Old 25th January 2004, 16:56   #1  |  Link
Koepi
Koepi's Avatar
Niltze! (XviD-1.0-RC1-26012004)
Heya folks,
it's a whole month of hidden work, but here we are:
We proudly announce the release of XviD 1.0 Release Candidate 1, Codename "Niltze"! Before anyone asks - it's no nazi german, it's Aztec.
Changelog:
XviD-1.0-RC1-25012004 (Niltze):
- Cleaned up VfW-GUI
- Colour space assignment fixes (dshow)
- Weight zones fixed
- Overhauled VfW status window in general
- Bugfixes in the plugin system
- Statsfile existence gets checked now on 2nd pass
- Postprocessing fix
- Faster first pass QPel gets disabled as well now
- Installer deletes old XviD configuration (no need for "Load defaults" after install)
Regards,
Koepi
Koepi is offline
Old 25th January 2004, 16:59   #2  |  Link
Human_USB
Plug me in...
Human_USB's Avatar
Cool beans..... testing now.
*Edit*
I love the new status window. Great job Xvid team. So far so good.
Chaos in order or order in chaos..... which are you?
Human_USB is offline
Old 25th January 2004, 17:10   #3  |  Link
DAvenger
hacked
DAvenger's Avatar
Good work. Thanks
Pokec o sexe, láske a vzťahoch : http://www.mojvztah.sk
Spyware, malware a vírusy : http://www.antispyware.sk
Hudba, texty, akordy, noty, albumy, mp3 a videoklipy : http://www.musicworld.sk
DAvenger is offline
Old 25th January 2004, 17:16   #4  |  Link
Swede
Deputy
Swede's Avatar
I like the new status look. Thanks for keeping XVID alive!
One quick question: What kind of frame is S? (amongst the 'internals' in the status-window)
Swede is offline
Old 25th January 2004, 17:25   #5  |  Link
Koepi
Koepi's Avatar
S is a S-Vop - a frame where GMC gets used
Regards
Koepi
Koepi is offline
Old 25th January 2004, 17:28   #6  |  Link
aaar9800
Big thanks go to the whole development team!!!
One question though: Why is AS @ L5 chosen by default?
aaar9800 is offline
Old 25th January 2004, 17:29   #7  |  Link
Human_USB
Plug me in...
Human_USB's Avatar
Oh, one thing. Can you tell us what each color is on the status window.
And for Xvid 1.0 it would be nice if we could save the status window information into a text file.
-Thanks
Jason
Old 25th January 2004, 17:31   #8  |  Link
aaar9800
I think that
red = i-frame
blue = p-frame
green = b-frame
aaar9800 is offline
Old 25th January 2004, 17:31   #9  |  Link
Swede
Deputy
Swede's Avatar
S-VOP. Aha.. /me learns new stuff everyday.
(The colors are Red=I, Blue=P and Green=B)
Swede is offline
Old 25th January 2004, 17:57   #10  |  Link
mikeX
yakisoooobaaa!!
mikeX's Avatar
dammit, just when i got my first gamr build and thought i'd be a few steps ahead of the masses... , oh well
(my comments about the revised gui and status window are already posted -yes they are good -)
mikeX is offline
Old 25th January 2004, 17:59   #11  |  Link
mf
mf's Avatar
Nice work on the status. It still lacks the curve-graphic (ala nandub) that me and suxen discussed, but it's certainly improving .
mf is offline
Old 25th January 2004, 18:05   #12  |  Link
seewen
Profile "AS@L5" is used by default. Does it mean that Rate Control's working correctly ?
(I know that it's written that "XviD RC will not respect these value" ).
seewen is offline
Old 25th January 2004, 18:40   #13  |  Link
CiNcH
CiNcH's Avatar
Does XviD's GMC support 4 warppoints?
Bye
CiNcH is offline
Old 25th January 2004, 18:53   #14  |  Link
Alxemi
Happy XviD user
Alxemi's Avatar
mirror
Big thanks to all XviD development team!!
Here it is a mirror for those who having problems with wget, downloads managers or whatever.
Mira detras de ti... ˇUn mono con tres cabezas! (Guybrush Threepwod)
Alxemi is offline
Old 25th January 2004, 19:16   #15  |  Link
Heini011
@Koepi & other devs: thanks a lot for your great work!
but again: please, make the fast first pass only be active, when the 'discard first pass' option is selected. i had already 2 times forgotten to deactivate the quant 2 zone in the second pass.
i use the first pass result to check the avisynth filter settings and for a size estimation.
i have a beta3 first pass ready (20h processing time, no weight zones). can i keep the stat file for RC1 ?
greetings, Heini011.
Heini011 is offline
Old 25th January 2004, 19:20   #16  |  Link
Koepi
Koepi's Avatar
Heini:
yupp, you could use that statsfile. Just remember to setup everything like it was again, now after installing my build XviD sets everything to the defaults
Regards
Koepi
Koepi is offline
Old 25th January 2004, 19:28   #17  |  Link
Human_USB
Plug me in...
Human_USB's Avatar
With the new Xvid I'm having problems keeping the size down. Even at 2000kbps it's make a 40 minute video about 500-650 MBs. It's still encoding but I'm at 135MBs at 13600 frams of 65504. Maybe it's because the Weight system is fixed. Would 1000kbps look dvd like and remain small in the new RC? Each new xvid is so great but different.
Old 25th January 2004, 20:03   #18  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
Originally posted by CiNcH
Does XviD's GMC also support 4 warppoints?
no 3 warppoints
Mr_Khyron is offline
Old 25th January 2004, 20:06   #19  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Re: Niltze! (XviD-1.0-RC1-26012004)
Rats! And I thought you spelled "Schnitzel" totally wrong...
np: Autechre - 777 (LP5)
Leak is offline
Old 25th January 2004, 20:52   #20  |  Link
cretin
Minimal Frame Quantization Default is 1
Hey. I installed the the new build and the first thing that i spot is that the Min I P and B Frame Quantizer defaults are 1 instead of 2.
It was known that quant 1 has some problems, like they are not working well(?), or even if they are working they dont have any effect on quality they just increase size. I would like to know if this is fixed or improved by now or is there any change there at all ? Is there a point in using minimal quant 1, ll that result in higher quality or anything ?
Thank for your answers.
cretin is offline
