Old 6th December 2003, 20:03   #1  |  Link
Sigmatador
Posts: n/a
textsub: a bug?
well if i use a script like this:
Avisource("raw.avi").textsub("mysub.ssa")
here's a screenshot:
http://sigmatador.free.fr/Test/1.png
It's difficult to notice, but you can see a "squarre" around the subtitle, specially on the red colours.
If i put many textsub in the script to increase the problem i get this:
http://sigmatador.free.fr/Test/2.png
well this time it's easily noticiable ^^
oki when you normally use textsub it's hard to see it (but in fullscreen and specilly on red colors it's not that hard) but i wonder if its possile to correct this bug ^^ since i know it, my eyes can't avoid it
Old 7th December 2003, 00:10   #2  |  Link
mf
mf's Avatar
You mean chroma subsampling artifacts ? It's part of YV12. ConvertToRGB32() solves it, but only for watching, cause when you encode to XviD/DivX it'll convert to YV12 again and you'll get the blocks again .
mf is offline   Reply With Quote
Old 7th December 2003, 04:04   #3  |  Link
Zarxrax
No, He's talking about that gray box that encompasses the subtitles. That does seem really weird, and it could possibly be having an adverse effect on the compressability.
Zarxrax is offline   Reply With Quote
Old 7th December 2003, 04:56   #4  |  Link
mf
mf's Avatar
Hmmm. I saw the grey box, but I thought it was intended or something.
Old 7th December 2003, 12:21   #5  |  Link
K-Dash
nooblar
K-Dash's Avatar
It seems like Alpha Leveled Opaque Box was added by mistake. That is anoying, what vsfilter ver are u using anyway?
K-Dash is offline   Reply With Quote
Old 7th December 2003, 12:51   #6  |  Link
Sigmatador
Posts: n/a
"It seems like Alpha Leveled Opaque Box was added by mistake."
right, i could be this.
i got this problem with every version of vsfilter, i asked some fansubber to test it, and they got the same problem.
just put many textsub("file.ssa") in your script, this will add the wrong alpha box and increase the problem, so you can see it.
But i'm sure, with only one textsub(), on the red colour with fullscreen it's really anoying.
i hope it's easy to fix ^^
edit:
"just put many textsub("file.ssa")"
i mean that:
Avisource("raw.avi").textsub("mysub.ssa").textsub("mysub.ssa").textsub("mysub.ssa").textsub("mysub.ssa").textsub("mysub.ssa").textsub("mysub.ssa") etc.. ^^
Old 7th December 2003, 13:38   #7  |  Link
mf
mf's Avatar
Actually it looks like textsub is taking the small rectangle where to put the subs, and converts it to RGB and back.
Old 7th December 2003, 14:10   #8  |  Link
Wilbert
I hope that Gabest is reading this If not you should contact him ...
Old 7th December 2003, 14:28   #9  |  Link
Sigmatador
Posts: n/a
i did this a month ago, so i guess gabest doesn't read his pm, so i post it here with the hope that this time he will read it ^^
Old 8th December 2003, 12:30   #10  |  Link
Le Furet
Le Furet's Avatar
Your sub says "Tout le monde a l'air bien de s'amuser".
That's not french. The right sentence is :
"Tout le monde a l'air de bien s'amuser".
Master Capello
Le Furet is offline   Reply With Quote
Old 8th December 2003, 13:46   #11  |  Link
d'Oursse
Mushroomeur
Hopefully, you are also here to correct our mistakes
don't forget to mp me your articles
d'Oursse is offline   Reply With Quote
Old 8th December 2003, 18:36   #12  |  Link
Sigmatador
Posts: n/a
LOL, this *bug* is old and has been corrected a long time ago
gabest where are you ???
Old 9th December 2003, 12:33   #13  |  Link
mf
mf's Avatar
Could you test it in RGB colorspace?
Old 9th December 2003, 12:55   #14  |  Link
Sigmatador
Posts: n/a
already done, same problem
i'll test from vdub
Old 9th December 2003, 14:14   #15  |  Link
mf
mf's Avatar
i'll test from vdub
Hm, so it doesn't have to do with YV12->RGB->YV12 conversion. Strange.
Old 9th December 2003, 18:51   #16  |  Link
Sigmatador
Posts: n/a
bug with vdubmod too :-(
[idea] does someone have gabest phone? [/idea]
Old 11th December 2003, 23:37   #17  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Heya !!
I don't have Gabest phone number, but just another idea : thank him for his great player in MPC thread and slip this problem too.....
PS: French touch powaaaa !!!
Old 11th December 2003, 23:57   #18  |  Link
Manao
Already done
Manao is offline   Reply With Quote
Old 12th December 2003, 13:06   #19  |  Link
Sigmatador
Posts: n/a
LOL this thread turn into a frog invasion
anyway, about the alpha channel opaque box (used for shadow i guess), is it hopeless ?
Old 20th September 2004, 19:47   #20  |  Link
JediNight
Usually don't dig up old threads, but figured this was the best way to find out if this bug has been fixed at all? Was told not to use VSFilter on my current project bc of it, but if its fixed I'd like to save the 30% encoding speed for not converting colorspace.
JediNight is offline   Reply With Quote
