Old 1st September 2003, 05:18   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
How To Blank Out a TitleSet with a Single Program Chain Guide (Optimized for Speed)
How To Blank Out a TitleSet with a Single Program Chain (Optimized)
Courtesy of 2CL
This is almost a lot like my first version, which has now been replaced with this guide in this thread, but with 2 less steps. All I changed in this guide was our Destination Directory in Step 3. Instead of using another folder to store you new VOBs, I had you just strip the files into the same directory your movie is also in.
Like the title says, this guide is only for TitleSets that have only one Program Chain (PGC) in them.
It’s so quick and easy to learn! Before we get to the steps, there’s something I need for you to know about.
Every VOB has to start with a VOB ID:1 and a CELL ID: 1 right? With that said, a 15 frame blank VOB that the only thing in a TitleSet has a VOB ID:1 and CELL ID: 1. If you can't find one, here's a ZIP, provided by me, courtesy of MackemX. There's a file inside named 1_BLANK_CELL.VOB. Download it and unzip.
Jan 22, 2004 Update: If you need to create a single NTSC/PAL VOB with VOB ID 1 and Cell ID 1 then download this free VOB creating tool BlankVOB, courtesy of jsoto.
Jan 23, 2004 Update: New Step 3 has been added to give you the option of keeping one cell or keep all cells blank. Default recommendation is still to keep only Cell_1 at VOB ID:1 and Cell ID: 1. I recently came across a single PGC Title that didn't have it's first Cell set to VOB ID:1 and Cell ID: 1. It was this attention that I have updated the guide.
Here’s what the 1_BLANK_CELL.VOB looks like below in Figure 1 when looking into it’s IFO / VTS Overview in IFOedit.
Figure 1.
__________________________
PGC_1 (program chain): [Title(TTN): 1] [00:00:00.15 / 30 fps] (Programs: 1) (Cells: 1)
..........................................................................(uses VOB-IDs: 1)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: 00:00:00.15 / 30 fps
Notice [V/C Id: 1/ 1]? That’s [VOB/CELL Id: 1/ 1] if you didn't figure it out.
In Figure 2, here are the files and sizes of our DVD that we are going to work on. In this DVD, I’m going to shrink Titleset 2 (VTS_02), which is our movie, for the fun of it.
Figure 2.
VIDEO_TS.BUP .......26 KB
VIDEO_TS.IFO .......26 KB
VIDEO_TS.VOB ....1,056 KB
VTS_01_0.BUP .......32 KB
VTS_01_0.IFO .......32 KB
VTS_01_0.VOB ......236 KB
VTS_01_1.VOB ....7,984 KB
VTS_02_0.BUP .......74 KB
VTS_02_0.IFO .......74 KB
VTS_02_0.VOB ..107,878 KB
VTS_02_1.VOB 1,048,544 KB
VTS_02_2.VOB 1,048,544 KB
VTS_02_3.VOB 1,048,544 KB
VTS_02_4.VOB 1,048,544 KB
VTS_02_5.VOB 1,048,544 KB
VTS_02_6.VOB 1,000,003 KB
Here’s a trim down version (Figure 3.) of this PGC_1 in VTS_02_0.IFO / VTS overview. Notice that we also have a starting [V/C Id: 1/ 1] existing.
Figure 3.
PGC_1 (program chain): [Title(TTN): 1] [01:14:27.16 / 30 fps] (Programs: 14) (Cells: 21)
.......................................................................(uses VOB-IDs: 1,2)
[Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: 00:00:23.00 / 30 fps
................[Cell 02] [V/C Id: 1/ 2] : time: 00:02:58.17 / 30 fps
[Ch 02] [Pg 02] [Cell 03] [V/C Id: 1/ 3] : time: 00:02:32.19 / 30 fps
[Ch 03] [Pg 03] [Cell 04] [V/C Id: 1/ 4] : time: 00:01:36.29 / 30 fps
[Ch 14] [Pg 14] [Cell 20] [V/C Id: 2/11] : time: 00:02:11.21 / 30 fps
................[Cell 21] [V/C Id: 2/12] : time: 00:01:17.15 / 30 fps
We want it to look like Figure 1 so let’s start some action.
_____________________________________________________
1. Delete all our TitleSet VOBs, VTS_02_1.VOB to VTS_02_06.VOB (Figure 2), or you can drag them to another folder if you want.
2. Copy our blank VOB into our movie folder and rename it as VTS_02_1.VOB. You also had the option to rename it when using BlankVOB. (Figure 4)
Figure 4.
VTS_02_1.VOB .......10 KB
3. Browse to our VTS_02_0.IFO / VTS_PGCITI / VTS_PGC_1 in IFOedit.Scroll down to the bottom section, Cell Position in VOB. We need to only edit Cell_1 if you have more cells in this PGC. So again, Double click on each line and change both values to 1. This is to reflect the changes you done above.
Cell Position in VOB:
Cell_1: has VOB ID.....1
Cell_1: has Cell ID....1
Optional: If you want to keep all your cells and have them referenced to your inserted blank cell VOB, you can do the same for every cell in this table. Keep in mind, if you are going to do this, each cell will be played and it will take a little longer for title bypassing to occur. Just tell yourself which is quicker...one blank cell or 2?
For example...
Cell_2: has VOB ID.....1
Cell_2: has Cell ID....1
Cell_3: has VOB ID.....1
Cell_3: has Cell ID....1
Cell_20: has VOB ID....1
Cell_20: has Cell ID...1
4. Click on “VOB Extras” button and have these settings checked. Click OK when done.
Options
X Strip Streams’
X Correct Vob-Unit (Navigation Pack) pointers in VOB-files
X Correct original IFO files
VOB Expert Options
X Remove P-UOps
X Remove Macrovision
X Adjust Vob-Unit pointers
X Adjust Audio/Subp point.
File/Directory Paths
Destination directory: (browse to our “NEW” folder) See Note
Remember to uncheck your “AutoCopy Menu-files to destination”
Note: If IFOedit says to select a different directory, then create another directory and browse to that.
5. Uncheck all streams and “Correct IFO tables” should be checked by default. Click “Strip it” button to start process.
6. Wow! That was quick! Anyways, you’ll now have a message box saying “Finishing correcting VOBU pointers!”. Click OK.
7. Close IFOedit
8. If you had a different directory for your new files (Step 3) then select all your files in this directory and drag them over into your original directory. Click "Yes to All".
9. Open IFOedit and select any IFO. Press your “Get VTS sectors” button. Click Yes and OK.
10. Press your DVD Play button to test out our new product. You should see the Title you have now stripped.
2COOL
Old 1st September 2003, 09:59   #2  |  Link
maa
Nice guide 2cool, wouldn't it have been better to keep the film though ?
maa is offline   Reply With Quote
Old 1st September 2003, 10:02   #3  |  Link
2COOL
2COOL's Avatar
I wanted to use any example so that's why I wrote this in the guide.
2COOL
Old 1st September 2003, 10:06   #4  |  Link
maa
Hey - I was just teasing Its great work - keep it up!
Thanks again.
Old 1st September 2003, 22:54   #5  |  Link
2COOL
2COOL's Avatar
Sometimes I wonder where I find the time to do any backups? Well, at least I can watch/test my movies and write out a learning guide at the same time.
2COOL
Old 2nd September 2003, 09:39   #6  |  Link
maa
I know - its all fun to do but I rarely watch a film twice - just like to get rid of the rubish.
Old 4th September 2003, 06:54   #7  |  Link
2COOL
2COOL's Avatar
Has anyone used this guide with success?
2COOL
Old 4th September 2003, 17:08   #8  |  Link
voo_doo99
Should I say 'just fabulous' one more time . Yes it works very well, my LoTG . I used this guide to build my BONUS backup disc where I replaced the whole movie with a blank clip [very applicable here as most main movie titleset has only 1 PGC]. The benefit was the backup disc ran smooth and no more need for button deletion or bypass codes, yayh!
voo_doo99 is offline   Reply With Quote
Old 7th September 2003, 08:45   #9  |  Link
2COOL
2COOL's Avatar
Original guide posted has been optimized and replaced by a newer guide with 2 less steps. See first post in this thread.
It just got quicker to get rid of your single Title PGC.
2COOL
Old 9th September 2003, 06:28   #10  |  Link
^Smoochie
When I set my destination directory to the directory where my movie is, it says that it cannot overwright the original VOB files, please select a different directory.
^Smoochie is offline   Reply With Quote
Old 9th September 2003, 08:48   #11  |  Link
2COOL
2COOL's Avatar
Sorry about that! Step 3 has been amended.
2COOL
Old 19th September 2003, 01:33   #12  |  Link
yamyam
Great work 2COOL, ive learned from this guide how to blank out a single PGC VOB but how could i do this to a single PGC menu file such as VIDEO_TS.VOB or VTS_01_0.VOB.
yamyam is offline   Reply With Quote
Old 19th September 2003, 01:46   #13  |  Link
2COOL
2COOL's Avatar
It should be the same concept with just setting the VOB IDs and Cell IDs in the VTS_*_0.IFO / VTSM_C_ADT to V/C : 1 / 1. You would replace the menu VOB with a single cell blank VOB and then correct the IFO by mock-stripping VOB-IDs in Menu Extras.
Most of the time, you can delete playback on the menus in your Menu Language Unit and then stripping out the VOB-IDs in Menu Extras.
2COOL
Old 2nd August 2004, 04:19   #14  |  Link
bobkoure
deleted message
finally figured out what I was doing wrong (nevermind!)
bobkoure is offline   Reply With Quote
