27th December 2003, 01:06 | #3 | Link |
Bored...
The picture on the top is with your new script... Right?
Nice results, but does it drop the speed more to the regular mfps-factor? Ok, enough joking... The sample image looks really impressive! As I said before, I'm not that advanced with complex script stuff... Please, could you give me an example usage to change the smoother!? Bye Last edited by Soulhunter; 3rd March 2006 at 23:17. |
27th December 2003, 12:51 | #4 | Link |
The usage is the same as with UnSmooth (if you remember ). If you want to use another smoother, you need to specify smoother= and params=.
HQDering(smoother="Convolution3D", params="preset="+Chr(34)+"animeLQ"+Chr(34)) for instance. And it's 7fps, i find that not so bad, now is it? |
27th December 2003, 18:58 | #5 | Link | ||
Bored...
THX n' Bye |
16th January 2004, 00:08 | #6 | Link |
Hey there, I need to use this dering filter on my TMNT anime DVD encode I'm working on because it's older and has a lot of "line noise". Would this script below be a valid one to use with the filter? If not, what would be a valid one? I've never modified, or even made an AviSynth script before so I have no idea really. Would mf toon be a good idea as well? Thanks guys!
script edited for length
AMD AthlonXP 1800+ Abit KX7-333R 512 MB Mushkin pc3000 DDR RAM 80 gb IBM 60gxp Hercules 3D Prophet 8500 @ 300/300 http://www.battle.net/war3/ladder/w3xp-player-profile.aspx?Gateway=Sunken-Ruins&PlayerName=CacK http://www.battle.net/war3/ladder/war3-player-profile.aspx?Gateway=Lordaeron&PlayerName=zonto http://service.futuremark.com/compare?2k1=4303905 Last edited by ZoNtO; 16th January 2004 at 15:29. |
16th January 2004, 06:37 | #7 | Link |
anybody?
AMD AthlonXP 1800+ Abit KX7-333R 512 MB Mushkin pc3000 DDR RAM 80 gb IBM 60gxp Hercules 3D Prophet 8500 @ 300/300 http://www.battle.net/war3/ladder/w3xp-player-profile.aspx?Gateway=Sunken-Ruins&PlayerName=CacK http://www.battle.net/war3/ladder/war3-player-profile.aspx?Gateway=Lordaeron&PlayerName=zonto http://service.futuremark.com/compare?2k1=4303905 |
16th January 2004, 11:12 | #8 | Link |
Well, HQDering is really only for slight ringing. It preserves so much detail that anything that's bad enough to be seen with the naked eye and without amplification won't be touched. The reason I made it was that I was annoyed at deringers in the fact that they harmed small details (well duh ). So I managed to make one that didn't do that. But it's really only for HQ (hence the name) sources. Also, if you had read closely enough (hint: at the top of the script is a section that says "Usage:"), the script is to be downloaded, saved into a directory, and then called with Import("HQDering-v0.1.avs"). You shouldn't just insert it at the end of your script (though that would have worked if you actually bothered to type HQDering() under it).
Note to other people reading this thread: I forgot to mention this here, but HQDering could be an excellent alternative to things like Dust or UnDot. It's a lot less destructive than said filters (possibly less effective as a result though), and should also create "invisible" extra compressibility, as some people like to call it. Last edited by mf; 16th January 2004 at 11:15. |
16th January 2004, 12:29 | #10 | Link |
With deen("a2d") or deen("a3d"), you don't need to substract the thin mask from the thick mask. Deen won't take into account pixels whose value is over the threshold. So by doing as you do, you only risk not to filter close enough of the real edge.
In fact, I think a script like that one would give better results : Code:
thinmask = msmooth(treshold = 10, highq = true, debug = true) enlargedmask = thinmask.blur().blur().blur().blur().binarize(upper = false, threshold = 1,y=3,u=1,v=1).blur().blur().blur() filteredclip = clip.deen("a2d") result = clip.maskedmerge(filteredclip,enlargedmask,y=3,u=2,v=2) Edit : @cyberman : it will still improve slightly the quality ( visually speaking ). When the quality is bad, applying a smoothing filter helps a lot, and the script will apply it on some part of the picture. But you won't see much difference. Last edited by Manao; 16th January 2004 at 12:34. |
16th January 2004, 12:40 | #11 | Link | |
16th January 2004, 13:04 | #12 | Link |
Yes, but your way, you're not sure to discard totally the edge, if he is really thick, and if on the contrary it is thin, you won't filter the pixels close to it.
And I don't do a binary mask, the last three blurs are not binarized. Finally, for having tested my script on a disney's movie, it doesn't create artifacts, and it is effective. |
16th January 2004, 15:30 | #13 | Link |
What about this script then? And thanks for the help too guys!
# # Created with Gordian Knot # # http://gknot.doom9.org # # PLUGINS LoadPlugin("C:\PROGRA~1\GordianKnot\mpeg2dec3.dll") LoadPlugin("C:\PROGRA~1\GordianKnot\undot.dll") #LoadPlugin("C:\PROGRA~1\GordianKnot\decomb.dll") #LoadPlugin("C:\PROGRA~1\GordianKnot\KernelDeInt.dll") #LoadPlugin("C:\PROGRA~1\GordianKnot\dgbob.dll") #LoadPlugin("C:\PROGRA~1\GordianKnot\Convolution3d.dll") LoadPlugin("C:\PROGRA~1\GordianKnot\FluxSmooth.dll") #LoadPlugin("C:\PROGRA~1\GordianKnot\TomsMoComp.dll") #LoadPlugin("C:\PROGRA~1\GordianKnot\VSFilter.dll") #LoadPlugin("C:\PROGRA~1\GordianKnot\SimpleResize.dll") # # SOURCE mpeg2source("C:\TURTLES_SCN\VIDEO_TS\tmnt ff.d2v") # #Import("C:\Documents and Settings\ZoNtO_the_KING\Desktop\mfToon-v0.52.avs") # #Import("C:\Documents and Settings\ZoNtO_the_KING\Desktop\HQDering-v0.1.avs") # # TRIM #trim(startframe,endframe) # # IVTC #Telecide(order=1,guide=1).Decimate() # or use #IVTC(44,11,95) #GreedyHMA(1,0,4,0,0,0,0,0) # # CROPPING crop(8,4,704,466) # # DEINTERLACING (1) #FieldDeinterlace() #FieldDeinterlace(blend=false) #TomsMoComp(1,5,1) # # DEINTERLACING (2) #KernelDeInt(order=1,sharp=true) # or maybe #DGBob(order=1,mode=0) # DEINTERLACING (3) - special requests #GreedyHMA(1,0,0,0,0,0,0,0) #Telecide() #SeparateFields() # # # SUBTITLES #VobSub("FileName") # # RESIZING LanczosResize(640,464) # Undot() # # DENOISING: choose one combination (or none) # 1) little noise #Temporalsoften(2,3,3,mode=2,scenechange=6) #mergechroma(blur(1.3)) #FluxSmooth(5,7) # # 2) medium noise #Temporalsoften(3,5,5,mode=2,scenechange=10) #Convolution3d("moviehq") FluxSmooth(7,7) # # 3) heavy noise #Temporalsoften(4,8,8,mode=2,scenechange=10) #Convolution3d("movielq") #FluxSmooth(10,15) # # BORDERS #AddBorders(left,top,right,bottom) # # COMPRESSIBILITY CHECK # !!!!Snip Size now has to be 14 for use in GKnot! #SelectRangeEvery(280,14) # # FOOL CCEnc #empty = BlankClip() #AudioDub(last,empty) # #mfToon() # #HqDering()
16th January 2004, 16:24 | #15 | Link |
Lines with # are comments. If you want to use mf's scripts, you have to remove the "#": # PLUGINS LoadPlugin("C:\PROGRA~1\GordianKnot\mpeg2dec3.dll") LoadPlugin("C:\PROGRA~1\GordianKnot\undot.dll") # Importing scripts Import("C:\Documents and Settings\ZoNtO_the_KING\Desktop\mfToon-v0.52.avs") Import("C:\Documents and Settings\ZoNtO_the_KING\Desktop\HQDering-v0.1.avs") # SOURCE mpeg2source("C:\TURTLES_SCN\VIDEO_TS\tmnt ff.d2v") # CROPPING crop(8,4,704,466) # RESIZING LanczosResize(640,464) # Usage Undot Undot() # Usage scripts mfToon() HqDering() |
16th January 2004, 16:43 | #17 | Link |
Tried that, got this:
Avisynth open failure: Script error: there is no function named "Unsharpmask" (C:\Documents and Settings\ZoNtO_the_KING\Desktop\mfToon...line 79 (C:\Turtles_SCN\Video_ts\tmnt anime.avs, line 90) Oh, and I did get those 3 dlls for mftoon as well, and put them in the load plugin part of the script.
AMD AthlonXP 1800+ Abit KX7-333R 512 MB Mushkin pc3000 DDR RAM 80 gb IBM 60gxp Hercules 3D Prophet 8500 @ 300/300 http://www.battle.net/war3/ladder/w3xp-player-profile.aspx?Gateway=Sunken-Ruins&PlayerName=CacK http://www.battle.net/war3/ladder/war3-player-profile.aspx?Gateway=Lordaeron&PlayerName=zonto http://service.futuremark.com/compare?2k1=4303905 Last edited by ZoNtO; 16th January 2004 at 16:46. |
16th January 2004, 18:43 | #18 | Link |
You probably need the updated version of MaskTools:
http://forum.doom9.org/showthread.php?s=&threadid=67232 |
16th January 2004, 19:02 | #19 | Link |
nope, tried that DL and it still gave me that error
