Old 1st September 2003, 09:40   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Creating a Custom VOB With Multiple Blank Program Chains (PGCs)
Creating a Custom VOB With Multiple Blank PGCs
Courtesy of 2CL
UPDATE: September 1, 2003 Guide has been redone.
This is a sub guide that will be used in preparation for this guide, How To Completely Blank Out a Whole Multi-PGC TitleSet (Version 1).
_____________________________________
1. First you need a get a blank 15ms VOB clip. A lot of DVDs have them lying around in Titleset with only a single PGC. This VOB will already have a VOB-ID: 1 and Cell ID: 1.
Update Jan 22 2004:
We can now create our own NTSC and PAL VOBs using a free tool called BlankVOB, courtesy of Doom9 user jsoto. It's pretty easy to figure out. Here it is.
BlankVob.exe
VC++ Source Code
2. Create a empty folder and copy this decrypted blank VOB into this.
3. Rename it as VTS_01_001.VOB.
4. Before we go further, we need to inquire on the first VOB-IDs in all your multiple PGCs TitleSet. So open the IFO of the Titleset in question and go to VTS overview. You will have PGC_1 (program chain) , PGC_2 , and so forth. All we need to do is write down all the first [V/C Id: #/ #]. “V” is for VOB and “C” is for Cell. In a example multiple PGC, I had this
PGC_1 > 1/ 1
PGC_2 > 7/ 2
PGC_3 > 13/ 1
When you’re done with the documentation, let’s go to next step.
5. Since I have three PGCs, I’ll need 3 blank VOBs for this project. Just copy the blank VOB and rename accordingly twice. You should have VTS_01_001.VOB, VTS_01_002, and VTS_01_003.VOB present in your folder. VTS_01_001.VOB is will used as our PGC_1. Open this file in VOBedit 0.60
6. Changing Cell IDs
Now, by default, your three VOBs are configured with a VOB ID of 1 and a CELL ID of 1. We need to change that to reflect the what we have in Step 4. Here’s how to change them.
Open up one of the VOB, in question. In the left window , under LBA column, click on…
000000 [Navigation Pack] [VOB: #] [CELL…
Your right window will now have data showing. Ensure that check boxes below are not checked and by default, they shouldn’t be. Under LBA Contents Data column, you will have a “VOB ID” and “Cell ID” data in your [DSI Stream] section. To change the ID values, double left click on line and input the required number and press OK to set. VOBedit does not automatically refresh the screen to display changes but if you click on 000000, under LBA column again, it will. Note: Your changes are already saved by pressing OK in this step.
7. Join CellVob files
We now should have these three files in our folder.
VTS_01_001.VOB
VTS_01_002.VOB
VTS_01_003.VOB
At the top left, click on Edit and then Join CellVob files
8. Select VTS_01_001.VOB and save your filename the same as your Titleset VOB in question. Since we are going to replace VTS_02_1.VOB and following VOBs, save your filename as the first original VOB, “VTS_02_1.VOB”.
9. Verifying
For verification of you new VOB’s V/C IDs, open up your VTS_02_1.VOB in VOBedit and check it out. I hope everything is correct or else you have to start over again.
That’s it. You just created your custom VOB which will replace your original TitleSet VOBs.
2COOL
Old 11th February 2004, 03:00   #2  |  Link
mikewillnot
Another nice piece of work. Question:
I have a VTS set with single VOB, with 3 PGC's, but the start of each PGC is the same for the second and the third: 1/1, 2/1, 2/1. Should this be accommodated differently, do you think?
"Education alone is not enough. The world is full of educated derelicts."
..... Calvin Coolidge
mikewillnot is offline   Reply With Quote
Old 11th February 2004, 03:07   #3  |  Link
2COOL
2COOL's Avatar
As long as the V/C Id assignments don't change in your IFOs, you don't need to have multiple VOBs of VOB ID 2 and Cell ID 1. Did I answer your question?
2COOL
Old 11th February 2004, 03:28   #4  |  Link
mikewillnot
Most definitely. Plus, I went ahead and tried it, and it worked fine -- as your explanation indicates.
Regards, O cool one.
Old 11th February 2004, 05:16   #5  |  Link
2COOL
2COOL's Avatar
exCLent!
2COOL
