20th January 2004, 19:50 | #1 | Link |
***Formula to guess the Decimate cycle***
Have a look:
http://forum.doom9.org/showthread.ph...541#post431541 This could be very neat for weird patterns like silent movies Code:
c= combed frame number fc = former combed frame number bfc = before former frame number if (fc=c-1 OR fc=bfc+1) then cycle=c-bfc Example 1: Telecine (cycle=5) ============================= ABBCDEFFGH ABCDDEFGHH ppccpppccp (p=progressive c=combed) frames before combed: ccppp fc=bfc+1 cpppc fc=c-1 cycle=c-bfc=5 Example 2: PAL2NTSC (cycle=6) ============================= aka 2:2:3:2:3 pulldown ABCCDEFGHHIJ ABCDEEFGHIJJ pppccppppccp (p=progressive c=combed) frames before combed: ccpppp fc=bfc+1 cppppc fc=c-1 cycle=c-bfc=6 Bilu Last edited by bilu; 21st January 2004 at 00:27. |
21st January 2004, 00:36 | #2 | Link |
Last version doesn't work on patterns like this:
3000130001 AABCDE -> ABCDEE ABCDEE ABCDEE AABCDEFFGHIJ ABCDEEFGHIJJ pccccppccccp c ppccc fc=c-1 AND fc=bfc+1 -> cycle=2 c cppcc fc=c-1 AND fc=bfc+1 -> cycle=2 c ccppc fc=c-1 -> cycle=4 c cccpp -> cycle=3 Bilu |
21st January 2004, 01:21 | #3 | Link |
Consider these patterns:
23012301 -> cycle 5 ABBCDEFFGH ABCDDEFGHH ppccpppccp 30013001 -> cycle 5 AABCDEEFGH ABCDDEFGHH pcccppcccp 3131 -> cycle 3 AABCCD ABBCDD pcppcp p=progressive c=combed Assuming: Code:
p=progressive fp=former progressive c=combed fc=former combed pat=(c-fc > p-fp) 1:0 off_c=((pat==1) && (c-fc==3))? 0:1 off_p=((pat==0) && (p-fp==3))? 0:1 cycle=(pat=1)? (c-fc)+off_c:(p-fp)+off_p Bilu |
21st January 2004, 15:22 | #4 | Link |
Small correction:
p=progressive fp=former progressive c=combed fc=former combed pat=(c-fc > p-fp) 1:0 off_c=((pat==1) && (c-fc<4))? 0:1 off_p=((pat==0) && (p-fp<4))? 0:1 cycle=(pat=1)? (c-fc)+off_c:(p-fp)+off_p Pretty nice for stuff like a Neo Genesis clip I have: Code:
A B C A AC C The purpose of this stuff is statistical, to help you make decisions over what you can do with weird streams. Bilu |
22nd January 2004, 08:41 | #5 | Link |
interlace this!
nice work... i'd like to bump this because i don't have any sources that choke with simple telecide default (good telecine must be a PAL thing :P)
sucking the life out of your videos since 2004 |
22nd January 2004, 18:31 | #6 | Link |
This is mostly useful to:
1) Identify Video and Film parts on hybrid streams; 2) Identify PAL to NTSC conversions made with the 2:2:3:2:3 process; 3) Identify large patterns with silent movies; As you can see in http://www.doom9.org/ivtc-tut.htm "SILENT FILMS", you have streams with multiple Telecine patterns one over another, and you have to Decimate more than one time. Maybe this can help too in those cases, at least the composed pattern shall repeat itself Bilu |
22nd January 2004, 19:45 | #7 | Link |
brainless
decimate(6) will restore PAL from 2:2:3:2:3 Pulldown, but the resulting
framerate is 24.975 fps instead of 25fps, due to the 30.00 <-> 29.97 issue. This means every 1000th frame of the PAL-Video will be dropped. a decimate cycle of 2997/497 (6.03018108651) is needed. Unfortunately decimate doesn't support float-cycles... is there any way to get true 25fps without using change/assumefps afterwards?
Don't forget the 'c'! Don't PM me for technical support, please. |
