Old 29th January 2004, 04:42   #1  |  Link
rayvt
Besweet bug - it crashes in shibatch
I have an audio file that came from a MOV music video. I converted
the MOV to an AVI, and extracted the audio to a wav. The audio from
the mov was at 22050, and so is the wav. When trying to convert it to
an mp2 at 44100, besweet crashes in shibatch. But ssrc (v1.29) can
successfully resample it to 44100. The original wav is 185 seconds
(16mb), but a smaller clip (3 seconds, 2656kb) also fails.
This is on an AMD2400+, running XP-SP1. When I try in on a Pentium
running W2K, it just goes into a tight loop using 100% CPU, and never
terminates.
You can download the WAV file here:
<http://members.core.com/~ramvan/besweetbug.zip>
BeSweet v1.5b25 by DSPguru.
Using Shibatch.dll v0.24 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Using MP2enc.dll v1.129 (23/5/2002), Engine 1.129 <http://www.cdex.n3.net>.
Logging start : 01/26/04 , 21:58:09.
e:BeSweet.exe -core( -input Extr1.wav -output extr1.mp2 -logfile
Extr1.log ) -shibatch( --rate 44100 ) -2lame( -e -b 128 -m s )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : Extr1.wav
[00:00:00:000] | Output: extr1.mp2
[00:00:00:000] | Floating-Point Process: Yes
[00:00:00:000] +------ Shibatch -----
[00:00:00:000] | Source Sample-Rate: 22.1KHz
[00:00:00:000] | Dest. Sample-Rate: 44.1KHz
[00:00:00:000] | Attenuation : 0.0db
[00:00:00:000] +------- MP2ENC ------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | MP2 bitrate : 128
[00:00:00:000] | Channels Mode : Stereo
[00:00:00:000] | Error Protection: Yes
[00:00:00:000] +---------------------
Windows error popup box says this:
AppName: besweet.exe AppVer: 0.0.0.0 ModName: shibatch.dll
ModVer: 0.2.4.0 Offset: 0000dd9d
and
ModVer: 0.2.4.0 Offset: 0000b85c
g:\bugreport>ssrc --rate 44100 extr1.wav extr1-ssrc.wav
Shibatch sampling rate converter version 1.29
frequency : 22050 -> 44100
attenuation : 0dB
bits per sample : 16 -> 16
nchannels : 2
length : 265816 bytes, 3.01379 secs
dither type : none
rayvt is offline   Reply With Quote
Old 31st January 2004, 16:09   #2  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
bug confirmed.
i'm afraid i won't have the time to troubleshoot this in the near future.
DSPguru is offline   Reply With Quote
Old 15th April 2004, 04:00   #3  |  Link
rs008f
I have the same problem. I use VDub to convert the wav to the desired kHz.
rs008f is offline   Reply With Quote
Old 15th April 2004, 11:30   #4  |  Link
LigH
LigH's Avatar
I guess the reason is that the shibatch.dll is rather optimized for downsampling (48000 => 44100 Hz), whereas ssrc.exe is a full-featured sampling rate converter.
Old 16th April 2004, 16:04   #5  |  Link
Firewave
I had a different problem with the shibatch.dll. The output to be twice as fast as the input. I was downsampling from 48KHz to 44.1KHz and the input was also mono. When I removed the shibatch parameter with the output.
The thread was moved from the Audio encoding forum to DVD2SVCD forum. It can be viewed here:
http://forum.doom9.org/showthread.php?s=&threadid=71662
Firewave is offline   Reply With Quote
Old 5th November 2004, 23:10   #6  |  Link
Tiggerpaws
I guess this is *profanity removed by moderation*
Tiggerpaws is offline   Reply With Quote
