Old 6th October 2003, 23:23   #1  |  Link
RB
Retired
GPL command line M2V transcoder
recently, Metakine released a DVD transcoder similar to DVD2One etc. for Mac OS X. Their transcoder engine is based on the GPL'd mpeg2enc and libmpeg2 libraries and consequently, they provide the source code to their engine under GPL. You can read more about this (in German) at heise.de.
I've taken the liberty to port this to Win32 so it can be compiled with MSVC++ and does not require the ugly Cygwin environment. Will run on Win9x/ME/NT/2K/XP/2003. I really don't deserve much praise for this as the port was fairly easy
Download the port (source included] from http://home.t-online.de/home/340044300675/requant.zip
It's a command line program and takes as input an quantization factor and an input and output M2V file (MPEG2 elementary stream). For example:
requant 2.0 input.m2v output.m2v
This would transcode input.m2v to output.m2v, reducing average bitrate by a factor of 2.0 (note the factor is a floating point value). Quality is pretty good to my eyes, even at factor 2.0, speed is similar to DVD2One.
This post is only meant to put the ball in the game, please don't request any additional features/improvements from me . Anybody with enough spare time and programming skills please just take the source, obey to the GPL and take it to the next level(s). I'll post a note on this in the Development forum. Have fun!
RB is offline
Old 7th October 2003, 00:00   #2  |  Link
mrbass
thanks for the port to win32 RB.
So is int 21h Jan 2003 proposal now a reality?
http://forum.doom9.org/showthread.php?&threadid=44321
www.mrbass.org DVDShrink | DVD2DVD | DVDFAB | Mac guides
mrbass is offline
Old 7th October 2003, 00:08   #3  |  Link
int 21h
Still Laughing
int 21h's Avatar
I browsed that article a few days ago, but since I didn't know german, and the translation was bad.. I couldn't make heads or tails of it... I'll take a look at this now
int 21h is offline
Old 7th October 2003, 00:51   #4  |  Link
atreides93
I am in awe.
This 100k program transcodes mepg2 files??
atreides93 is offline
Old 7th October 2003, 05:51   #5  |  Link
CropsyX
I've only done a quick test but this looks extremely good so far. It's great to have a program that can work on plain mpeg2 video files. I do quite a bit of work with Digital TV captures and sometimes they're just a bit too big to fit on a DVD, this will be perfect for solving that problem.
Thanks!
CropsyX is offline
Old 7th October 2003, 07:33   #6  |  Link
RB
Retired
Originally posted by atreides93
I am in awe.
Sure . With a few compiler optimizations, you can get it down to 17k.
RB is offline
Old 7th October 2003, 17:29   #7  |  Link
int 21h
Still Laughing
int 21h's Avatar
I think I am going to work on making this oO C++, and perhaps making a shiny GUI for it...
First I have to finish a simple DCT compression project for work though.. I'll post progress as I make it.
int 21h is offline
Old 7th October 2003, 22:41   #8  |  Link
DVDRFreak
Fantastic !
Tested this little proggie on my favorite test subject NARC.
Wanted to decrease with the same value as recode and shrink so calculated 71% - factor 1.41.
Speed: 10 and 23 seconds to transcode (3.5x as fast as shrink or recode).
Compliancy of MPEG2 stream is no problem. Could author it without any problem at all.
Used PowerDVD to watch the resulting DVD. I mus say the quality is for this movie very good (read much better the recode or shrink).
The first scene is amazing. Recode and Shrink would cause a lot of macro blocking (even visible when just watching the scene)) because of the high motion. This little tool causes almost no macro blocking at all (even when freezing the picture I could not detects any aditional macro blocks).
Will do some further testing on other movies but until now I am impressed with the speed and the quality.
Thanks a lot RB for porting this little proggie.
DVDRFreak is offline
Old 7th October 2003, 23:58   #9  |  Link
Rombaldi
MPEG Packet Picker
Thank GOODNESS! I've been hoping someone would do this!
Must give it a whirl...
Rombaldi is offline
Old 8th October 2003, 01:13   #10  |  Link
What do you people use to demux M2V from VOBs?
Guest is offline
Old 8th October 2003, 01:16   #11  |  Link
int 21h
Still Laughing
int 21h's Avatar
DVDDecrypter if its on DVD...
int 21h is offline
Old 8th October 2003, 07:01   #12  |  Link
RB
Retired
If the VOBs are already on your hard disk, use Vobedit or vStrip.
RB is offline
Old 8th October 2003, 10:19   #13  |  Link
zyzzle77
How to get it down to 17k?
@RB:
What compiler optimizations did you make to get it down to a paltry 17 kbyte? Can you make this version available to download? Would be much appreciated.
-z
zyzzle77 is offline
Old 8th October 2003, 11:21   #14  |  Link
RB
Retired
I only have MSVC++ Standard Edition which does not allow for any optimizations, but I also have the Windows DDK which comes with an own compiler that has several optimizations on by default. So I simply compiled it in the DDK build environment (yes, it can build user mode apps) and it came out at 17.5 kb. I'm attaching the executable to this message. This may probably not run on Win9x/ME.
RB is offline
Old 8th October 2003, 17:47   #15  |  Link
DVDRFreak
optimized for speed
Recompiled the source using VC6 enterprice edition at work. Used optimalization setting for speed and code generation set to pentium pro.
Testing new exe on AthlonXP 1900+ 1GB memory
Did some more testing:
Movie: Gangs of new york
Compression: 1.492538 (67%)
Transcode time RB exe: 15:17 min
Transcode time optimized VC6 for speed: 11:00 min
Quality: Very Good
Shrink and recode caused a jumping pixel effect in the last scene where the two guys are fighting. This little proggie did not.
Old 9th October 2003, 02:11   #16  |  Link
zyzzle77
What an excellent piece of work. In some cases, this even beats out Shrink in quality (eg, on R1 FIGHT CLUB and WEIRD SCIENCE. Elegant in utility yet very small code footprint...
RB: I couldn't download your 17.5 kb binary compile. Am I missing something, or did you upload it to another server or forget to include it as an attachment?
DVDRFreak:
Very interesting and promising results. Compiling with VC Enterprise edition & optimized for speed & P6 results in a 25% boost in speed! As I don't have Enterprise edition, could you also somehow make your optimized binary available for download?
Thank you both for such positive insight and promising results.
zyzzle77 is offline
Old 9th October 2003, 21:09   #17  |  Link
Rombaldi
MPEG Packet Picker
This is quite an AMAZING piece of work, I've been trying it out and not only is the quality quite execellent, but the speed is great. I had been archiving TV episodes that were 'just a little too big' to fit three on a disc, so I ended up authoring them and then Shrink/IC'ing them ... I swear that it seems to cut the process in half by shrinking them BEFORE authoring..
Should someone GUI'ify this.. I can think of two features that would be a blessing..
1) be able to specify the 'shrinkage' either in a percentage (that way you don't have to find a calculator all the time) and/or as a 'target file size' (let's say the file is 1546mb, you want a target file of 1400mb, let it calculate the proper shrink percentage).
2) what else... BATCH MODE! I've got a pile of files stacked up that I'll need to run thru this.. would be lovely to set an input/output/percentage (ie. an 'add to batch' button above) for a pile of files and then let it process them all...
no matter if anyone does or not... GREAT STUFF!!!!
Rombaldi is offline
Old 9th October 2003, 23:20   #18  |  Link
DVDRFreak
I modified my version so it will except a percentage as parameter. Works great and the speed/quality is also awsome. I have a new favorite tool to do movie only backups.
Just 64KB big and it compressed the matrix_reloaded i just did buy in 8:42 min.
Quality is asome. I do not see the difference between the original and the compressed version when playing. If I freeze frame I can find one or two macro blocks in the title scene.
imho better then recode or shrink for speed and aslo for quality.
Old 9th October 2003, 23:30   #19  |  Link
Rombaldi
MPEG Packet Picker
DVDRFreak...
how about letting us peons without programming skill at your modified version????
Rombaldi is offline
Old 9th October 2003, 23:37   #20  |  Link
DVDRFreak
DVDRFreak...
I do not have a FTP server to upload it to.
[IMG] code is Off
