Old 31st December 2003, 01:10   #1  |  Link
chrome
packed bitstream question
did a search on my question, came back with somewhat mixed results, and an unclear answer, so once and for all:
with the latest xvid release, is it a good idea to use packed bitstream. the whole b-frame lag thing while editing in nandub, is annoying, and if i use packed bitstream, i wont have this problem anymore, right?
BUT, im curious, will packed bitstream mean there may be any bad effects on the video? will i have problems playing the vid in any circumstances?
what (if any) are the pro's and con's of using it.
thanks.
-Eberhard.
The belief in a supernatural source of evil is not necessary.
-Men alone are quite capable of every wickedness.
chrome is offline   Reply With Quote
Old 31st December 2003, 01:19   #2  |  Link
iago
retired
iago's Avatar
If you use it, you will have playback problems with ffdshow.
iago is offline   Reply With Quote
Old 31st December 2003, 01:23   #3  |  Link
chrome
what kind of problems? will it be unplayable? have any sort of audio synch problems, b-frame errors...? i just started an encode of matrix, so ill find out in 6 hours, but a bit of a heads-up would be nice
thanks.
Old 31st December 2003, 11:48   #4  |  Link
Koepi
Koepi's Avatar
Ffdshow has problems playing back more than 1 consecutive bframe in packed bitstreams. It'll playback a little jerky (timing errors). You can still switch to XviD DSF (in ffdshow codec setup, select "disable" at xvid).
Regards
Koepi
Koepi is offline   Reply With Quote
Old 31st December 2003, 12:07   #5  |  Link
bond
and you will have problems on standalones with the mediatek chipset, the ess chip seems to handle it, dunno about other chips
Ogg Theora | Ogg Vorbis
Old 31st December 2003, 12:41   #6  |  Link
Koepi
Koepi's Avatar
For mediatek based players this will sure be fixed with a future firmware, if ESS is capable of coping with it
Regards
Koepi
Old 31st December 2003, 12:59   #7  |  Link
chrome
ok, so may as well not use it... through trial and error, ill be able to use nandub to perfectly split my large movie encodes onto two cd, so theres no real need to use packed bitstream. it just sounds like a bit of a pain in the ass using it, at the moment really.
this is really an ffdshow problem isn't it, is it likely to ever get fixed so that there will be NO errors at all using packed bitstream in the future?
i really dont know what that would depend on happening, so im really talkin outa my butt, i dont know if it can ever be fixed so there are no problems at all, using it.
Old 31st December 2003, 15:48   #8  |  Link
bond
yepa
btw: the divx5 decoder also seems to have some problems with more than 1 b-frame packed bitstreams, altough pb is their "invention" if i understand it right
Old 31st December 2003, 17:12   #9  |  Link
Nic
(Useful definitive answers so I've added a link to the FAQ)
-Nic
Nic is offline   Reply With Quote
Old 31st December 2003, 21:40   #10  |  Link
HarryM
I dont use packed bitstream.
This feature is too new for me, potentially problematic. Only original XviD decoder can corectly decode this.
HarryM is offline   Reply With Quote
Old 8th January 2004, 04:34   #11  |  Link
crusty
Ahhh....Nuts!!
crusty's Avatar
Sorry if this has been answered elsewhere...but this thread has been linked to from the faq thread so I think this questions needs to be asked here:
The disadvantage of packed stream has been answered in this topic, but:
What exactly are the advantages of using packed bitstream?
This thread hinted at better seekability, but I'm not sure....
Core 2 Duo intel, overclocked at something (can't remember what i set it at), about 2 TB in hard storage, nvidia 9800 GT and a pretty old 19tftscreen.
Crusty007 at en.Wikipedia.org
crusty is offline   Reply With Quote
Old 8th January 2004, 05:32   #12  |  Link
chrome
when i used packed bitstream, i found the playback VERY jerky, and also on my other comp, the video was actually vertically flipped (!!), but this is apparently an ffdshow problem?
as with better seekability, perhaps someone can help me with this... does it help you to better use the seek/position slider-bar in your movie player?
it DOES let you seek better in nandub if your planning on splitting a movie file into 2 segments, but im curious to know if it helps with searching while playing it in a movie player
either way, i dont use it, the movies play fine without it, and its not that big a bother when viewing it in nandub
Old 8th January 2004, 06:31   #13  |  Link
chilledoutuk
chilledoutuk's Avatar
i read somewhere that it can help with bframe lag can anyone confirm this?
chilledoutuk is offline   Reply With Quote
Old 8th January 2004, 21:41   #14  |  Link
fccHandler
Registered Jedi
Historically (from what I've seen), XviD packed bitstream AVIs are better for editing in VirtualDub. Without packed, I sometimes get wrong frame counts or an end frame ends up being lost.
P.S. I haven't seen any posts relating to this specifically, but it looks to me like the new beta3 codec plays choppy in WMP when I select packed bitstream. I've never used ffdshow at all, instead I allow the DivX 5.1.1 decoder to handle my XviD content. If I disable packed bitstream, there is no choppy playback, but then (as I said above) editing becomes unreliable in VirtualDub. Videos I've encoded with older versions of XviD play OK (packed or not), so I'm wondering if something has changed about the packing...
May the FOURCC be with you...
fccHandler is offline   Reply With Quote
Old 11th January 2004, 13:11   #15  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
A sideline observation.
Why are you generating so many problems for yourself by enabling packeted bitstream by default?
The popularity of ffdshow, and the missing support of proper playback is bound to give a lot of bad user feedback/support requests.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 12th January 2004, 08:54   #16  |  Link
fccHandler
Registered Jedi
As I said, editing in VirtualDub seems unreliable unless packed bitstream is selected. And it was never a problem with previous builds of XviD, only the latest one.
Old 12th January 2004, 13:26   #17  |  Link
HarryM
I dont use 'packed bitstream' temporarily.
