4th November 2003, 00:04 | #2 | Link |
For an up-to-date discussion on removing rainbows, check out this thread here:
http://forum.doom9.org/showthread.php?threadid=62873 Somewhere on the second page of the thread you will find a script sh0dan came up with to remove rainbows, reprinted here: Code:
org = last org_u = utoy(org) org_v = vtoy(org) msharpen(threshold = 10, mask=true) reduceby2() greyscale() uv = blur(1.5).levels(0,2.0,255,0,255).blur(1.5) filtered_u = org_u.blur(1.5).blur(1.5).blur(1.5).temporalsoften(2,255,0,3,2) filtered_v = org_v.blur(1.5).blur(1.5).blur(1.5).temporalsoften(2,255,0,3,2) u_final = MaskedMerge(org_u, filtered_u, uv) v_final = MaskedMerge(org_v, filtered_v, uv) ytouv(u_final, v_final, org) |
4th November 2003, 01:09 | #4 | Link |
Glad you found something that you like. As far as using dlls go, you could also try using MipSmooth (see my post on the first page of the thread I mentioned for the settings). Also, scripts are just as convinient as dll filters if you make them into a function. For example, you can convert sh0dan's script into a function as follows:
EDIT: See sh0dan's post below for a working script. Simply save the above code into a new text file and rename it to "function.avs". Now you can load it as if it were a dll filter using the Import() command, ie, Code:
Import("C:\function.avs") Avisource("C:\something.avi") DeRainbow() Functions are one of the more fun things you can do with avisynth, although one might argue it requires a bit of programming background to do some of the more complicated things. If you don't know how to program, I think that learning AviSynth functions is a simple and great way to get started, since it does not have a lot of the difficulties involved in learning a language like c++ from scratch. Check out the shared functions on the AviSynth homepage to see what some other people are doing, and try some functions out for yourself in your free time, it will really help you get the most out of AviSynth. Last edited by qwerpoi; 13th November 2003 at 06:58. |
4th November 2003, 09:58 | #5 | Link | |
i really dont know much about advanced scriptin i wish i could learn it an maybe some day i will write somthin like this thanx alot u helped me alot |
4th November 2003, 10:28 | #6 | Link | |
4th November 2003, 11:01 | #7 | Link | |
GuavaComb(Mode="NTSC",Recall=85,MaxVariation=100,Activation=70) |
4th November 2003, 11:23 | #9 | Link | |
4th November 2003, 12:21 | #10 | Link | |
(No, I wasn't referring to my own creation to advertise, but because it was the one I could find easily and of which I know it works .) |
4th November 2003, 15:00 | #12 | Link |
Yoshi
you can also try this setting for rainbows in static scenes (works fine for me, not strong enough for temporal errors from minor patterns, but works fairly well with static rainbow, line noise, and that hideous dot crawl)
GuavaComb(mode="NTSC",recall=85,maxvariation=35,activation=30) watch out for patterns... and did you give "smoothuv" a try? that works spatially. does not work as well as smoothiq but its way faster. I looked at your "problem.avi" and my guavacomb setting should work pretty well to get rid of that line noise. tweak maxvariation if too much line noise comes through.
member of www.clan-ee.com Last edited by MasterYoshidino; 4th November 2003 at 15:05. |
4th November 2003, 15:27 | #13 | Link | |
and i used the script at the start of the forum it removed it completly |
4th November 2003, 15:30 | #14 | Link | |
and if u can help me with my "problem" i will be very greatful |
4th November 2003, 17:25 | #15 | Link |
Yoshi
i remember there was a thread one time... where is it now...
a/w here is the dll for avisynth2.5. http://members.cox.net/hentai/SmoothUV.rar syntax is (radius,strength,interlaced boolean) example SmoothUV(5,16,false) accepts YV12 data only. hits subtitle and credit rainbows pretty easily, some rainbows it only hits at too high a strength and ends up cross coloring / color bleeding. if that happens, stuck with slow as can be smoothiq.
member of www.clan-ee.com |
9th November 2003, 21:02 | #16 | Link |
About Shodan’s chroma smoothing script — It will work substantially better if it only smooths vertically within a field. What you really want for this purpose with NTSC video is a 1:2:1 FIR filter. (In other words, weight 1 for the line above, 2 for the current line, and 1 for the line below.) For PAL you would want (this gets icky) 1:0:2:0:1.
For Guava stuff, I wouldn’t raise MaxVariation all the way to 100 — That’ll show a lot of artifacts. For a more permissive setting, I’d reduce Recall and possibly Activation, with something like GuavaComb(Mode="NTSC", Recall=70, Maxvariation=50, Activation=40) But the best MaxVariation does depend on your input card. And like Wilbert mentioned, regardless of its settings, Guava will only work on completely static parts of a picture.
9:) Lindsey Dubb |
11th November 2003, 07:50 | #17 | Link | |
plebian
I followed what was said below. I have the following lines in my .avs file
----- LoadPlugin("D:\downloads\windows\utilities\divx\avisynth\plugins25\MPEG2Dec3.dll") LoadPlugin("D:\downloads\windows\utilities\divx\avisynth\plugins25\undot.dll") LoadPlugin("D:\downloads\windows\utilities\divx\avisynth\plugins25\Decomb.dll") LoadPlugin("D:\downloads\windows\utilities\divx\avisynth\plugins25\STMedianFilter.dll") LoadPlugin("D:\downloads\windows\utilities\divx\avisynth\plugins25\awarpsharp.dll") LoadPlugin("D:\downloads\windows\utilities\divx\avisynth\plugins25\masktools.dll") LoadPlugin("D:\downloads\windows\utilities\divx\avisynth\plugins25\msharpen.dll") Import("D:\downloads\windows\utilities\divx\avisynth\plugins25\rainbow.avsi") mpeg2source("c:\dvdrips\escaflowne18\escaflowne18.d2v",cpu=6,iPP=true) crop(12,0,696,480) DeRainbow() Telecide(Post=true,blend=true) Decimate(cycle=5) awarpsharp(20,2,0.5,2) lanczosresize(640, 480) ----------------- Every time I load the avs file, it says msharpen has invalid arguments. I am using the latest one from Donald Graft's website. thanks for the reply. Quote:
12th November 2003, 09:40 | #18 | Link |
Retired AviSynth Dev ;)
The function above did not work. I fixed it and added a YUY2 version (much slower though), but with no chroma downsampling. I tweaked it a bit for best results on my current material. I also changed the blurs to MipSmooth.
function DeRainbow(clip org, int "thresh") { assert(org.isYV12(),"DeRainbow() requires YV12 input!") thresh = default(thresh, 10) org_u = utoy(org) org_v = vtoy(org) msharpen(org, threshold = thresh, mask=true) reduceby2() greyscale() uv = blur(1.5).levels(0,2.0,255,0,255, coring=false).blur(1.5).blur(1.5).levels(50,2.0,255,0,255, coring=false) filtered_u = org_u.mipsmooth(spatial=255, temporal=255, scenechange=3, show=false, method="strong", scalefactor=0.5) filtered_v = org_v.mipsmooth(spatial=255, temporal=255, scenechange=3, show=false, method="strong", scalefactor=0.5) u_final = MaskedMerge(org_u, filtered_u, uv) v_final = MaskedMerge(org_v, filtered_v, uv) return ytouv(u_final, v_final, org) } function DeRainbowYUY2(clip org, int "thresh") { assert(org.isyuy2(),"DeRainbowYUY2() requires YUY2 input!") thresh = default(thresh, 10) org_yv12 = org.converttoyv12() org_u = utoy(org).converttoyv12() org_v = vtoy(org).converttoyv12() msharpen(org_yv12, threshold = thresh, mask=true) bilinearresize(last.width/2, last.height) greyscale() uv = blur(1.5).levels(0,2.0,255,0,255, coring=false).blur(1.5).blur(1.5).levels(50,2.0,255,0,255, coring=false) filtered_u = org_u.mipsmooth(spatial=255, temporal=255, scenechange=3, show=false, method="superstrong", scalefactor=0.5) filtered_v = org_v.mipsmooth(spatial=255, temporal=255, scenechange=3, show=false, method="superstrong", scalefactor=0.5) u_final = MaskedMerge(org_u, filtered_u, uv).converttoyuy2() v_final = MaskedMerge(org_v, filtered_v, uv).converttoyuy2() return ytouv(u_final, v_final, org) } YV12: DeRainbow(int thresh) YUY2: DeRainbowYUY2(int thresh) Threshold is optional, and defaults to 10 (which is fairly strong). Required plugins: MipSmooth. Masktools. mSharpen.
Regards, sh0dan // VoxPod Last edited by sh0dan; 12th November 2003 at 20:56. |
12th November 2003, 18:50 | #20 | Link |
The void that is my self
mf hates me for sometimes using this, but you could try
BlindPP(cpu2="ooxxox", quant=31) BlindPP is part of MarcFD's MPEG2Dec3. Oh, and don't try this with non-anime stuff...
Kono yo ni aku ga aru to sureba sore wa hito no kokoro da. |
