Thread Tools Display Modes
Old 8th November 2003, 12:09   #1  |  Link
DAvenger
hacked
DAvenger's Avatar
RadLight MPC DirectShow Filter v1.0.0.3 released
This new version should fix the incorrectly indicated duration bug. Please, test it and let us know if it works for you and/or if you find other bugs.
Binary (80kb)
Thanks,
RadLight team
Pokec o sexe, láske a vzťahoch : http://www.mojvztah.sk
Spyware, malware a vírusy : http://www.antispyware.sk
Hudba, texty, akordy, noty, albumy, mp3 a videoklipy : http://www.musicworld.sk
DAvenger is offline   Reply With Quote
Old 9th November 2003, 00:41   #2  |  Link
Liisachan
李姗倩 Lǐ Shān Qiŕn
Liisachan's Avatar
Thank you for the update ^^
Altho 1.0.0.1 didn't support unicode filename and couldn't open the file named with double-byte chars, 1.0.0.2 was already fine for me and this 1.0.0.3 is just fine too. As for the "duration" problem, Media Player Classic seems to show the correct "now at mm:ss" and total duration...even with 1.0.0.2, while WMP9 doesn't show the total time with 1.0.0.2 and .3. Is this the problem addressed? Sorry if I misunderstood.
Liisachan is offline   Reply With Quote
Old 9th November 2003, 11:09   #3  |  Link
DAvenger
hacked
DAvenger's Avatar
There was a problem with duration of files longer than 10 minutes. Seems to be fixed now
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
