Old 30th July 2003, 06:39   #1  |  Link
wata
Anamorphic encode rv9 convert mkv doesn't play
both latest realmedia & Matroska splitter install
no video, sound play fine
popup from mpc:
Stream 0
Media Type 0:
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: FOURCC GUID {30345652-0000-0010-8000-00AA00389B71}
formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 0
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 146
VIDEOINFOHEADER:
rcSource: (0,0)-(0,0)
rcTarget: (0,0)-(0,0)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 333332
BITMAPINFOHEADER:
biSize: 40
biWidth: 0
biHeight: 864
biPlanes: 0
biBitCount: 0
biCompression: RV40
biSizeImage: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
wata is offline   Reply With Quote
Old 30th July 2003, 08:33   #2  |  Link
nah
RV9 Convaincu !
yes, I have the 'same' pb.
posted :
I've tested RealMediaSplitter 1.0.0.4 and MatroskaMuxer 1.0.0.6 and MPC doesn't play the mkv.
It worked well with the RealMediaSplitter 1.0.0.3
UteamVision
nah is offline   Reply With Quote
Old 30th July 2003, 11:18   #3  |  Link
wata
RealMediaSplitter 1.0.0.3 doesn't work for me as well
Old 30th July 2003, 12:11   #4  |  Link
Sirber
retired developer
Sirber's Avatar
what if you use RealMedia instead of DirectShow in MPC for RealVideo?
Detritus Software
Sirber is offline   Reply With Quote
Old 30th July 2003, 12:58   #5  |  Link
wata
i would like to use mkv so that it can display dvobsub subs
the special renderer for subtitling does work for me cause using it cause 100% cpu load.
Old 30th July 2003, 13:58   #6  |  Link
Sirber
retired developer
Sirber's Avatar
I mean in Format selection, "RealMedia" or "DirectShow" for RealVideo and RealAudio.
Detritus Software
Old 30th July 2003, 18:07   #7  |  Link
karl_lillevold
karl_lillevold's Avatar
Why anamorphic RV9 in mkv does not show video is problably something Gabest can answer. Perhaps you should try to ping him over in this thread.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 31st July 2003, 04:59   #8  |  Link
dillee1
I dun have problem with anamorphic RV9 in mkv .
Audio is not rendered, however.... wtf
dillee1 is offline   Reply With Quote
Old 3rd August 2003, 18:26   #9  |  Link
Sirber
retired developer
Sirber's Avatar
Same problem:
Stream 0
Media Type 0:
AM_MEDIA_TYPE:
lSampleSize: 1
cbFormat: 146
VIDEOINFOHEADER:
dwBitRate: 0
dwBitErrorRate: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 0
biHeight: 848
biPlanes: 0
biBitCount: 0
biCompression: RV40
biSizeImage: 0
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
using internal MPC splitters
Detritus Software
Old 4th August 2003, 15:48   #10  |  Link
dillee1
tested a few more old clips.
Some got video no audio
Some got audio no video
some got none
some got both.
interesting.....
Old 4th August 2003, 16:43   #11  |  Link
gabest
gabest's Avatar
Could you check their fourcc or waveformat tag when mpc reports them? (and for that you have to change the rendering of real media files to be done through dshow at options/formats)
gabest.org
gabest is offline   Reply With Quote
Old 4th August 2003, 23:05   #12  |  Link
Sirber
retired developer
Sirber's Avatar
Some more informations...
+ EBML head
+ Segment
|+ Seek head (subentries will be skipped)
|+ EbmlVoid
|+ Segment information
| + Timecode scale: 1000000
| + Duration: 5914.470s
| + Date: Sun Aug 03 13:15:57 2003 UTC
| + Muxing application: DirectShow Matroska Muxer
|+ Segment tracks
| + A track
| + Track number: 1
| + Track UID: 38
| + Track type: video
| + MinCache: 1
| + MaxCache: 1
| + Codec ID: V_REAL/RV40
| + CodecPrivate, length 58
| + Default duration: 33.333ms (30.000 fps for a video track)
| + Video track
| + Pixel width: 0
| + Pixel height: 848
| + Frame rate: 30.000031
| + A track
| + Track number: 2
| + Track UID: 7719
| + Track type: audio
| + MinCache: 1
| + MaxCache: 1
| + Codec ID: A_REAL/COOK
| + CodecPrivate, length 94
| + Audio track
| + Sampling frequency: 44100.000000
| + Channels: 2
| + Bit depth: 16
| + A track
| + Track number: 3
| + Track UID: 21238
| + Track type: subtitles
| + MinCache: 1
| + MaxCache: 1
| + Codec ID: S_TEXT/ASCII
|+ Cluster
When trying to extract:
C:\Documents and Settings\sirber\Bureau\Helix Factory\bin\mkv>mkvextract.exe tra
cks Solaris.mkv 1:vid.rmvb
Warning: Track ID 1 is missing some critical information. Skipping track.
Nothing to do. Exiting.
cks Solaris.mkv 2:aud.rm
Warning: Unsupported CodecID 'A_REAL/COOK' for ID 2. Skipping track.
cks Solaris.mkv 3:sub.srt
Warning: Unsupported CodecID 'S_TEXT/ASCII' for ID 3. Skipping track.
This infos is from a "normal" working anamorphic MKV file:
+ EBML head
+ Segment
|+ EbmlVoid
| + Muxing application: libebml v0.5.0 + libmatroska v0.5.0
| + Writing application: mkvmerge v0.6.0
| + Duration: 20.547s
| + Date: Mon Aug 04 22:10:29 2003 UTC
| + Segment UID: 0x83 0xd3 0x9b 0x0f 0xfc 0xde 0x24 0x43 0x88 0x05 0x8f 0xb8 0xf
6 0x4f 0xce 0x04
|+ Segment tracks
| + A track
| + Track number: 1
| + Track UID: 2574048674
| + Track type: audio
| + Audio track
| + Channels: 2
| + Bit depth: 16
| + A track
| + Track number: 2
| + Track UID: 237765970
| + Track type: video
| + MinCache: 1
| + CodecPrivate, length 34
| + MaxCache: 1
| + Default duration: 41.708ms (23.976 fps for a video track)
| + Video track
| + Pixel width: 856
| + Pixel height: 364
| + Display height: 364
| + Display width: 856
| + Lacing flag: 0
|+ Cluster
Detritus Software
Old 4th August 2003, 23:26   #13  |  Link
gabest
gabest's Avatar
What did you use to create this file? S_TEXT/ASCII isn't supposed to be used anymore. I could only think you connected ogm's subtitle parser or used a very old build of matroskamuxer.
gabest.org
Old 4th August 2003, 23:26   #14  |  Link
karl_lillevold
i just tried the latest mkvmerge tool instead of Dark-Cracker's
directshow wrapper, and it seems to create a 'good' anamorphic RV9
file.
the atest.mkv file, as created by DC's dshow wrapper:
| + Video track
| + Pixel width: 0
| + Pixel height: 856
[mkvinfo]
with mkvmerge:
| + Video track
| + Pixel width: 856
| + Pixel height: 364
So it seems the directshow wrapper method does not work for anamorphic
files. The mkvmerge'd file plays video, but stutters and freezes a few times.
Old 4th August 2003, 23:28   #15  |  Link
Sirber
retired developer
Sirber's Avatar
It's SRT format, and IIRC I used your subtitle renderer...
Detritus Software
Old 4th August 2003, 23:42   #16  |  Link
gabest
gabest's Avatar
Sirber: Are you sure you are using the latest muxer? Could you check the version number at the file properies in explorer?
karl_lillevold: mkvmerge's demuxer may not recognize those double packed frame types, try to compare the frame listing of rmeditor with what you get in the codec through the dshow filter.
gabest.org
Old 4th August 2003, 23:49   #17  |  Link
Sirber
retired developer
Sirber's Avatar
MatroskaMuxer.ax: 1.0.0.6
subtitlesource.ax: 1.0.0.1
Detritus Software
Old 4th August 2003, 23:53   #18  |  Link
karl_lillevold
Without actually checking, that sounds very likely, since the freezes are 100% deterministic and probably a result of such an error in mkvmerge's demuxer.
Old 5th August 2003, 00:08   #19  |  Link
karl_lillevold
so I did check, and the mkvmerge'd file has a large number of missing frames, most likely as a result of the demuxer problem Gabest mentioned. This means most files converted from rmvb to mkv using mkvmerge will have missing frames, so this is not a recommended method until this problem is fixed in mkvmerge's demuxer.
Old 5th August 2003, 08:15   #20  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Definitely likely that mkvmerge does not handle some streams correctly. Can someone please provide me with (preferably small) sample files which show this behaviour?
I'll ask Gabest how to handle those thingies.
Latest MKVToolNix is v63.0.0
Mosu is offline   Reply With Quote
