#1 | Link |
Matroska Team
New, experimental matroska splitter
Haali made a new, experimental matroska splitter : http://haali.cs.msu.ru/fonts.html This new splitter can load FONTS from matroska files, if they were attached to it. This will only work if you set the correct mime type for the FONTS when muxing them with mkvmerge/mmg, it is application/x-truetype-font This splitter will parse all attachements of a matroska file for this mime type, and then load them automatically for the embedded SSA subs of this file. Its important to understand that the FONTS are only temporarily loaded for the playback, and not installed. As soon as the playback graph is closed, they are unloaded. Have fun and report problems you find. If the build proves stable, it will become the next standard build .... |
#2 | Link |
Very nice idea...
But I noticed on the 'fonts' page you point to, the link for the splitter is to MatroskaSpilitter.ax when it should be MatroskaSplitter.ax. Note the spare 'i'. ![]() I typed the URL manually, and will test the filter shortly... EDIT: Working just fine so far... Not breaking existing files, and loading the fonts just like it should.
"We demand rigidly defined areas of doubt and uncertainty!" - Vroomfondel, H2G2 Last edited by omion; 4th March 2004 at 23:45. |
#3 | Link |
李姗倩 Lǐ Shān Qiàn
Worked like charm!!!!! Really impressive. This is something
![]() Unicode font (Japanese) tested too. I know a lot of ppl will be delighted with this....especially (or maybe ONLY) fansubbers... Will this be merged into Gabest's standard fileter in the end? I really hope so! - The correct URL as of now: http://haali.cs.msu.ru/MatroskaSplitter.ax - Tip Internal splitter should be disabled if tested with MPC |
#4 | Link |
chatarrero
Hi
I've got a problem. The sample works perfectly and it loads the font without problems, but an hour after creating one by myself, i can't load this correctly even trying different fonts. This is a little sample with this problem of not loading, let's see if someone knows what's wrong: http://www.divxhouse.com/test/prueba_ssa.mkv MKVMERGE: 0.8.5 kind regards |
#5 | Link | |
When I play your file on my computer, the file loads and the subtitles play, but the font isn't the one in the attachment. I messed around with a few things, and noticed that everything worked if I changed the 'Encoding' number in the subtitle file to 0. So change the line: Code:
Style: Default,McKloud Storm,38,&H00ffff,0,0,&H333333,-1,0,1,1,1,2,30,30,30,0,128 Code:
Style: Default,McKloud Storm,38,&H00ffff,0,0,&H333333,-1,0,1,1,1,2,30,30,30,0,0 I uploaded a re-muxed file to http://people.ucsc.edu/~rswilson/other/remixed.mkv. I also put the edited subtitle file to http://people.ucsc.edu/~rswilson/other/subs-works.ssa, so you can see if it works when you make the mkv. I have no idea what the 'Encoding' flag does; I just changed stuff until it worked. ![]()
"We demand rigidly defined areas of doubt and uncertainty!" - Vroomfondel, H2G2 |
#8 | Link |
Hello.
I think i have found an error in Haali's splitter (it last too much time loading a large - 700 MB - .mkv file. I have used MPC for testing) Take a look at: http://forum.doom9.org/showthread.ph...809#post456809 |
#10 | Link |
@Liisachan:
Where is a list of value and the coorrespanding character set for this attribute? And have it any relation to the "at" sign befor the font name(which should also load the japanese part of fonts). PS: Is there any relationship from you to this site? Last edited by ac-chan123; 11th March 2006 at 15:09. |
#11 | Link | |
李姗倩 Lǐ Shān Qiàn
It's defined in Include/WinGDI.h in Platform SDK.
As another note, Sabbu can't handle DEFAULT_CHARSET (1). And, yes, I know that site. Um... do you read Japanese? We have one of celtic_druid's mirrors, on its subdomain. EDIT I forgot to answer about @-marked fonts. That thing is for vertical writing (top-to-bottom). Last edited by Liisachan; 11th March 2006 at 18:33. |
#12 | Link |
Thanks for the list of the encoding values and the "at" sign.
No, i can't read japanese. I know some Kanji(e.g. the one used in Ghibli Movie titles, some cities or Hon, go, numbers, ...) and the kanas but that is all. On the german Doom9/Gleitz Forum i started a list of subtile Programms. It's in german, but the name and links can be understud without german knowledg ;-) http://forum.gleitz.info/showthread.php?t=26487 Last edited by ac-chan123; 11th March 2006 at 19:46. |
