14th December 2003, 03:38 | #41 | Link |
Mind Over Matter
Is it possible to use the codec for other uses, besides DVD conversion?
I was hoping to use it with After effects, but i couldn't see the codec in the pulldown list...
Optional signature you may use to appear at bottom of your posts :) |
14th December 2003, 05:09 | #42 | Link | |
I'm back! :D
My Blog |
14th December 2003, 05:32 | #43 | Link | |
Re: Re: Re: Machine Keeps Resetting With Coverting DVD 2 MP4
http://www.mersenne.org/freesoft.htm You could also test with Sandra or some other CPU intensive app, looping 3DMark'01 for a few hours for instance. I'd recommend Prime95, however, because it will report errors if it doesn't crash immediately. |
14th December 2003, 06:01 | #44 | Link | |
Posts: n/a
I had the exact problem. Uninstalling, Deleting the reg keys, Installing and Restarting didn't help me either. Go to Start Smart and click the big NERO button. Click serial numbers and delete all the previous version keys. Then start Nero Burning ROM and it will ask for the key. Now insert your 6.3.0.0 key and everything will work fine after that. |
14th December 2003, 11:21 | #45 | Link |
ARCalculator Developer
I uninstalled NeVideo.ax to try decode a ND video using FFDSHOW and CoreAAC, and well, CoreAAC opens the audio perfectly. However, I can´t manage to ffdshow opens the vídeo (configuring it to open any MPEG-4 video). Maybe it is problem of the container?
About the quality... it is not a wonder... but it is really easy, and fast to use. Regards |
14th December 2003, 12:10 | #46 | Link | |
Life's clearer in 4K UHD
Well, that's confused me even more now. Assuming that QuickTime Pro uses Halfpel as default in their encodes. Why is it their files play fine with the Xcard and Recode2's don't? Cheers EDIT: I'm wondering if it might be something to do with the AAC audio. Up to this morning I just used Nero's ShowTime to see if the encodes worked. However, I found earlier today that despite WMP9 being able to play both the audio and video streams of a Recode2 encode (slide bar dosn't work though). MPC (v6.4.7.2) can only play the video stream. The following 'Warning' appears: - Stream 1 Media Type 0: -------------------------- AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: Unknown GUID Name {4134504D-0000-0010-8000-00AA00389B71} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 0 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 20 WAVEFORMATEX: wFormatTag: 0x0000 nChannels: 2 nSamplesPerSec: 48000 nAvgBytesPerSec: 0 nBlockAlign: 0 wBitsPerSample: 0 cbSize: 2 (extra bytes) I guess Recode2 does not like the Core AAC DS filter I've installed. When everything else does! I wonder if Recode2 will allow me to generate a 'Video only' encode from my DVD source. If my Xcard can cope with just the video stream encode, then I think it's fair to assume the problem is with the audio!
14th December 2003, 13:05 | #47 | Link | |
Matroska Team
BTW, i wonder what wFormat tag alexnoe will use for his AAC-in-AVI implementation, and how mayn different wFormat tags will pop-up as there is no 'official' tag defined from the MPAA .... confusion and frustration of the users are guaranteed, this shit really should never had happened, at least an 'official' GUID for playback on DShow should have been defined by them.... |
14th December 2003, 13:31 | #48 | Link |
Ahh! Thanks Christian,
I think we are getting nearer to the heart of the problem. Maybe the Xcard does not like this wFormatTag either! Why is everything like this so difficult to standardise? Maybe everybody on the Doom9 forum should get together to create our own official "Unofficial A/V Regulative Association" or UAVRA! Joking apart, it might not be such a stupid idea! What do you think? Cheers EDIT: I forgot to ask. What AAC filter are people using in order to listen to the Recode2 audio stream with MPC?
14th December 2003, 13:40 | #49 | Link | |
Posts: n/a
Subtitles worked for me only in Nero ShowTime. QuickTime didn't show either. Can anybody please confirm? |
14th December 2003, 13:59 | #50 | Link |
the subs nero puts into .mp4 are not mpeg-4 spec compliant and will only be shown in their own players
edit: and did i already say that i hate it if progs steal extensions
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 14th December 2003 at 14:08. |
14th December 2003, 14:10 | #51 | Link | ||
clueless n00b
14th December 2003, 19:04 | #52 | Link |
ND Subtitles & Chapters issue
I'd like to bring some clarifications about ND mp4 files, Subtitles and Chapters support as it seems to generate much discussions, lack of understanding, etc. I hope this could enlight you on the way it is done and why.
Basically, the mpeg-4 standard doesn't specify a way to handle subtitles and chapters. That is to say the notion of movie subtitles and chapters doesn't exist in the standard. From that assumption, there is no reason to say subtiltes or chapters are ISO compliant or not since there is no spec for this. However mpeg-4 is a very rich standard and provide several tools one can use to implement the support of subtitles and chapters. For the subtitles, we can have : - 2D BIFS - Streaming Text Format (14496-17) - private data The first approach (2D BIFS) consists in the use of the complex mpeg-4 system layer to describe a presentation composed of multiple objects (audio stream, video stream, 2D bitmap, etc.). In the absolute this should be the best way to implement subtitles. However, due to its complexity it would involve a lot of work for us which simply means more delay before the release ! Beside this constraint, we were also faced to the fact that such complex system management would become a real headache on embedded platforms (ie standalones) were resource are extrexemly limited. Therefore a fast adoption of MP4 format in this area. Just imagine us telling standalone manufacturers : to support MP4 it's quite easy, just read the 1000 pages of mpeg-4 BIFS system standard, then make it fit in your 16 kB of memory and you'll get it ! You'll understand that solution was not reasonable for us and that's why we prefer in our first stage to not use this implementation. But in futur evolutions, the addition of new features like menus, interactivity, and with the spreading of more powerful chips, we may seriously consider this solution. The second solution "Streaming Text Format" is a new part of the standard not approved yet. It uses text data rather than bitmap for the subtitles and relies on the previous system layer. Considering subtitles in DVD are bitmap it would require some OCR process. In conclusion this solution is even harder to implement (imagine bitmap to unicode conversion for chinese or arabic language !). So we coulnd't choose this way. And finaly the last solution uses mp4 file user data to store our info. Since the mp4 file provides private data space, we simply put our compressed data here. These user data must be discarded by decoders that don't know how to handle them so that shouldn't hurt. This was the best compromise we found and basically this doesn't differ much from other system like vobsub which stores data in a file beside. For the chapter list, we applied the same recipe since there was no really other mean to achieve this. I hope this clarify a little bit things and help you to understand why these choice were done. And last but not least, for those who are concerned about ND MP4 files support on their standalone, be sure we're making much efforts in promoting ISO MP4 support in standalones. Discussions are on the way and hopefuly mp4 support will come quite soon. |
14th December 2003, 19:36 | #53 | Link | |
14th December 2003, 20:39 | #54 | Link | |
It turns out that v1.0b8 does the trick. Thanks
14th December 2003, 21:36 | #55 | Link | |
Re: ND Subtitles & Chapters issue
another one. I tried to remux the MP4 file to avi, but it seems that neither ffdshow nor ffvfw can decode the video stream. Arent XVID and LAVC compatible with Nero's MP4V? Since Nero is already able to encode to mp3, why doesn't Recode give the option to encode to mp3 or wav or to embed the original AC3? Or to mux to AVI? Quality and speed seem to be good; I like the product, but the current limitations make it unusable for me; I'll stick to xvid until ND can generate AVI files. Thanks. |
14th December 2003, 22:04 | #56 | Link | |
Many people with standalones will be relieved to know! Cheers
14th December 2003, 22:21 | #57 | Link | |||
Re: Re: ND Subtitles & Chapters issue
14th December 2003, 22:42 | #58 | Link | |
clueless n00b
14th December 2003, 22:47 | #59 | Link | |||
Re: Re: Re: ND Subtitles & Chapters issue
My player is an el-cheapest Nortek NDVX 100, based on ESS Vibrato I chipset. Quote:
VD could decode the content. My ffvfw is a build dated 20032810. Quote:
14th December 2003, 22:49 | #60 | Link | |
Matroska Team
