Thread Tools Display Modes
Old 6th November 2003, 00:42   #1  |  Link
zedude
Dtdrive to demux & fix RM files
hi there !
Originally posted by karl_lillevold, about DTDrive :
There is a very powerful tool available via the Helix Community. As far as I know you currently have to check out source code and build it yourself...
I got it and build a mini gui :
- enables demuxing audio & video streams
- if producer did not finish indexing a file, dtdrive can fix it
i remember once i wished i had this tool
Broken link: download DTDriver.rar (475 ko)
Get it here instead: download DTDriver.rar (475 ko)
zedude is offline   Reply With Quote
Old 6th November 2003, 01:52   #2  |  Link
RadicalEd
very cool
[edit]any idea why the gui would work, but copying the commandline generated by the gui into a console and executing wouldn't? Because that's what I'm getting :|
RadicalEd is offline   Reply With Quote
Old 6th November 2003, 11:48   #3  |  Link
zedude
@ RadicalEd
you have to run dtdrive from it's own directory .
ie set your currentdir to ...\dtdrive\ before you launch command line.
pardon my frenglish...
Old 7th November 2003, 00:25   #4  |  Link
RadicalEd
ah, yeah, that works, although just decoding (not passthrough) doesn't work for writing to rmvb, and won't write to any other format (failed to find filewriter for designated file). Any ideas?
Holy crap I'm a noob all over again :|
Old 7th November 2003, 01:00   #5  |  Link
karl_lillevold
karl_lillevold's Avatar
decoding requires decoders for the formats you try to decode.
filewriting to other formats than RM, requires filewriters for those formats.
I tried zedude's GUI and it works nicely for the purposes it was made for, demux and passthrough fix. However, it does not include any other DLLs than those needed for these purposes, I think.
Sr. Codec Engineer | RealNetworks Codec Group | https://helixcommunity.org/
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 19th January 2005, 23:21   #6  |  Link
karl_lillevold
The link to the dtdriver GUI is dead. Unless the author updates or objects, I will make available a copy...
Old 19th January 2005, 23:38   #7  |  Link
bond
moved to realvideo forum
Ogg Theora | Ogg Vorbis
Old 19th January 2005, 23:43   #8  |  Link
karl_lillevold
bond: excellent! I noticed this old thread was in the wrong forum after I posted the reply, but knew I could count on you
Old 19th January 2005, 23:57   #9  |  Link
bond
just drop me a pm if you find another one
Old 21st January 2005, 18:18   #10  |  Link
karl_lillevold
Dtdrive GUI download: download DTDriver.rar (475 ko)
Old 24th January 2005, 13:18   #11  |  Link
clone83
clone83's Avatar
can u plz add a section to change the resolution....?
for example i have some rmvb files that are 576x432 and i want tro make them 336x252, but i want to beable to play them bs player and not just realplayer. thx in advance
clone83 is offline   Reply With Quote
Old 24th January 2005, 13:42   #12  |  Link
Sirber
Sirber's Avatar
You would have to recompress them with resize. You cannot just change frame size like that
Detritus Software
Sirber is offline   Reply With Quote
Old 24th January 2005, 18:10   #13  |  Link
karl_lillevold
Yes, in fact you can change the display resolution, just like that. However, this does not change the actual encoded resolution, and it does not make sense to reduce the display resolution (and this might well crash some players as well). If you want to lower the resolution to get lower bitrate, you will have to re-encode.
Old 24th January 2005, 18:57   #14  |  Link
Sirber
Sirber's Avatar
he wants to "resize to lower rez". Makes no sense.
Detritus Software
Old 25th January 2005, 00:51   #15  |  Link
clone83
clone83's Avatar
im do them at that resolution because when im doing my work i can watch my encodes and because also i do them at a smaller bitrate anyway. the are jusr some of the simple settings that i use for a 4:3 show,
Resolution - 336x252
Average Bitrate - 230
MAX Bitrate - 1150
and so far a have always gotten a very high quality encode for the size of the file i need and the resolution.
but as karl said that i can re-encode them to get my resolution, i have tried to get the files to re-encode but as i said last time you help me out i was getting sound problems but if there is a better way or some one knows of a better way then please let me know.
thx in advance
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
