Thread Tools Display Modes
Old 8th February 2004, 15:28   #1  |  Link
t1955feb
Don't buy this software
Don't buy this software dvdcloner 2 it's dvdshrink here's to these gangsters http://www.dvd--copy.net
TJ
t1955feb is offline   Reply With Quote
Old 9th February 2004, 01:25   #2  |  Link
djan
- DVDRB User -
Yes, ****** bad, it's really DVDShrink 3.05 Beta. You can see it when you push cancel while scanning the disc. The DVDShrink analysis window appears and then the main window. It's well camoufled.
- CaN -
djan is offline   Reply With Quote
Old 9th February 2004, 09:13   #3  |  Link
dvdshrink
I'm curious - but I don't want to install it, God knows what other stuff it will install as well.
I wonder if they managed to decrypt DVD Shrink and modify the executable, or are running it unmodified but in a hidden window, and sending it fake mouse click events...?
dvdshrink is offline   Reply With Quote
Old 9th February 2004, 21:56   #4  |  Link
djan
- DVDRB User -
Unmodified and in hidden windows, be sure.
- CaN -
Old 9th February 2004, 22:02   #5  |  Link
dvdshrink
Are there any programmers out there, who know how to prevent this kind of thing from within an application?
I suppose checking AfxGetMainWnd()->IsWindowVisible() would suffice? If you get a mouse click, and the window is invisible, something has to be wrong ;-)
Old 11th February 2004, 12:19   #6  |  Link
Nic
Also check that the window position is within the window view (i.e. so it can be seen on the desktop) and not obscured by a larger window. Also check Window Title/Caption names (so they can't rename them). And then, if you can, encrypt and compress your app.
That should do it (Hopefully)
Take Care,
-Nic
Nic is offline   Reply With Quote
Old 11th February 2004, 12:29   #7  |  Link
the-warriners
Check out the "version history"
Did you see the "version history" page?
http://www.dvd--copy.net/release.html
These guys just really take the cake! A whole page of versions that tells you absolutely nothing.
As far a protection goes you can try
http://www.aspack.com/
the-warriners is offline   Reply With Quote
Old 11th February 2004, 12:37   #8  |  Link
Nic
aspack and asprotect are good, but so well known that their are tutorials everywhere for them....dvdshrink, if he has the time, should look at the fravia messageboard and see which protections people have trouble hacking...
-Nic
Old 11th February 2004, 12:47   #9  |  Link
dvdshrink
Good point, thanks for the tip.
DVD Shrink is already encrypted and compressed, although I don't suppose there is any encryption software out there that would put off a determined hacker for long. I'm not aware that it's been hacked yet though. It's a strange world, that one should need to protect a free software.
Nic, good luck with Rejig! Will the GNU licence be enough to protect it?
Old 11th February 2004, 13:06   #10  |  Link
Nic
he he, I had a little go at decrypting dvdshrink, (I try on all things I realise that are protected). Looks like it's been compressed with UPX and then changed. I just dumped it with LordPE, never got round to fixing the OEP/IAT though. Ill try and tell you how hard it is (shame the old mod chainsaw isn't around, he'd probably crack it in a sec)
Thanks for the good luck I'll need it.lol...Don't have too much time. For the new unreleased version I'm sure im writing the SCRs a bit weirdly, but it seems to work. I love dvdshrink's interface, very well written.
GPL will protect it until it gets good enough to be ripped off. And then it'll probably be sold as something else Oh well.
If you do actually work at ahead, say hi to Menno and Ivan for me
Cheers,
-Nic
Old 11th February 2004, 13:33   #11  |  Link
dvdshrink
Nic, I'd love to know if you can hack DVD Shrink, but of course, don't publish how you did it on the forum ;-)
Naturally I checked out the Rejig source, and you're doing a great job getting all those modules working together. It's a big project! And yes, when it's finished, it will surely become the basis of many commercial implementations (in same manner as MSSG reference source for mpeg-2 video).
Let me know if you need help with anything. I'd like to contribute.
Old 11th February 2004, 13:41   #12  |  Link
Nic
Thanks loads dvdshrink I may well just have to do that. Currently dvdauthor is a bit particular about what video you feed it. i.e. the PTS values can't reset, nor can the SCR values. So in the new version I have to correct the all the PTSs and SCR values. It seems to work ok. But might need to should you for help.
I'll see what I can do with dvdshrink...did you make the protection yourself. When ever I've released stuff that I dont want people looking into I just used UPX and then hex edited bad values into the UPX header. Stops the average prying eyes but isn't secure.....
I'll keep you posted
-Nic
ps
Damn them for making PTS and SCR 33 bit variables hey? Would have made life so much easier if they had been 32 bit.....
edit:
grrr, I think the OEP is 0x10cc and after rebuilding the IAT table and setting that OEP. It should work, but doesn't. I must be forgetting something. But seeing I've got this far, and I dont know what im doing, someone with better skills probably could unpack it easily.
Old 11th February 2004, 14:35   #13  |  Link
dvdshrink
I attached the code used by DVD Shrink for reading/writing SCR, PTS and DTS, also a generic pack header structure.
// DVD Shrink
// the following should be in header file
typedef unsigned int uint32;
typedef unsigned short uint16;
typedef unsigned char uchar;
typedef unsigned __int64 uint64;
// data structure for first 36 bytes of a pack
// PTS, DTS and PES_EXT are optional fields. So actual size of pack
// header may be as small as 23 bytes, followed by stuffing and
// pack data. If PTS exists, DTS is optional. If no PTS, then DTS
// is not allowed.
// system header - 14 bytes (mandatory)
// PES header    -  9 bytes (mandatory)
// PTS           -  5 bytes (if pts_dts_flag & 2)
// DTS           -  5 bytes (if pts_dts_flag & 1)
// PES_EXTN      -  3 bytes (if pes_ext_flag)
// stuffing      -  N bytes (stuffing_size, 0 - 7 bytes)
typedef struct {
    // 14 bytes
    uint32  system_code;            // PACK start code
    uchar   scr_base_5      : 2;    // scr_base (bits 28 - 29)
    uchar   marker1         : 1;
    uchar   scr_base_6      : 2;    // scr_base (bits 31 - 30)
    uchar   scr_base_7      : 1;    // scr_base (bit 32)
    uchar   bits_01         : 2;
    uchar   scr_base_4;             // scr_base (bits 20 - 27)
    uchar   scr_base_2      : 2;    // scr_base (bits 13 - 14)
    uchar   marker2         : 1;
    uchar   scr_base_3      : 5;    // scr_base (bits 15 - 19)
    uchar   scr_base_1;             // scr_base (bits 5 - 12)
    uchar   scr_extn_1      : 2;    // scr_extension (bits 7 - 8)
    uchar   marker3         : 1;
    uchar   scr_base_0      : 5;    // scr_base (bits 0 - 4)
    uchar   marker4         : 1;
    uchar   scr_extn_0      : 7;    // scr_extension (bits 0 - 6)
    uchar   mux_rate_2;             // mux_rate (bits 14 - 21)
    uchar   mux_rate_1;             // mux_rate (bits 6 - 13)
    uchar   marker6         : 1;
    uchar   marker5         : 1;
    uchar   mux_rate_0      : 6;    // mux_rate (bits 0 - 5)
    uchar   stuffing_size   : 3;    // stuffing size
    uchar   reserved        : 5;
    // 6 bytes
    uint32  stream_code;            // stream code
    uint16  pack_len;               // PES pack length
    // 1 byte
    uchar   original_copy   : 1;    // original or copy flag
    uchar   copyright       : 1;    // copyright flag
    uchar   data_alignment  : 1;    // data alignment indicator
    uchar   pes_priority    : 1;    // PES priority
    uchar   pes_scrambling  : 2;    // PES scrambling control
    uchar   res10           : 2;    // reserved = 10b
    // 1 byte
    uchar   pes_ext_flag    : 1;    // PES ext exists flag
    uchar   pes_crc_flag    : 1;    // PES CRC exists flag
    uchar   addn_copy_info  : 1;    // additional copy info flag
    uchar   dsm_trick_flag  : 1;    // DSM trick mode flag
    uchar   es_rate_flag    : 1;    // ES rate exists flag
    uchar   escr_flag       : 1;    // ESCR exists flag
    uchar   pts_dts_flag    : 2;    // PTS/DTS exists flag
    // 1 byte
    uchar   pes_header_len;         // PES header data length
    // 5 byte PTS (optional)
    uchar   marker7         : 1;    // marker bit
    uchar   pts5            : 3;    // PTS bits 30-32
    uchar   res0011         : 4;    // reserved = 0011b
    uchar   pts4;                   // PTS bits 22-29
    uchar   marker8         : 1;    // marker bit
    uchar   pts3            : 7;    // PTS bits 15-21
    uchar   pts2;                   // PTS bits 07-14
    uchar   marker9         : 1;    // marker bit
    uchar   pts1            : 7;    // PTS bits 00-06
    // 5 byte DTS (optional)
    uchar   marker10        : 1;    // marker bit
    uchar   dts5            : 3;    // DTS bits 30-32
    uchar   res0012         : 4;    // reserved = 0011b
    uchar   dts4;                   // DTS bits 22-29
    uchar   marker11        : 1;    // marker bit
    uchar   dts3            : 7;    // DTS bits 15-21
    uchar   dts2;                   // DTS bits 07-14
    uchar   marker12        : 1;    // marker bit
    uchar   dts1            : 7;    // DTS bits 00-06
    // 1 byte PES_EXT
    uchar   pes_ext_flag_2  : 1;    // 0
    uchar   res11           : 3;    // 0x07
    uchar   p_std_buf_flag  : 1;    // 1
    uchar   p_pscf          : 1;    // 0
    uchar   pack_hdr_field  : 1;    // 0
    uchar   private_data    : 1;    // 0
    // 2 byte PES_EXT
    uchar   p_std_buf_sz1   : 5;    // P_STD buffer size
    uchar   p_std_bufscale  : 1;    // 1
    uchar   bits2_01        : 2;    // 01b
    uchar   p_std_buf_sz2   : 8;    // P_STD buffer size
} PackHeader;
// functions defined in this module
uint64 read_scr(const PackHeader * ppack);
void write_scr(uint64 nSCR, PackHeader * ppack);
bool pts_exists(const PackHeader * ppack);
bool dts_exists(const PackHeader * ppack);
uint64 read_pts(const PackHeader * ppack);
void write_pts(uint64 nPTS, PackHeader * ppack);
uint64 read_dts(const PackHeader * ppack);
void write_dts(uint64 nDTS, PackHeader * ppack);
// implementation
// read 64-bit SCR from a pack
    ASSERT(ppack);
    ASSERT(ppack->system_code == 0xba010000);
    // scr_base
    uint64 scr_base = ((uint64) ppack->scr_base_7 << 32) +
                      ((uint64) ppack->scr_base_6 << 30) +
                      ((uint64) ppack->scr_base_5 << 28) +
                      ((uint64) ppack->scr_base_4 << 20) +
                      ((uint64) ppack->scr_base_3 << 15) +
                      ((uint64) ppack->scr_base_2 << 13) +
                      ((uint64) ppack->scr_base_1 <<  5) +
                      ((uint64) ppack->scr_base_0 <<  0);
    // scr_extn
    uint64 scr_extn = ((uint64) ppack->scr_extn_1 <<  7) +
                      ((uint64) ppack->scr_extn_0 <<  0);
    // SCR
    return scr_extn + (scr_base * 300);
// write 64-bit SCR to a pack
    ASSERT(ppack);
    // write base and extn
    const uint64 scr_base = nSCR / 300;
    const uint64 scr_extn = nSCR % 300;
    ppack->scr_base_5 = (uchar)(0x03 & (scr_base >> 28));
    ppack->scr_base_6 = (uchar)(0x03 & (scr_base >> 30));
    ppack->scr_base_7 = (uchar)(0x01 & (scr_base >> 32));
    ppack->scr_base_4 = (uchar)(0xff & (scr_base >> 20));
    ppack->scr_base_2 = (uchar)(0x03 & (scr_base >> 13));
    ppack->scr_base_3 = (uchar)(0x1f & (scr_base >> 15));
    ppack->scr_base_1 = (uchar)(0xff & (scr_base >>  5));
    ppack->scr_extn_1 = (uchar)(0x03 & (scr_extn >>  7));
    ppack->scr_base_0 = (uchar)(0x1f & (scr_base >>  0));
    ppack->scr_extn_0 = (uchar)(0x7f & (scr_extn >>  0));
// check if the PTS exists in a pack
    ASSERT(ppack);
    return (ppack->pts_dts_flag & 2) != 0;
// check if the DTS exists in a pack
    ASSERT(ppack);
    return (ppack->pts_dts_flag & 1) != 0;
// read 64-bit PTS from a pack
// PTS is only 33 bits, and since DVD packs never use the MSB, could be
// optimized to return 32-bit unsigned
    ASSERT(ppack);
    // check PTS exists
    if (ppack->pts_dts_flag & 2)
        return ((uint64) ppack->pts5 << 30) +
               ((uint64) ppack->pts4 << 22) +
               ((uint64) ppack->pts3 << 15) +
               ((uint64) ppack->pts2 << 7 ) +
               ((uint64) ppack->pts1);
    // return invalid PTS if none exists
    else
        return (uint64) -1;
// write 64-bit PTS to a pack
    ASSERT(ppack);
    // set the PTS exists flag
    ppack->pts_dts_flag |= 2;
    // set the PTS
    ppack->pts1 = (uchar)((nPTS      ) & 0x7f);
    ppack->pts2 = (uchar)((nPTS >>  7) & 0xff);
    ppack->pts3 = (uchar)((nPTS >> 15) & 0x7f);
    ppack->pts4 = (uchar)((nPTS >> 22) & 0xff);
    ppack->pts5 = (uchar)((nPTS >> 30) & 0x07);
// read 64-bit DTS from a pack
// DTS is only 33 bits, and since DVD packs never use the MSB, could be
    ASSERT(ppack);
    // check DTS exists
    if (ppack->pts_dts_flag & 1)
        return ((uint64) ppack->dts5 << 30) +
               ((uint64) ppack->dts4 << 22) +
               ((uint64) ppack->dts3 << 15) +
               ((uint64) ppack->dts2 << 7 ) +
               ((uint64) ppack->dts1);
    // return invalid DTS if none exists
    else
        return (uint64) -1;
// write 64-bit DTS to a pack
    ASSERT(ppack);
    // set the DTS exists flag
    ppack->pts_dts_flag |= 1;
    // set the DTS
    ppack->dts1 = (uchar)((nDTS      ) & 0x7f);
    ppack->dts2 = (uchar)((nDTS >>  7) & 0xff);
    ppack->dts3 = (uchar)((nDTS >> 15) & 0x7f);
    ppack->dts4 = (uchar)((nDTS >> 22) & 0xff);
    ppack->dts5 = (uchar)((nDTS >> 30) & 0x07);
// end of file
Old 11th February 2004, 15:52   #14  |  Link
Nic
Thanks! Already got very similar code to that. But may use yours because yours is neater. My problem is laying out the SCRs correctly. I read a bunch of video packs in. Then write out less when their compressed and try to spread the SCR values evenly.
i.e.
Read 12 blocks
1st block's SCR = 10
last block's SCR = 10000
going to write 10 blocks (the compressed 12 blocks)
so Scr_Inc = (10000-10)/(12-1);
and SCR = 10;
Then I write out the blocks:
Block 1 = SCR
Block 2 = SCR + Scr_Inc
Block 3 = SCR + Scr_Inc + Scr_Inc
If that makes any sense Seems to work ok...but you don't get many blocks going up by the standard 146.086 value...
As for dvdshrink, think my OEP is wrong. I think if I find the right one use ollydbg ill be able to unpack it (but at work at minute, so can't)
-Nic
Old 11th February 2004, 17:18   #15  |  Link
mpucoder
getting off topic, but...
The increment in scr should always be around 146.085 (IfoEdit notation, it is actually 85/300 or .283+) to 146.260 for the NAV pack and video. This reflects the maximum bitrate of 10.08Mbs. (2048 bytes *8 bits/byte *90000 ticks/second /10080000 bits/second = 146.2857) Then the SCR jumps ahead during the audio and subpictures. Very important to get the video into the buffer as fast as possible.
edit: 146.086 is the highest that can be sustained (represents 146.2867). I've seen 146.085, but the next 2 packs were 146.086, for a total of 438.257 over three packs (average of 146.2856, still a little too fast). I assume further down there were some more adjustments to keep it right on the edge (I didn't write them all down), but it seems like a lot of work just to nudge such a small increase in speed.
mpucoder is offline   Reply With Quote
Old 11th February 2004, 17:40   #16  |  Link
Nic
So how can someone approach my problem without re-writing all the PTSs to keep inline with the SCR values only being increased by a maximum of 146.xxx ?
I know DVDShrink does this without modifying the PTSs. DVDShrink seems to suddenly jump its SCR values up a little and then carry on with the rougly 146.xxx increase. I haven't currently worked out how.
I haven't found a DVD player yet that didn't like my approach (and I've tried it on about 10). Infact when I completely screwed up the SCR values (they got way ahead of the relevant PTS values), only one DVD Player minded and that was only when seeking. However, I would like to do it "properly". Any suggestions ?
-Nic
Old 11th February 2004, 18:02   #17  |  Link
mpucoder
I don't see any problem, really. The DTS and PTS values should not change, as the time to decode and present do not change. And if you are reducing the video data, maintaining 10.08 into the buffer will not result in buffer overflow.
Perhaps you are looking at this as a streaming mpeg rather than a DVD. In a DVD the SCR is NOT the system clock, instead it is used to control the rate that data is read and buffered. In other words, the read process compares the SCR to the players master clock to determine when to put another sector into the buffer (oversimplified, since there are 16 sectors in one ECB)
Old 11th February 2004, 18:08   #18  |  Link
Nic
You are right, I was thinking about it like a System Clock. My bad misconception. So if my SCR increments by slightly more than 146 it shouldn't cause a problem?
Weirdly though, originally I just started the SCR at 0 and then incremented by 146.xx with every pack header, but this caused a problem when seeking to chapters or fastforwarding through the file ? Why would that be if it isn't used as the system clock?
I think what I've got now is ok, but if you've got any insight it will be real helpful
Thanks,
-Nic
Old 11th February 2004, 18:16   #19  |  Link
mpucoder
As for jumps, they occur in three places.
1) between video and audio/subpicture - after stuffing all the video in the reading relaxes a bit. The SCR of the first audio should not be changed, though, since this has been back calculated from the DTS and PTS of the streams to allow anough time to load the buffer (prior to the first DTS).
2) within audio/subpicture streams - they have much lower bitrates, and greater delay in decoding, so stuffing the buffer at max speed isn't needed.
3) between VOBU's - although this is usually small, since the audio/subpictures can be used to distribute the time. For good random access each VOBU should have enough lead time (usually 4 to 7 frames) for reading and decoding. The hard rule is the last pack of the first presented (not decoded) picture has to be read in time for it and all preceeding pictures to be delivered to the decoder, and decoded. For a lot of GOPs that means 3 pictures (2 B and the I).
Old 11th February 2004, 18:22   #20  |  Link
mpucoder
The SCR isn't used as the system clock, but it still represents the same time, and exhibits the same relationships with DTS and PTS as an mpeg stream. It's just that the tail wags the dog in a DVD. When a random seek occurs the players clock gets set to the first SCR encountered, reading begins at the rate indicated by SCR increments, and data gets delivered to the decoders according to the newly set clock and DTS, and then the show starts when PTS agrees with the player clock.
Thread Tools
[IMG] code is Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
