#1 | Link |
ScenAid
![]() Join Date: Mar 2003
SceneAid -- RC2
SceneAid RC2 is now available
What's SceneAid? * Complete Track creation for VOBID Demux * Automatically adds chapter/scene information * Automatically creates assigns audio to tracks * Automatically imports existing sub file to tracks How do you use it? 1) Rip your Movie with DoItFast4u 2) Encode all assets as normal 5) Run SceneAid - select your Doitfast4u demux directory and click "Generate Script" 6) Import script into scenarist 7) Verify Layout 8) Mux and enjoy If you would like to test SceneAid please feel free but make sure to report any problems back to me via email at sceneaid@sceneaid.com Available at: http://www.sceneaid.com Last edited by D3s7; 28th January 2004 at 05:44. |
#4 | Link |
Dutch strain
![]() Join Date: Sep 2002
seems somebody has been busy last night
What can I do to protect myself against the flu? By far, the single best way to prevent the flu is for individuals, especially persons at high risk for serious complications from the flu, to get a flu shot each fall. Last edited by influenza; 26th November 2003 at 16:33. |
#5 | Link |
Good to see people looking into helping vobid projects. Just wanted to voice my support.
If this tool eventually automates the Scenarist part of doing a vobid project, I will love you forever, well maybe only until dual layer burners are standard./MLS |
#6 | Link |
ScenAid
New RC1 posted which fixed a few issues with current posted version - updated to update.zip file as listed above.
RC2 will be released in the next few days.... this version included a new look, complete IFO processing (runs about 5x as fast this way), angle support. Once I am fairly sure this new version is working properly (by people testing and letting me know) I'll start working on getting the actual scenario authored. PGC and VOBID! |
#7 | Link |
I would be willing to test any new versions you have...
I have the new collector's edition of The Lion King on DVD and it needs to be demuxed by VOBID. I have successfully reauthored it by hand but would like to see how your program would work with it. I know how the structure is supposed to end up so I would be able to give you good feed back. let me know.. jarvis17_81@yahoo.com |
#11 | Link |
ScenAid
Working hard on it.... ran into some snags calculating Duration/Information for the Audio tracks which I'm attempting to iron out. (if any others out there would like to share info on drop-frame calculations and AC3/DTS headers I'd be much appreciated)
If I can't get them worked out in the next day or so I'm going to skip file/audio detection and work off imported files as current version does and worry about that after everything else is working correctly... To be honest, I have only received feedback from a couple people on if it's working for them or not and have been working directly with them. |
#12 | Link |
i get this error
hello with scene aid i get hte following error when putting in the doitfast log and the scenarist script....
it imports the information then somes up with this error run-time error '35601': element not found could someone shed some light on this... so i can figured out how todo the vob id regards d4g |
#13 | Link |
ScenAid
did you run the installer first or just grab the .exe?
That be the first thing I'd check... make sure your path to ifoupdate is correct too.. If all that's fine then check your HKEY_Current_user/Software/SceneAid key export that and email to me at the address above... |
#14 | Link |
i ran the installer and the ifo update is fine.....
it imports the doitfast log fine it comes up when i input the sceanarist file.....after it imorts the error comes up then when i click ok the program closes...?ill email u the key: |
#17 | Link |
ScenAid
d4g: when you run sceneaid and it dies, check you registry before running it again. key should be HKCU/Software/SceneAid - export that whole key
jaocc: email me your SceneAid.scp file - i'm interested in seeing where it's blowing up - D3s7 |
#20 | Link | |
i wouldnt mind debugging a new version if you have one in the works |
| Thread Tools | |
| Display Modes | |
