Old 17th July 2003, 08:16   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Scarface [R1]: Displaying Main Menu Upon DVD Insert Guide
Scarface [Region 1]: Displaying Main Menu Upon DVD Insert
Courtesy of 2CL
User lrosado wanted to know how to do this so I came up with this small simple guide to help him and others. The total size of the ripped and unstripped files is 7.63 GB (8,199,794,688 bytes) so do what you need to do for you to get your backup. FYI, the trailers and outtakes are in the VIDEO_TS.VOB.
Tools I used
IFOedit 0.95
DVD Decrypter in File Mode
____________________________________________
1. Rip all files to a folder on your harddrive.
2. Open VIDEO_TS.IFO with IFOedit and press "Get VTS Sectors" button. Press OK
3. Go to VIDEO_TS.IFO / VMGM_MAT / First Play PGC / PGC Command Table section. We need to edit Pre Command #11 as follows. Right click on Pre Command #11 and select "Edit Command". Select "(JumpSS_VTSM) Jump to Titleset Menu" and input [Title Nr: 1, TitleSet Nr.: 1, Menu: root]. Press OK.
OLD > 11.Pre Command...(JumpTT) Jump to Title: 3
NEW > 11.Pre Command...(JumpSS VTSM) Jump to TitleSet(vts): 1, Title(ttn): 1, root-menu
4. Save VIDEO_TS.IFO
5. That's it! Press DVDplay button to preview/test.
2COOL
Old 17th July 2003, 23:14   #2  |  Link
lrosado
El Capitan
Thanks 2COOL, will try tonight. I guess you are just 2COOL for us.
WinXP
P-4 3Ghz 800Mhz
1Gig Corsair DDR 400mhz
2 36Gig WD Raptor S-ATA
2 74Gig WD Raptor S-ATA
875P Chipset
SB Live 5.1
ATI All in Wonder 9600XT
ARTEC 16X DVD-Rom
LG DVD-+R/RW/DL
lrosado is offline   Reply With Quote
Old 18th July 2003, 00:54   #3  |  Link
voo_doo99
Re: Scarface [R1]: Displaying Main Menu Upon DVD Insert Guide
[QUOTE]Originally posted by 2COOL
Courtesy of 2CL
'Displaying' or 'Disabling' [check your cheatsheets list title!]
voo_doo99 is offline   Reply With Quote
Old 18th July 2003, 02:10   #4  |  Link
2COOL
2COOL's Avatar
Re: Re: Scarface [R1]: Displaying Main Menu Upon DVD Insert Guide
[QUOTE]Originally posted by voo_doo99
Courtesy of 2CL
@voo_doo99
HUH? I have no idea what you are talking about. It says "Displaying" not "Disabling". Deny, deny, deny...
Just kidding! . I was really tired when I posted the shortcut link that so thanks for pointing out the typo.
2COOL
