13th March 2004, 00:46 | #1 | Link |
Paldo-GNU/LinuxMaintainer
Daily MEncoder Builds
Hi there! I started to port the linux mencoder version to windows.
I'll do this everyday (... if I found some time). Here is the latest version: Download Mencoder CVS 01.04.04 MinGW Build optimized for AMD and Intel (ca. 1.50 MB) - fast download server 80k! Download Mencoder CVS 01.04.04 CygWIN Build optimized for AMD and Intel (ca. 2.00 MB) - fast download server 80k! All builds are upxed and in WinACE 2.5 packed.
Paldo GNU/Linux Homepage Paldo GNU/Linux Wiki Download of Installer-LiveCD Installation guide for the Installer-LiveCD Need fast help? Talk with me Last edited by Amnon82; 1st April 2004 at 06:10. |
13th March 2004, 03:52 | #2 | Link |
@Amnon92,
Below are my commandline to encode to VCD REM ################################################################# mencoder.exe -of mpeg -ovc lavc -lavcopts vcodec=mpeg1video:intra_matrix=8,9,12,22,26,27,29,34,9,10,14,26,27,29,34,37,12,14,18,27,29,34,37,38,22,26,27,31,36,37,38,40,26,27,29,36,39,38,40 ,48,27,29,34,37,38,40,48,58,29,34,37,38,40,48,58,69,34,37,38,40,48,58,69,79:inter_matrix=16,18,20,22,24,26,28,30,18,20,22,24,26,28,30,32,20,22,24, 26,28,30,32,34,22,24,26,30,32,32,34,36,24,26,28,32,34,34,36,38,26,28,30,32,34,36,38,40,28,30,32,34,36,38,42,42,30,32,34,36,38,40,42,44:vratetol=1 000:vbitrate=1150:vrc_maxrate=1150:vrc_minrate=1150:vrc_buf_size=328:vqmin=2:vqmax=24:vb_qfactor=1.2:vi_qfactor=0.8:vqblur=0.3:keyint=15:aspe ct=4/3:vmax_b_frames=3 -vf scale=352:288 -ofps 25 -oac lavc -lavcopts acodec=mp2:abitrate=224 -srate 44100 "C:\1.avi" -o D:\Test\TestVCD.mpg PAUSE REM ################################################################## First, i try with old mencoder (5.64 MB or 5,918,208 bytes ) .I can craete file D:\TestVCD.mpg but Nero deny to burn this file(Non compatible issue). Later,i try the latest MencoderDRPEncBuild120304.exe.Encodeing stop at the beginning and report error(For WinXP). Kindly look into my commandline if there is any thing gone wrong. Best regards, Last edited by itcth; 13th March 2004 at 03:56. |
13th March 2004, 16:23 | #3 | Link |
@itcth I checked Your script. It was ok. I used -no sound.
So here is the screenshot of your script using CVS 12.03.04: I got a 6.347 KB file. then I used my DRPEnc 0.2.0.1 to create a VCD script. Here the screenshot of the 1pass script: I got a 2.569 KB file with the same quality like Yours... Here the screenshot of the 2pass script: I encoded it without my special filters. Then I got a file with 3.884 KB. This file has the best quality and blows Yours strait away. I uploaded all the scripts and the sample I created with DRPEnc to my server. You can download it here . Try it out. On my AMD it works! Maybe You have a Intel and my builds don't work there...
Paldo GNU/Linux Homepage Paldo GNU/Linux Wiki Download of Installer-LiveCD Installation guide for the Installer-LiveCD Need fast help? Talk with me Last edited by Amnon82; 13th March 2004 at 17:19. |
14th March 2004, 19:06 | #6 | Link |
@Amnon82
Report #1.. I test vcd compatibility of your encoded file "vcd2pass.mpg.m1v" by mutilplexing in TMPGEnc(Without any new encoding of course) and burn with Nero.Hey,it does work.This is the first time i ever burn VCD with Nero without complain after many encoding with menocder. I am to going to test further by enccoding with my Intel Pentium 4. Best regards, Last edited by itcth; 14th March 2004 at 20:52. |
14th March 2004, 19:34 | #7 | Link |
I've only a AMD Athlon XP 2800+ (Batron)
So my builds are with MMX, MMX2, 3DNow, 3DNowEx, SSE Support. I can't add SSE2 to this build. Otherwise I can build a build with CPU-Selfdetection. But this will be slower. Also I can create a guide for compiling MEncoder. So everybody can compile it. Also it is possible that I host this builds. |
14th March 2004, 20:34 | #8 | Link |
@Amonn82
Report #2 Below are script, REM ============================================================ @ECHO on ECHO Batchfile created with DRPEnc 0.2.0.1 - by Avalon ECHO Start encoding movie... mencoder.exe -forceidx -of mpeg -ovc lavc -lavcopts vcodec=mpeg1video:vqmin=2:vqmax=24:vmax_b_frames=2:mbd=0:keyint=15:aspect=4/3:vbitrate=1150:vratetol=1000:vb_qfactor=1.2:vi_qfactor=0.8:vb_qoffset=1.25:vi_qoffset=0.0:vqblur=0.3:vqcomp=0.5:vlelim=-4:vcelim=7:dark_mask=0.15:tcplx_mask=0.1:scplx_mask=0.2_mask=0.1:trell:inter_matrix=16,20,24,28,32,36,40,44,20,24,28,32,36,40,44,48,24,28,32,36,40,44,48,52,28,32,36,40,44,48,52,56,32,36,40,44,48,52,56,58,36,40,44,48,52,56,58,60,40,44,48,52,56,58,60,62,44,48,52,56,58,60,62,62:intra_matrix=8,16,19,22,26,27,29,34,16,16,22,24,27,29,34,35,19,22,26,27,29,34,35,38,22,22,26,27,29,34,35,40,22,26,27,29,32,35,40,48,26,27,29,32,35,40,48,50,26,27,29,35,40,48,50,60,27,29,35,40,48,50,60,62 -vf crop=704:576,scale=336:206,expand=352:288 -ofps 25 -nosound "C:\1.avi" -o "C:\1.mpg" ECHO Demuxing now M1V-file... BBDMUX.EXE C:\1.mpg 0xe0 C:\1.m1v pause REM ============================================================== Encoding stop after encoding for a while.Please see details here; |
14th March 2004, 21:28 | #11 | Link |
@ itcth: Download DRPEnc 0.2.0.2 and it will be fine.
@ celtic_druid: THX, I'll check it right now! @ all: compiling guide is out. I got it: Code:
./configure --enable-largefiles --enable-mmx --enable-mmx2 --enable-3dnow --enable-3dnowex --enable-sse --enable-sse2 --enable-static --with-codecsdir=F:/mplayer/codecs
Paldo GNU/Linux Homepage Paldo GNU/Linux Wiki Download of Installer-LiveCD Installation guide for the Installer-LiveCD Need fast help? Talk with me Last edited by Amnon82; 14th March 2004 at 21:57. |
14th March 2004, 22:07 | #14 | Link |
Uploading new MEncoder Version optimized for AMD and Intel.
Added the new MEncoder Version to the installer version of DPREnc 0.2.0.2. Have fun with it. ... and I know that I'm the MAN ...
Paldo GNU/Linux Homepage Paldo GNU/Linux Wiki Download of Installer-LiveCD Installation guide for the Installer-LiveCD Need fast help? Talk with me Last edited by Amnon82; 15th March 2004 at 00:55. |
16th March 2004, 10:07 | #19 | Link |
I did it like the last build. But it crashed. I didn't changed my configure line. Lets see what happend today. For Hyperthreading is till now nothing build in. Maybe they add this feature. I'll check again the source.
