#1 | Link |
AviSynth Developer
![]() Join Date: Nov 2001
AviSynth 2.5.3 Released
Hi folks!
AviSynth 2.5.3 has finally been released! This is a major stability and feature release compared to AviSynth 2.52. Many bugs has been fixed, and DirectShow support has been seriously upgraded. As always the new Release can be downloaded from Sourceforge. Complete changelist: Additions: * Added audio support to DirectShowSource. * Added seeking support to DirectShowSource. * Added .GRF file loading to load filter graphs from GraphEdit. Be sure there is an open pin, to which AviSynth is able to connect, otherwise expect "the filter graph won't talk to me". * Added optional coring=true/false to Levels and Tweak. both true by default, as previously. * Added Histogram(mode ="levels") and Histogram(mode = "color") which displays levels histogram and YUV color placement. * AviSynth now properly converts to and from 24bit audio. WAV-files exported from vdub are compatible with at least WinAmp and CoolEdit. * German documentation. * Added DV type 1 video input, using AviSource(). Video only! * DirectShowSource() is now capable of properly opening audio with more than 2 channels. Tested with AC3Filter. * DirectShowSource() now accepts and properly decodes float-precision samples. Tested with AC3Filter. * Added checks for samplerate and framerate in Splice. * SwapUV(), UToY(), VToY() and YToUV() now also works in YUY2 mode. * Added C-style plugin support (still in testing) to allow plugin writers to use other compilers than MSVC. * Added Invert(), ShowAlpha(). * Added default parameters to ColorBars. * Extensive updates of German documentation. * DirectShowSource capable of opening audio only. WAV/AC3/MP3 can be opened using DirectshowSource. * Added experimental "align=true/false" to crop - this will realign frames if they aren't already. Alignement is 16 for SSE2 machines, 8 for others. * Added "Overall PSNR for Compare()" - thanks to temporance. * ResampleAudio now accepts any number of channels. * Added "after_frame=true/false" option to FrameEvaluate. This determines if the script should be evaluated before (default operation) or after the frame has been fetched from the filters above. Bugfixes: * Fixed memory leak in Plugin name export. * Incorporated file lock fix in AviSource by WarpEnterprises. * Minor fixes to field information in Info(). * Fixed occational hangs in DirectShowSource. * Fixed crashbug in Compare, when logfile was specified. * Fixed overflow in ResampleAudio (Thanks to IanB!). [Bug 770853]. * Fixed MergeChannels broken with more than 2 channels. * Made adjustments for longer sample support in ResampleAudio. * Fixed crash in ResampleAudio, if no audio was present. * Fixed crash in MonoToStereo(). * Fixed: Normalize(show = true) displaying invalid value, and added a dB amplification indication. * Fixed minor issues in audio routines with very long samples. * Fixed wrong colors in ShowSMPTE YV12 mode. * Corrected several performance problems in Limiter, YUY2 mode (thanks again ARDA!). * Fixed YUY2 FlipHorizontal giving garbage/crashing. * GeneralConvolution now properly processes 5x5 matrices. Thanks IanB? for the patch. * Fixed minor stuff in TemporalSoften. * (Hopefully) fixed precision in PointResize. * ConvertBackToYUY2 now throws an error if non-RGB is delivered. * Fixed occational crashbug in conditional Plane stats. Optimizations: * Added heavily optimized memory copy mode, that will be used in some blits. * Conditional unroll of fetch/unpack loop in dynamic compiled resizer. Now only unrolls if 1) Athlon 2) Source width < 512. Changes: * Further clarification in Info() regarding field information. * Minor changes to Limiter code (block prefetch). * ApplyRange now accepts startframe = stopframe. This will only process the specified frame. * ApplyRange now supports audio and processes it to the end of stopframe. * Reenabled function name export for VDubMod syntax highlighting - I'm not sure if it had much effect on stability. * Corrected ParseMultiplication so it parses from left to right. * The default luma range in Limiter is corrected to 16-235 (it was 16-236). * Temporarily disabled plugin function export for VDubMod. I'm suspecting this of the "crash+disappear" of VdubMod. * Removed HSIAdjust(). * Removed ffvfw from installation. * ShowSMPTE does no longer require fps parameter - only if the current fps cannot be used. * Made thread-safety changes to frame reference counting. * Exposed internal cache filter for plugins to use. Use it after an Invoke to cache frames. Last edited by sh0dan; 11th November 2003 at 20:01. |
#2 | Link |
AviSynth Developer
For those very helpful people here, the changes from the last (November 10th) CVS Binary:
* DirectShowSource now always throws "could not detect fps", even if audio could be opened. * Made DSS error messages report both audio and video, if neither can be opened. * AviSynth now properly converts to and from 24bit audio. WAV-files exported from vdub are compatible with at least WinAmp and CoolEdit. * Added Histogram(mode ="levels") and Histogram(mode = "color") which displays levels histogram and YUV color placement. YV12 only: ![]()
#5 | Link | |
AviSynth Developer
#9 | Link |
Simply me
[EDIT]
Sorry - didn't read post properly. Didn't even realise Window's gave version info on dll's regards Simon
http://www.geocities.com/siwalters_uk/fnews.html Last edited by Si; 12th November 2003 at 20:16. |
#10 | Link | |
AviSynth Developer
Re: Version properties
#11 | Link | |
Well, this version seems to throw me exception when exiting VirtualDub and VirtualDubMod, also when trying some scripts like this
#14 | Link |
![]() Join Date: Nov 2002
Could you make the Avisynth installer check the registry for where AviSynth is installed and install to that folder? I never install it to the default location, and I always come THAT close to clicking OK before I realize it. Sooner or later disaster will happen
#15 | Link |
Brazilian Anime Ripper
I detect a strange bug since 2.52 version (I didn't test 2.5 and 2.51 versions). I capture animes with analog device. My capture settings:
Resolution:320X480 Codec: Divx 5.1 Divx Settings: 1st quality based quantizer 2, Fastest, no BFrame, no Psy, Keyframe = 1 Problem: I created a AVS script with only AviSource("d:\capture.avi") line. The codec used to decode the video was DivX 5.1. Sometimes I see a full green frame (with a yellow dot). If I change VIDC.YV12 = "divx.dll" to VIDC.YV12 = "xvid.dll" in registry, and I open video again, the problem was gone. If I open video with VirtualDubMod directly (without AVS script) the problem is not occuring. I captured a video with Xvid codec and back registry to decode with divx.dll. The problem is the same. In other words, the problem of full green frame is occuring in the combination of AviSynth 2.52/2.53 and Divx 5.1 decoder with a resolution of 320X480. |
#16 | Link | |
OpenDMLsource would give me very similar behavior and speed as VirtualDub[Mod], when I just play the video clip. While AVIsource would be like half the speed. ??? Can anyboday confirm that? |
#18 | Link | |
OpenDML is an extension to the original Video for Windows (VfW) file format. It was drawn up to overcome the original 2GByte file length restrictions in avi files. |
#20 | Link | |
Retired, but still around
How to Optimize Bitrate for CCE multipass |
| Thread Tools | |
| Display Modes | |
