping 10 left, 10 right, 80 top, 80 bottom? If so, the GUI gives no hint about that.
Old 25th March 2004, 15:54   #13  |  Link
notags
@redcheek: 台兄您的软件很棒!相信除了YS RealAnime完成后能与其竞争外,短期内应该没有GUI能比得上ERM。请再接再厉!
notags is offline   Reply With Quote
Old 25th March 2004, 15:57   #14  |  Link
Sirber
Sirber's Avatar
Use english please.
download RealAnime and Bencos
Sirber is offline   Reply With Quote
Old 25th March 2004, 18:27   #15  |  Link
notags
@Siber: Sorry, didn't know English is the only medium allowed.
@redcheek: Just a minor bug report, I do not wish to fill in any of the details like copyright title etc.. So I usually uncheck the "Same as filename" under Clip Info. Unfortunately, when I tried to save as default, this particular setting is not captured i.e. the box remains checked the next time I restart ERM.
Will fill you in when I find more.
Old 26th March 2004, 02:40   #16  |  Link
redcheek
Nothing......
redcheek's Avatar
left 10, right 710, top 80, bottom 496 is the correct values for cropping 10 left, 10 right, 80 top, 80 bottom.
i'll make this particular setting clearly ... next version...
Old 26th March 2004, 02:56   #17  |  Link
redcheek
Nothing......
redcheek's Avatar
thx,i'll fix it
Old 26th March 2004, 09:20   #18  |  Link
Toll
Hi, redcheek
Your FPS set has something wrong...
No matter what FPS I input, the video finally output FPS "23".
So, please check...
May you tell me how to solve this?
Thank you very much~
Toll is offline   Reply With Quote
Old 26th March 2004, 10:29   #19  |  Link
redcheek
Nothing......
redcheek's Avatar
Originally posted by Toll
Hi, redcheek
So, please check...
The maximum frame rate that the codec will attempt to reach. While the codec will attempt to reach this frame rate and maintain it, the resulting frame rate may be lower than requested if the bit rate is not high enough to achieve a baseline level of quality. The higher the bit rate, the more likely it is the codec will be able to achieve the frame rate specified.
Old 29th March 2004, 03:35   #20  |  Link
redcheek
Nothing......
redcheek's Avatar
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
