Old 24th July 2003, 13:49   #1  |  Link
Shalcker
Programmer
Shalcker's Avatar
CompareYV12
Since there seems to be no progress in that direction and widely used "ConvertToYUY2().Compare" blurs chroma resulting in "better" overall PSNR (which can be misleading) I created this filter - Compare for clips in YV12 colorspace.
Dll and source code (with SSE optimizations) can be downloaded here
No On-Screen Display and no graph at the moment, only logfile and debug output supported.
While creating this I noted small bug in current AviSynth Compare function
  if (channels[0] == 0) {
    if (vi.IsRGB32() || vi.IsRGB24())
      channels = "RGB";
    else if (vi.IsYUY2())
      channels = "YUV";
    else env->ThrowError("Compare: clips have unknown format");
when you set channels to any non-empty value Compare will accept ANY input colorspace...
Shalcker is offline   Reply With Quote
Old 24th July 2003, 14:42   #2  |  Link
trbarry
trbarry's Avatar
Shalcker -
Thanks. That should be useful. I'll check that out.
I've also been using ConvertToYUY2().Compare() but I knew it probably changed the results a bit.
- Tom
My video filters (still) at www.trbarry.com.
trbarry is offline   Reply With Quote
Old 25th July 2003, 12:46   #3  |  Link
temporance
Nice work, Shalcker
Could you add a computation of Overall PSNR? It produces more reliable results than a simple mean average PSNR.
It's already done by the regular Compare() (see latest avisynth CVS). There are some more details on this thread:
temporance is offline   Reply With Quote
Old 25th July 2003, 13:17   #4  |  Link
Shalcker
Programmer
Shalcker's Avatar
Originally posted by temporance
Nice work, Shalcker
Actually that "average" PSNR in my plugin is computed from Mean Square Error sum as:
Average PSNR = 10*log10 (255*255*FramesProcessed/ SumValues[Channel][_MSE])
so it is the "overall" PSNR you're reffering to;
since Mean Square Error (MSE) = (Pixel Error^2)/(bytecount), and SumValues is array containing sum of all values from processed frames.
Old 25th July 2003, 14:03   #5  |  Link
temporance
nice
I read the source too quickly!
Old 25th July 2003, 15:30   #6  |  Link
CruNcher
CruNcher's Avatar
great work but unfortunately i cant use compareyv12, this is what im getting with mplayer 6.4 and mediaplayer classic @ the end of a compare
name = "none-2pass.avi"
original=avisource("low_motion-original.avi")
modified=avisource(name)
compareyv12(original,modified, "", name+".psnr.log", false)
Result :
Comparing channel(s)
           Mean               Max    Max
         Absolute     Mean    Pos.   Neg.
 Frame     Dev.       Dev.    Dev.   Dev.  PSNR (dB) Avg. PSNR
     2   -1.#IND    -1.#IND     0     +0     0.0000    1.#INF
     3   -1.#IND    -1.#IND     0     +0     0.0000    1.#INF
     4   -1.#IND    -1.#IND     0     +0     0.0000    1.#INF
     5   -1.#IND    -1.#IND     0     +0     0.0000    1.#INF
           Mean               Max    Max
any idea what could cause this, the plugin is in the plugins dir and gets autoloaded a normal compare with Converttoyuy2 works
avisynth is 2.5.2 17.06.03 build
system: p4 1.8
os: windows xp pro
directx: 9.0b
originalclip = vble (avisource)
modified= Xvid Devapi4 rendered thtough xvid.dll (avisource)
It is about Time
Old 25th July 2003, 17:06   #7  |  Link
Shalcker
Programmer
Shalcker's Avatar
[CODE]
Result :
Empty channels... weird... oh, yes, i forgotten to check channels string for zero length. I'll fix this shortly, it only requires one line of code.
Just set channels to "YUV" instead of "" and bug should be gone. Or try
compareyv12(original,modified, logfile=name+".psnr.log")
Edit: Fixed. Updated version (v1.01) available at the same URL here
Old 7th August 2003, 18:48   #8  |  Link
CruNcher
CruNcher's Avatar
@Shalcker
there musst be still a problem somewhere
Total frames processed: 2520
                                Minimum   Average   Maximum
  Y: Mean Absolute Deviation:    0.0000    1.9301    5.0150
  U: Mean Absolute Deviation:    0.0000    1.3147    3.7740
  V: Mean Absolute Deviation:    0.0000    1.1159    4.2228
Sum: Mean Absolute Deviation:    0.0000    1.6919    4.5222
  Y:          Mean Deviation:   -2.8939   -0.0665    1.4344
  U:          Mean Deviation:   -2.0027   -0.1061    1.9306
  V:          Mean Deviation:   -0.9144   -0.0271    1.7173
Sum:          Mean Deviation:   -1.9241   -0.0665    1.2777
  Y:       Mean Square Error:    0.0000   10.3204   68.5512
  U:       Mean Square Error:    0.0000    4.7763   36.3066
  V:       Mean Square Error:    0.0000    3.7386   42.8451
Sum:       Mean Square Error:    0.0000    8.2995   52.7642
  Y:  Root Mean Square Error:    0.0000    2.9492    8.2796
  U:  Root Mean Square Error:    0.0048    1.9763    6.0255
  V:  Root Mean Square Error:    0.0000    1.7278    6.5456
Sum:  Root Mean Square Error:    0.0020    2.6554    7.2639
  Y:                    PSNR:   29.7707   37.9938    1.#INF
  U:                    PSNR:   32.5310   41.3399   94.5177
  V:                    PSNR:   31.8118   42.4037    1.#INF
Sum:                    PSNR:   30.9074   38.9403  102.2992
look @ those 2 1.#INF i think thats resulting in a wrong overall result isn't it ?
compareyv12(original,modified,"YUV", name+".psnr.log", false)
It is about Time
Old 7th August 2003, 18:58   #9  |  Link
Shalcker
Programmer
Shalcker's Avatar
@Shalcker
No, they don't. Look up in this thread - final Average PSNR is calculated as 10*log10 (255*255*FramesProcessed/ SumValues[Channel][_MSE]). Now, infinite PSNR is only possible for frames with zero MSE - which means that they are just ignored in final Sum while FramesProcessed increases. MSE Sum is not zero as long as at least one frame is different from another. And if all frames are identical then infinite PSNR is RIGHT and absolutely valid result.
Old 24th August 2003, 01:52   #10  |  Link
quantum
So what is the average PSNR here?
Total frames processed: 49001
  Y: Mean Absolute Deviation:    0.0000    3.9589    5.7205
  U: Mean Absolute Deviation:    0.0000    0.4881    2.5603
  V: Mean Absolute Deviation:    0.0000    0.3679    2.2183
Sum: Mean Absolute Deviation:    0.0000    5.0053    3.9889
  Y:          Mean Deviation:   -0.3584    0.4515    0.7846
  U:          Mean Deviation:   -0.5319    0.0983    0.6549
  V:          Mean Deviation:   -0.3375    0.0828    0.8397
Sum:          Mean Deviation:   -0.2154    0.6608    0.5377
  Y:       Mean Square Error:    0.0000    3.8224   76.5912
  U:       Mean Square Error:    0.0000    1.3902   15.1334
  V:       Mean Square Error:    0.0000    1.0398   10.8859
Sum:       Mean Square Error:    0.0000    2.9533   51.8263
  Y:  Root Mean Square Error:    0.0000    1.7033    8.7516
  U:  Root Mean Square Error:    0.0000    1.0113    3.8902
  V:  Root Mean Square Error:    0.0000    0.8660    3.2994
Sum:  Root Mean Square Error:    0.0000    1.5065    7.1990
  Y:                    PSNR:   29.2890   -1.#IND    1.#INF
  U:                    PSNR:   36.3314   -1.#IND    1.#INF
  V:                    PSNR:   37.7621   -1.#IND    1.#INF
Sum:                    PSNR:   30.9853   -1.#IND    1.#INF
I have a number of frames like this in the video:
 48876    0.0000    +0.0000     0     +0     1.#INF   43.5857
quantum is offline   Reply With Quote
Old 24th August 2003, 05:41   #11  |  Link
Shalcker
Programmer
Shalcker's Avatar
<skip>
Weird... really weird...
I don't see how things can be that different between this (average PSNR writtten for each frame, which is ok as you noted below in frame example)
10*log10 (255*255/(SumValues[i][_MSE]/FramesProcessed) )
and this (average PSNR written at the end of the sequence)
10*log10 (255*255*FramesProcessed/ SumValues[i][_MSE])
SumValues is array of doubles, and i don't think there can be a problem with that, so maybe problem comes with big number of frames. hmm... yes, looks like that creates error.
(255*255*49001)=3186290025 (0xBDEAED69)
Problem starts at frame 33026, guess not many people process sources that big...
Fixed version 1.02 is available at the same URL
http://web.etel.ru/~shalcker/CompareYV12.zip
Look at this information on the last frame - last number there is average PSNR for all 49001 frames...
Old 31st August 2003, 16:06   #12  |  Link
quantum
New version works okay so far, thanks.
