Thread Tools Display Modes
Old 26th July 2003, 02:16   #1  |  Link
Gej
DivX guy
Gej's Avatar
DivX Manihi Codec Beta
DivX Manihi Codec Beta is up at DivX.com
http://www.divx.com/divx/windows/beta/
Welcome to the new codec beta release. The release is full of new features that will improve the overall quality of your digital video experience. A list of new features and fixes can be found in the "What's New" section below. The Quality Assurance (QA) period will run for about three weeks starting 2003-07-25. All the results must be e-mailed back to us by 2003-08-15 at the latest. Intermediate results are welcome. Please submit your bugs through our bug submission form .You can discuss your bugs and feedback with the DivX community in the DivX Beta Release Feedback Forum.
What's New:
* High Quality encoding mode
- Different motion estimation criteria
- Rate distortion algorithm
*High Quality psychovisual mode
- Texture cortex masking and Rate distortion algorithm
- Hybrid mode (Texture cortex masking)
* High Quality B frame mode
- The motion estimation for B frame has been improved
- Quantization modulation is changed
* Feedback mode
- Allows visual feedback during encoding
* Decoder rearchitecture
- Decoder is 10 to 30% faster on all CPU platforms
- Decoder supports auto-postprocessing
* Encoder GUI
- The codec GUI has been redesigned to ease accessibility and simplify overall usage.
- RC modes: Enabled complexity vector logfile, and experimental texture / motion modulation switch
- RC to support real time control through API support
- I frame insertion forced through API support
Fixed:
* Fix for quantizer overshoot when over bitrate following a transition to a complex scene
* Change in quantizer from one frame to next limited to change in ideal quantizer or +-2
* Fix for a bug in RGB32 to YUV conversion on P4
* A minor issue with Multiple CPU configuration
* Fix for broken B-frames ('P' in FrameSpec was occasionally producing an I frame)
* 3.11 Compatibility improved (NO mismatach at all on ALL the clips tested, more than 60 hours of contents!)
* RC VBV enforce "3 sec" max bitrate
Bugfixes, performance improvements in nth-pass strategy planning
* MV reuse is functional
* Qpel, B frames and slow and slowest mode doesn't generate artifacts anymore
Gej is offline   Reply With Quote
Old 26th July 2003, 11:53   #2  |  Link
cordraconis
Lurker by lack of time
d**n, I was looking around on your website becouse I have some Probs with Dr.Divx, and I just saw your new béta.
It seems you were faster than me to report it to Doom9, héhé.
"the Word Wide Web is a web like any other: either you get caught in it, or you learn to walk on it like a spider. In the future, I'd like to be somewhere on top of the food chain. " -- Cordraconis
cordraconis is offline   Reply With Quote
Old 26th July 2003, 12:50   #3  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
very nice!
when I get my new dvd-rom drive next week I will be testing this thing out
well I tested it right quick on some avi sources, but that isn't very accurate
SiXXGuNNZ is offline   Reply With Quote
Old 26th July 2003, 20:54   #4  |  Link
The People's Elbow
Addicted to ANiME!
The People's Elbow's Avatar
In VDubs compression dialogue it still says "kauehi" though codec seems to have changed - at least the settings did.
Is it me or a little bug in the frontend?
greetz Elbow!
encoding @: AMD K7-2000+ XP 1,66 GHz - MSI MS-6380 - 512MB DDR-Ram @ 133(266)MHz FSB - WinXP SP1
...and that's the bottom line... ;)
The People's Elbow is offline   Reply With Quote
Old 26th July 2003, 22:45   #5  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
greetz Elbow!
I dunno ay, mine says DivX Pro Manihi Codec
Old 26th July 2003, 23:28   #6  |  Link
Animaniac
Animaniac's Avatar
greetz Elbow!
I needed to uninstall Kauehi before installing Manihi, for it to work correctly.
Animaniac is offline   Reply With Quote
Old 27th July 2003, 00:36   #7  |  Link
rozemab
Is it possible to install Manihi without messing up my Divx Pro install?
I would like to try it out with vdub etc. and not affect my Dr Divx configuration.
rozemab is offline   Reply With Quote
Old 27th July 2003, 05:03   #8  |  Link
Gej
DivX guy
Gej's Avatar
You can install Manihi safely, it'll not impact DrDivX, as it use it's own private encoder.
Old 27th July 2003, 08:38   #9  |  Link
saeed
I have just downloaded and installed manihi. but what I got was kauehi in the decoder and the encoder. The previous version on my system was 5.03 not kauehi. the reamde file is for manihi, though.
The file size is 1,912,749 bytes. Can someone confirm that.
saeed is offline   Reply With Quote
Old 27th July 2003, 11:29   #10  |  Link
The People's Elbow
Addicted to ANiME!
I had to delete the divx.dll manually to get manihi working, maybe my system is messed up a bit
This new overlay dialog is a pretty thing, but for job encoding it's a disadvantage, because its always showing the encoded output which slows down encoding while I'm asleep... can that be disabled?
greetz elbow!
Old 27th July 2003, 11:33   #11  |  Link
pluonk
I installed Manihi today and am now encoding a movie with VDubmod (which btw correctly identifies as "DivX Pro Manihi Codec"). It runs extremely slowly, ~7fps, while 5.05 and previous encoded at 15-20fps (for the same type of movie, which is PAL interlaced using FieldDeinterlace). The settings for Manihi are the defaults (perfomance/quality: standard, psychovisual enh: slow, -Qpel, +GMC, +Bframes). Has anybody tested it or know what's wrong?
Btw, I closed the overlay dialog, hoping that it was to blame for the slow performance, but it didn't help at all. If I choose to keep this codec, does anybody know how to prevent this dialog from popping up each time VDubmod runs?
pluonk is offline   Reply With Quote
Old 27th July 2003, 12:28   #12  |  Link
saeed
To disable the feedback window you have to click the settings bottun next to OK bottun and check the option.
I guess it is slower because of the new psychovisual enhancement and the motion estimation in B-frames.
Old 27th July 2003, 15:18   #13  |  Link
SeeMoreDigital
Life looks better in HDTV
SeeMoreDigital's Avatar
Well here we are again with another DivX test codec. Great fun!
Granted the decoder will be slower if psy etc is used. But if you disable the feedback window the encoder should run approx twice as fast.
I'm currently encoding Tomb Raider 1 (PAL 96min) in anamorphic (720x576) with video at 913kbps and audio at 96kbps. So I should have some results in a few hours.
As per normal I'll compare this new encode against previous encode versions such as DivXPro5.0.5 & Kauehi. And view the output on my TV via the Xcard.
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear |
Old 27th July 2003, 18:55   #14  |  Link
Fr4nz
Also the GMC active slows down the encoding ALOT.
Try to put psyco on fast and disable GMC..it should be really faster.
Fr4nz is offline   Reply With Quote
Old 27th July 2003, 20:36   #15  |  Link
SeeMoreDigital
My first test with DivX Manihi is complete.
To be honest I can't see any difference between this version and Kauehi. I will generate a lower bitrate encode tomorrow. Maybe (I hope) this will reveal some more positive results.
All is not lost though as I do prefer the new interface.
Anybody else like this?
Old 27th July 2003, 20:40   #16  |  Link
Fr4nz
I also tried Manihi at 1000kbps and I can't see any difference with Kauehi (same options enabled). Oh I have to say also that I find Kauehi faster, so I think I'll stick with it.
Old 27th July 2003, 23:03   #17  |  Link
Morbo
I Will Destroy You!!
Morbo's Avatar
The overlay window
Overlay window is ultra cool
Looks like a nice release overall again gej..
Cheers!!
Jesus Saves,but Buddah makes incremental backups!
Morbo is offline   Reply With Quote
Old 28th July 2003, 04:07   #18  |  Link
silver_cpu
I have an interesting problem...
Ever since I upgraded (from Kauehi), whenever I try to encode through VirtualDubMod , it gives me this error:
VideoSourceAVI error: the source image format is not acceptable. (error code -2)
Anyone know what this means? I've tried different settings, as well as changing the resolution (thought I might have hit a bad one), but nothing seems to help. I'm trying to encode one of the pieces in "the animatrix," can anyone describe what VDM's problem is, and how to fix it?
EDIT: Well, it seems that this is a system-wide problem. I tried out Xvid and Divx3 just in case it was truely DivX5 that had caused the problem, that didn't fix it. Vor some reason, VDubMod is rejecting the video stream. I've tried uninstalling and reinstalling the GKnot rip-pack (0.28.5, with 0.28.5.2 patch), and un-installing DivX (even running a registry cleaner to catch stray reg entries), reinstalling with the retail 5.0.5 codec (none of the betas). Nothing works It keeps giving me the same error, but I can't seem to locate that error when I search the boards... Maybe I'll have luck and figure out what it is soon.
silver_cpu is offline   Reply With Quote
Old 28th July 2003, 05:59   #19  |  Link
LordIntruder
Look here, it may solve your problem:
http://forum.doom9.org/showthread.php?s=&threadid=51906
LordIntruder is offline   Reply With Quote
Old 28th July 2003, 07:33   #20  |  Link
silver_cpu
Thank you so much! It worked perfectly
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
