Old 14th December 2003, 08:08   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
DVD95Copy v2.0 "No compression" setting test results
I decided to do another test run on how well DVD95Copy compresses so I used the same DVD like I did in this thread. I wasn't testing for quality, just compression. The DVD is Thomas & Friends-Best of Percy. This is only a 4.35 GB DVD-5 so if I set everything to "No compression" and the main movie titleset to "Fit to DVD", I should get almost a 1 for 1 copy. That's logically thinking. Here's the test results.
DVD95Copy 2.0 settings
All Audio and Subtitles Kept and DVD Size(MB) at 4464
Title Set     Aspect   Audio      Subtitle   Repack TitleSet to:    Repack Menu down to:
X 0:175 MB    Full                                                  No compression
X 1:1788 MB   Full     en                    Fit to DVD             No compression
X 2:281 MB    Full     en                    No compression         No compression
X 3:528 MB    Full     en         en         No compression         No compression
X 4:999 MB    Full     en         en         No compression         No compression
X 5:297 MB    Full     en         en         No compression         No compression
X 6:387 MB    Full     en                    No compression         No compression
                ORIGINAL    No compression
VIDEO_TS.BUP         20 KB         20 KB
VIDEO_TS.IFO         20 KB         20 KB
VIDEO_TS.IFO    179,664 KB    179,664 KB
VTS_01_0.BUP         36 KB         36 KB
VTS_01_0.IFO         36 KB         36 KB
VTS_01_0.VOB    213,534 KB     84,502 KB :eek:
VTS_01_1.VOB  1,048,544 KB  1,048,574 KB
VTS_01_2.VOB    569,060 KB    568,688 KB
VTS_02_0.BUP         18 KB         18 KB
VTS_02_0.IFO         18 KB         18 KB
VTS_02_0.VOB      1,654 KB      1,654 KB
VTS_02_1.VOB    286,708 KB    286,708 KB
VTS_03_0.BUP         28 KB         28 KB
VTS_03_0.IFO         28 KB         28 KB
VTS_03_0.VOB      1,062 KB      1,062 KB
VTS_03_1.VOB    540,494 KB    522,576 KB
VTS_04_0.BUP         30 KB         30 KB
VTS_04_0.IFO         30 KB         30 KB
VTS_04_0.VOB        702 KB        702 KB
VTS_04_1.VOB  1,022,776 KB  1,022,560 KB
VTS_05_0.BUP         20 KB         20 KB
VTS_05_0.IFO         20 KB         20 KB
VTS_05_0.VOB          8 KB          8 KB
VTS_05_1.VOB    304,552 KB    296,866 KB
VTS_06_0.BUP         28 KB         28 KB
VTS_06_0.IFO         28 KB         28 KB
VTS_06_0.VOB    396,436 KB    396,436 KB
VTS_06_1.VOB          8 KB          8 KB
Total Size         4.35 GB       4.20 GB :eek:
Different end-size from original input
Here are the Size On disk info for VTS_01_1.VOB and VTS_01_2.VOB combined.
      Original: 1.54 GB   1,656,426,496 bytes
No Compression: 1.54 GB   1,656,078,336 bytes
    Difference:                 348,160 bytes :eek:
My analysis: My main menu VOB, VTS_01_0.VOB has shrunk very significantly! I did this test 3 times and there's still a difference of 129,032 KBs. The transcoded size is worse than the results I had when I did that same VOB with 1.5 Beta 1 @ 100% setting. That resulted in 90,576 KB back then. Anyways, there are still some VOBs present with decreased end sizes.
2COOL
Old 14th December 2003, 10:28   #2  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
Yo!
it isn't unreferenced material it's dropping is it?, a bit like the Universal DVD's that have an extra 190mb in the VIDEO_TS.VOB that will be dropped by some programs
I see its in the VTS_01_0.VOB, can you see what video it's dropping by comparing the 2 (maybe splitting them) and if it is referenced in the IFO. I'm sure you can work this one out and I hope you do as I'm interested in your results
cheers
MackemX is offline   Reply With Quote
Old 15th December 2003, 20:13   #3  |  Link
2COOL
2COOL's Avatar
Used DVD Shrink to analyze files off the DVD and there were no unreferenced materials present. So my compression detecting test is still in good standing.
2COOL
[IMG] code is Off
