Old 12th October 2003, 12:50   #1  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
MipSmooth 1.0 released
Hi folks!
I pulled myself together and implemented a new idea into MipSmooth, along with some bugfixes, speedup and adjustments. I'm quite happy with the filter now, and see it as a good replacement for smartsmooth, C3D and a supplement to VagueDenoiser.
Changelist:
v1.0
* Two new SuperMip modes. These mode reduces artifacts greatly.
* Massive speedup - this requires an AviSynth dated October 11th or later. This will give a >100% speedup.
* Scenechange values can be float values.
* Presets adjusted (preserves more detail in general).
* Fixed: Nasty bug that provided wrong thresholds on first mip. Quality improved!
* Fixed: Mips have a minimum size (16x16 pixels) to avoid resizer crashes.
* Added resolution checks to avoid crashes.
As it has hit v1.0 I now see it as "production ready", and with the latest cvs binary it is also quite speedy. It can also be used for a nice gaussian-like blur.
Download from: http://cultact-server.novi.dk/kpo/av...mipsmooth.html.
Feel free to post any experiences or problems here.
Regards, sh0dan // VoxPod
sh0dan is offline
Old 12th October 2003, 15:06   #2  |  Link
jorel
Posts: n/a
thanks sh0dan!
i was waiting for this great news!
Old 12th October 2003, 21:42   #3  |  Link
Chainmax
Huh?
Chainmax's Avatar
'tis some very nice news indeed. I have a question, though:
I don't get this. Isn't there only one version of Avisynth v2.52 (from 2003-05-31)?
Chainmax is offline
Old 12th October 2003, 22:09   #4  |  Link
Dreassica
Check Shodan's sig, u'll see a link to a site with CVS binaries. One of the files there is a test version released 11th october. get that for the speed improvement.
Dreassica is offline
Old 12th October 2003, 22:34   #5  |  Link
cipher
WOWOWOWOW!!
thx for your great work, sh0dan!
cipher is offline
Old 13th October 2003, 13:06   #6  |  Link
digitalman
This filter is unbelievable on low bitrate DVDs. I usually put two movies on one DVD+R, so the VBR is around 2000-2500Kbps. They almost look better than the original!!!
digitalman is offline
Old 13th October 2003, 14:13   #7  |  Link
Dams
Dams's Avatar
what do u mean by "low bitrate DVDs" ?
Dams
Dams is offline
Old 13th October 2003, 14:44   #8  |  Link
digitalman
Usually DVDs are over 4000Kbps Variable Bit Rate. Most people on this board consider a low bitrate around 2000Kbps VBR for DVDs.
Also, I would like to add that I tried the latest and greatest filter Vague Denoiser with the low bitrates, and Mipsmooth does a superior job.
Old 13th October 2003, 15:04   #9  |  Link
Dams
Dams's Avatar
oki
Dams
Dams is offline
Old 13th October 2003, 15:09   #10  |  Link
Wilbert
Just curious. Why is this filter any better than (say) convolution3d(preset="movieHQ") considering the source and target?
Wilbert is offline
Old 13th October 2003, 18:31   #11  |  Link
digitalman
(I should have added that I use UNDOT() before Mipsmooth)
There are less artifacts, which is noticeable when comparing to Convolution3d, and the picture looks a little sharper. I do not do any resizing or cropping. Maybe it is just my eyes and opinion, but it just looks better to me. Okay, maybe it doesn't look better than the original, but it still looks awesome. Could be the new SuperSoft setting that is used in Mipsmooth. Maybe at higher bitrates there is no difference between Convolution3d and Mipsmooth, since the source is already clean, but at the bitrate I use, I can see a difference. I am using CCE Basic, without any of their filtering settings enabled. I am also using PowerDVD 5 to view my MPEG-2 files, with default settings. Media Player Classic is giving me an issue when trying to move through a video, so I am not using that right now. Media Player 9.0 has some noise filtering settings enabled in the video section, so even if I disable them, I am still worried it is not giving me the true picture.
Old 15th October 2003, 13:47   #12  |  Link
known_03
digitalman I'm curious in what your settings for mipSmooth are?
I have converted a 3 hour movie and have notice artifacts in the face and background. I was hoping that mipSmooth could help limit these problems?
Anyway thanks for any help you can give me.
known_03 is offline
Old 16th October 2003, 12:23   #13  |  Link
digitalman
I just use Mipsmooth(preset="MovieHq"). You may try Mipsmooth(preset="MovieLQ")for older movie DVDs or independent films(which to me, always seem grainier than big budget movies).
Old 16th October 2003, 16:42   #14  |  Link
Chainmax
Huh?
Chainmax's Avatar
sh0dan, could you upload the "two downsizers, one upsizer" version here?
Chainmax is offline
Old 16th October 2003, 18:43   #15  |  Link
sh0dan
sh0dan's Avatar
If you are interested in a new suggestion you can try out:
SuperSubSample MipSmooth.
This version creates two mips using scalefactor, and one mip using 1/scalefactor instead of a third mip. This will create a mip at the inverse factor.
Very experimental - very untested.
sh0dan is offline
Old 17th October 2003, 03:08   #16  |  Link
known_03
I used the suggestion from digitalman -- undot(), then mipsmooth (moviehq) and results where very impressive indeed on a 3 hour movie (3000 ish) bitrate.
The arifacts that I was getting in the movie have smoothed to the point that they are not noticeable specially in in close ups of peoples faces and slow motion in the background.
Great job sh0dan!
known_03 is offline
Old 17th October 2003, 07:55   #17  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Looking very good, sh0dan I'm currently waiting for a capture with lots of rainbows so I can test how MipSmooth can get rid of them.
Does the filter work properly with interlaced material or do I have to do the SelectEven()-SelectOdd()-Interleave trick?
Boulder is offline
Old 17th October 2003, 08:35   #18  |  Link
Didée
Alas, I had no time for testing so far ("Fulltime Job" with Restore24), but I really look forward to test it out.
However, Sh0dan, two questions:
1. If a given pixel lies within the threshold in more than one mip, how do you decide from which mip to take the destination pixel? Or do you, in this case, average the destination from the according mips?
2. Spontaneous idea:
In case of working with a scalefactor>1, it could be worthful to additionally involve XSharpen. (Inspired by mf's SharpTools, and its brilliant results.)
I.e. instead of creating three mips
[source] * [scalefactor] * [scalefactor] * [scalefactor],
create
[source] * [scalefactor^3].XSharpen(0~255,255) / [scalefactor] / [scalefactor]
Of course, this would need quite some CPU cycles more. But I could imagine that this way even more smoothing through higher thresholds can be achieved, without smoothing away the sharpness - or perhaps even smoothing the noise while enhancing the definition.
What do you think?
- Didée
Didée is offline
Old 17th October 2003, 18:15   #19  |  Link
Chainmax
Huh?
Chainmax's Avatar
sh0dan: up factor = 1 / scalefactor doesn't reflect my suggestion.
For instance, if scalefactor was 0.6, then the two downsized "mipmaps" would be 60% and 36% of the original frame's size and the upsized "mipmap" would be ~167% of the original frame's size.
What I meant to suggest was that using a scalefactor of 0.6, the upsized "mipmap" should be 140% of the original frame's size, so as to be symmetrical (so to speak) with the first "mipmap" taking the original frame as reference point. So, according to my suggestion:
Up Factor = 2 - Scalefactor
Chainmax is offline
Old 17th October 2003, 19:50   #20  |  Link
Zarxrax
Zarxrax's Avatar
I think something funky is happening with this for me. I tried out the anime presets and they both were very destructive to the image and also increased filesize quite a bit.
Here's the original:
http://www4.ncsu.edu/~baclontz/mip-orig.png
And here's with AnimeHQ preset:
http://www4.ncsu.edu/~baclontz/mip-smooth.png
Is something wrong here?
Zarxrax is offline
