#1 | Link |
"qcce", utility to automate One Pass VBR starting from an AviSynth file
Current version: 1.02 (27th January 2004)
Download: http://jonny.leffe.dnsalias.com/qcce/rar/qcce_1_02.rar Screenshot: http://jonny.leffe.dnsalias.com/qcce/images/qcce.png Source code (can be interesting if you are a Perl programmer ^^'): http://jonny.leffe.dnsalias.com/qcce...ource_pack.rar The app is tested with: CCE 2.66.01.07 CCE 2.67.xx.xx (last version checked: CCE 2.67.00.23) EclCCE 1.7b You can run: - Normal encodes (opv only) - Size prediction - Q finder (to find the Q needed to hit your target size). For the Q finder, i use a simple binary search (so there are a lot of rooms for improvement in this direction). + you get full save/load settings function, joblist, full save/load joblist functions, you can use custom matrices and (optionally) shutdown at the end. I've done all this stuff mainly to learn CCE a bit. It's useful for me, maybe can be useful for someone other... Cheers jonny
home sweet home Last edited by jonny; 27th January 2004 at 11:42. |
#2 | Link |
Retired, but still around
jonny, this certainly looks like a lot more than a learning exercise! For a first version it is packed with features. Do you plan to continue it and are you open to suggestions?
BTW, people may have been confused when you said "The app works only with CCE SP Trial 2.66.01.07". I think you mean this is what you have tested with? It seems to work fine with higher versions of CCE and ECLCCE in the very limited testing I have done. Great job! DD
How to Optimize Bitrate for CCE multipass |
#3 | Link | |||
![]() Quote:
on my side, things i'd like to add are: -Conditional encoding (encoding after q finding only if the Q is <= *something*) -Conditional stopping the joblist: you fill the joblist with "Q Find" jobs, the 1st with unfiltered source and good matrices, the others using progressively more aggressive filtering and/or matrices, after running all, the process will stop after finding the first combination that give a Q <= *something* (and maybe a jobs-grouping, so the feature can be used with more movies in the same joblist) -Maybe a resizing pass (i'm still not sure is needed, on my tests with full movies, i've got always undersized by 40-80MB, i'd like to hear experiences from others) -Optimization of the Q Finding process -Calculator for the target size ++Other ideas/suggestions i find interesting (so i can learn more ^^) Quote:
I use a fixed "ecl template", if the ecl format is the same between 2.66/2.67, it will work (i'll verify this in this week and let you know - anyway i think it will be not a big pain to eventually add 2.67 support) Atm you can use the menu function: "EclCCE->Save Ecl+Run EclCCE" to verify if all the parameters are set correctly with 2.67.xx.xx Thanks for the feedback
home sweet home |
#4 | Link |
Paldo-GNU/LinuxMaintainer
Jonny great program! I'll upload it now to my page so You have a mirror. If You want, I can translate Your program into german. PM if You want this.
I've the latest Version of CCE 2.67.00.23 and I'll test Your program with it in the next days with full PAL Movies. I think maybe You can beat Kwag's CQMatic (only for TMGEnc) of KVCD.NET. Go on with Your proggy.
#6 | Link |
many thanks Amnon82
![]() I've done testing on 2.67 and added support for it: http://jonny.leffe.dnsalias.com/qcce/rar/qcce_1_01.rar http://jonny.leffe.dnsalias.com/qcce...ource_pack.rar (only a little change was required, selecting "UFF" in my interface will now result in "Offset Line"=1 when you use CCE 2.67) To make a summary, i've tested v1.01 with: 2.66.01.07 2.67.00.13 2.67.00.23 (i'll check for compatibility every time a new beta will be out) EDIT: you was too fast for the mirror
home sweet home |
#7 | Link |
Hi Jonny!
Great job! I was waiting for such tool! I noted that you use same different settings in CCE: GOP Sequence= 3;4 (not "3;5") Luminance level=16 to 255 (not "0 to 255") Restrict auto I frame insertion selected (not "unselected") -> ("my settings") My settings comes from a template of RB. Maybe he can comment about it. Another thing. Maybe you could make a little change for searching faster a Q (and better?). In your app., IŽve made a test and it was necessary to encode 4 times to find a Q. Using the same source, manually, I needed encode only 2 times. IŽve just encoded something today. My sample test (including line "SelectRangeEvery(750,15)": File desired=29.555KB Q53 -> results 31.172KB -> error=+5,47% Q57 -> results 29.572KB -> error=+0,06% Qfinal=56 Encode settings: Q56 (500-9000kbps) QC (17) DC precision (9) Aspect Ratio 4:3 Progressive frame flag (NO) Upper field first (NO) Scanning (alternate) Frame rate 29.970 Quantization matrices (Standard) Final: File size results=1.458.481KB File size desired=1.477.744KB Error=-1,3% ------------------------------- Calculations: ->NextQ=Q+(1,5*Q*(FileSize-DesiredSize)/DesiredSize) ->if Abs(ActualError%)<=2% then, Qfinal=Q-1+LastError%/(LastError%-ActualError%)/2 This is nearly the same what Tylo uses in his plugin. It works very good to me. Regards, Alexandre |
#8 | Link | |||||
Hi Alexandre
![]() Quote:
This option seems to reduce the error on the single size prediction, you can find some tests here: http://forum.doom9.org/showthread.ph...0&pagenumber=3 Quote:
i've preferred to start with something simple (reducing the number of passes for the Q finder it's probably the next thing i'll go to do)Quote:
home sweet home |
#9 | Link | |||
IŽll make some tests with this. Regards, Alexandre |
#11 | Link | |
Actually the test was fully generated with my app (the html generator and other options are disabled in the binary release) If you have ideas on improving the single size prediction let me know, i can compare methods using a lot of automation. Cheers jonny
home sweet home |
#12 | Link | |
Retired
#13 | Link |
Thanks RB, this confirms that 1.01 works with all the 2.67.xx.xx versions.
I've a little question for you, actually i'm passing to EclCCE an ecl file that contains all the 3 options: ... top_first=... offset_line=... uscc=... ... so i don't need to make differences between 2.66/2.67 Seems to work nicely (i see no strange effect on both 2.66/2.67), am i doing something wrong? (i don't know how you handle internally this situation, so i have this little doubt)
home sweet home |
#15 | Link |
Hi Jonny,
I want only tell you that I test the version 1.01 now with my DRP 2.2 Settings on full movies ... THX for adding all the answers I need in Your app! I'll tell You if I reached 3.300 GB as I wanted ... P.S. Your PM-Mailbox is full... BTW: How to read Your Log-Files (*.enj)? Do You have a ENJ-Viewer?
Paldo GNU/Linux Homepage Paldo GNU/Linux Wiki Download of Installer-LiveCD Installation guide for the Installer-LiveCD Need fast help? Talk with me Last edited by Amnon82; 14th January 2004 at 00:33. |
#16 | Link | |||
![]() (i've tryed to document the main stuffs directly in the interface, usually you'll get a popup for every parameter that need to be explained) Quote:
![]() "Load job list" or "Append job list" from the joblist menu Generally you can save 2 kind of files: "ens" contains settings (basically it's one job) "enj" contains jobs Quote:
home sweet home |
#17 | Link |
Done with the test and it was fantastic!!!!
here is the result screenshot: It was amazing! Realy I started Your app with Blue Crush (its a Surfermovie with a lot of water...). I wanted the size 3.450 GB and I got 3.415 GB, it is only 34 MB less as I wanted!!! How I tested it: I select the movie, entered my DRP 2.2 Settings with AVAMAT4 and entered 3.450 GB as wanted size. 10% of the movie for calculating and run Q Find without encoding. After that I entered the final Q 21 and run the encode mode to see the difference of the wanted and getting file. This app is fantastic and I'll start writting now the guides for it. Read the PM form me about DRP2.2 ... THX Guide for the QCCE Program: Avalon's DRP 2.2 Guide
Paldo GNU/Linux Homepage Paldo GNU/Linux Wiki Download of Installer-LiveCD Installation guide for the Installer-LiveCD Need fast help? Talk with me Last edited by Amnon82; 14th January 2004 at 17:42. |
#18 | Link | |
Soon i'll do some tests with full movies to show what kind of error one should expect using different % (something really similar to what i've done for XviD/DivX)
home sweet home |
#19 | Link | |
You realy mean 2% of the movie...
...K, let see it. I run a test with 2% of a movie I've already encoded with Q22. Let see if QCCE will get this value also with 2%... As You can see it works also with ONLY 2% of the movie! FANTASTIC!!! Precition ONLY in 9 min!!!! CQMatic for TMPGEnc take over 30 min to get this!!! GREAT done jonny! ... and thanks for advice ...I change this in my guide Quote:
And it is the only reason that I start now learning pear, cos I want this app german I looked into the PL and I felt home! I translate it and create a DRP-Version with my settings as default I hope I can compile it... I've troubles with compiling it. I send you a PM about the 2 errors...
Paldo GNU/Linux Homepage Paldo GNU/Linux Wiki Download of Installer-LiveCD Installation guide for the Installer-LiveCD Need fast help? Talk with me Last edited by Amnon82; 16th January 2004 at 14:58. |
#20 | Link |
Bugga!!!I compiled my edited qcce.de.pl-file somehow and got a exe. I tried runing it and shot so my system!!! Jonny I'll send you a PM with the PL-file. Maybe I did something wrong. If You have time for it take a look into it and try to compile it. I think I did MANY mistakes editing it... I got a 2 MB NOT runing file... ... and it shots my system... Make a GHOST-Backup of C:\ before runing the compiled qcce.de.pl. THX anyway! |
| Thread Tools | |
| Display Modes | |
