Thread Tools Display Modes
Old 15th June 2003, 16:51   #1  |  Link
Mosu
minor fan of cows
Mosu's Avatar
mkvtoolnix: new version
New releases will be announced by replying to this thread. The current version is 0.7.2. Look for it on the last page of this thread.
Hi.
I'd like to use this thread to announce any new version I'll release. Bugreports are welcome here as well - although I still prefer to get them via Email
Today I'll start with release 0.4.4. Here's the ChangeLog since 0.4.3:
2003-06-15 Moritz Bunkus <moritz@bunkus.org>
* Several options now need an explicity track ID to specify which tracks of an input file the option should be applied to. These options include --atracks, --vtracks, --stracks, --sync, --default-track, --cues and --language.
* The Matroska reader now handles track selection correctly.
2003-06-13 Moritz Bunkus <moritz@bunkus.org>
* Added an option for identifying input files and their track types.
This release breaks the old syntax for the options mentioned above. This is especially important for any GUI which might use mkvmerge. On the other hand the new syntax is much more flexible than the old one - these options do not apply to all tracks in a file anymore but to only one specific track (you can still use -1 as the track ID and hit all tracks). For details read the man page/HTML documentation.
A note to the Windows users: Several people have reported crashes in the AVI reader on non-Windows-XP systems. Unfortunately I don't have access to any Win2k/Win98 machines at the moment, neither do I have a spare hard drive on which to install it. Needless to say that mkvmerge works fine for such files on both Windows XP AND Linux So please be patient with me until I've found a solution. Thanks.
Get the sources/binaries at http://www.bunkus.org/videotools/mkvtoolnix/
Latest mkvtoolnix is v2.9.8
If I ever ask you to upload something then please use my FTP server (address: ftp.bunkus.org, user: "upload", password: "only").
Mosu is offline
Old 16th June 2003, 08:19   #2  |  Link
Joe999
Yay! I did a distupgrade today and noticed this being updated. Thanks for the hard work you've put into it!
Joe999 is offline
Old 16th June 2003, 21:03   #3  |  Link
ssjkakaroto
ssjkakaroto's Avatar
hi there mosu, i dont know if this is a error of the AVI reader but this is what i got with the win version:
Opened 'd:\test.mkv' for writing.
progress: 33801/33801 frames (100%)
Writing cue entries (the index)...
7 [main] mkvmerge 1372 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
1510 [main] mkvmerge 1372 open_stackdumpfile: Dumping stack trace to mkvmerge.exe.stackdump
and it created mkvmerge.exe.stackdump which is 2k long, but strangely the mkv file created works ok, here's the command i used:
mkvmerge --output d:\test.mkv --cues 0:iframes --noaudio d:\test.avi --cues 1:none --language 1:jpn --novideo d:\test.avi
CCCP
ssjkakaroto is offline
Old 16th June 2003, 23:32   #4  |  Link
Mosu
minor fan of cows
Mosu's Avatar
That's the error I was talking about in the first post. I've installed VMware and Win98 under VMware, but it's slow as hell on my Celeron 733, so don't expect a fix too soon :/
Please note that exactly these cues options are the defaults anyway. Stating from http://www.bunkus.org/videotools/mkv.../mkvmerge.html : "The default is iframes for video tracks and none for all others." Just to shorten your command line a bit
Mosu is offline
Old 17th June 2003, 00:51   #5  |  Link
ssjkakaroto
yeah, Pamel told me that on another post, but i was just testing it
good thing is that it's working even with that error, so a fix isn't needed soon
CCCP
Old 22nd June 2003, 22:13   #6  |  Link
Mosu
minor fan of cows
Mosu's Avatar
mkvtoolnix 0.5.0 released
Hi guys.
Time for another release. There have been a lot of changes since the last week. One thing I'd really like you to try is to run mkvmerge under Windows 98/Windows 2000. Several people reported problems and I'm eager to know if the switch from cygwin to mingw32 solved this problem.
The release is available at
Windows binaries:
http://www.bunkus.org/videotools/mkv...lnix-0.5.0.zip
http://www.bunkus.org/videotools/mkv...ix-runtime.zip
Ok, here's the ChangeLog since the last version:
2003-06-22 Moritz Bunkus <moritz@bunkus.org>
* Released v0.5.0.
* Added 'ReferencePriority' element to the known elements for mkvinfo.
* Removed "(mkvinfo) " from mkvinfo's output in order to improve readability and save space.
* --sub-charset now also needs a track ID.
* Modified the verbosity levels for mkvinfo: The seek head subentries and cue subentries will only be shown at level 2 to make the output easier to read.
* The language and default track settings are now kept again if not overridden when reading from Matroska files.
2003-06-21 Moritz Bunkus <moritz@bunkus.org>
* Added mkvextract which can extract tracks from a Matroska file into other files.
2003-06-20 Moritz Bunkus <moritz@bunkus.org>
* Switched from cygwin to MinGW32 for the Windows binaries.
* Fixed a double free() on cleanup (after writing the cues) which resulted in a segfault sometimes.
* Added a SSA/ASS reader.
2003-06-19 Moritz Bunkus <moritz@bunkus.org>
* Support for reading text subtitles from Matroska files.
* Made the AAC reader automatically recognize if a MPEG4 AAC file contains the emphasis header (deprecated) or not (current standard).
Comments, bugreports and stuff is welcome as always
Mosu is offline
Old 22nd June 2003, 23:00   #7  |  Link
Gaia
Now it seems to work under Win98se I do more testing tomorrow.
Gaia is offline
Old 23rd June 2003, 00:01   #8  |  Link
ssjkakaroto
Mosu, just tried on w2k using that exact same command-line and it didnt give me any errors this time
thx a lot for the upd8
CCCP
Old 23rd June 2003, 00:09   #9  |  Link
Mosu
minor fan of cows
Mosu's Avatar
Thanks for the feedback, guys. So it was probably due to some cygwin specific stuff - and I'm just happy that it builds with mingw now.
Happy merging
Mosu is offline
Old 23rd June 2003, 04:19   #10  |  Link
ssjkakaroto
Mosu, this time i tried to have a little more fun trying to mux:
-video file
-aac 2ch track
-ac3 2ch track
-srt sub
-ssa sub
and after the message:
the program just hung with 100% cpu use
the file test.mkv was only 31kb and didnt got any bigger than that
heres my command line:
mkvmerge --output "d:\test.mkv" d:\video.avi --language 0:jpn "d:\Audio1.aac" --language 0:jpn --sync 0:-37 "d:\Audio2-DELAY -37ms.AC3" --language 0:eng d:\subs1.srt --language 0:eng d:\subs.ssa
tia
CCCP
Old 23rd June 2003, 10:46   #11  |  Link
Mosu
minor fan of cows
Mosu's Avatar
-video file
-aac 2ch track
-ac3 2ch track
-srt sub
-ssa sub
tia
Hmm. Ok, please try to leave out the aac track and see if that changes anything. As I've said I've rewritten the AAC parser, and it may very well be buggy.
If this does not help then try to find the file that mkvmerge chokes on by leaving out a single file each time. Please tell me the results.
If it is the AAC file could you then please send me the first 4megs of that file? Any file splitter will do, I don't care if the end of the file is borked. Please upload that file via FTP to mosu.no-ip.com, username upload, password only.
Thanks for your help
Mosu is offline
Old 23rd June 2003, 11:29   #12  |  Link
bond
Jcsston's GUI can be obtained here
Ogg Theora | Ogg Vorbis
bond is offline
Old 23rd June 2003, 12:44   #13  |  Link
ssjkakaroto
ok, when i get home tonight i'll send it to ya
CCCP
Old 23rd June 2003, 18:16   #14  |  Link
Atamido
Seņor Member
Atamido's Avatar
Errrr..... The GUI hasn't been updated yet for the new command set. Don't use it yet for the new mkvtoolnix.
Atamido is offline
Old 23rd June 2003, 18:28   #15  |  Link
ChristianHJW
Matroska Team
ChristianHJW's Avatar
.. dont work for latest mkvmerge, sorry ...
ChristianHJW is offline
Old 23rd June 2003, 18:39   #16  |  Link
angelyote
The frumious Bandersnatch
angelyote's Avatar
Excellent results
Worked like a charm under WinXP muxing 2 ogg tracks, 1 xvid and ssa subs resulting in 1.2g file split into 700m and 500m.
Dave
Looking forward to chapters in mkv
angelyote is offline
Old 23rd June 2003, 18:42   #17  |  Link
Mosu
minor fan of cows
Mosu's Avatar
Re: Excellent results
Me too
Mosu is offline
Old 24th June 2003, 00:35   #18  |  Link
ssjkakaroto
hey mosu, just tested one by one and the problem was in the ssa sub
all the others (including the aac track, do you still want me to send it to you?) would mux together without any problem. It seems that the ssa file that i created with subrip converting from the srt is incompatible with mkvmerge, i tried converting it to uft-8 and unicode formats but it didnt help. i couldn't even mux only the video and the ssa file, maybe there's something wrong with my command line
angelyote how did you mux it and what program did you use to create the ssa file?
tia
CCCP
Old 24th June 2003, 02:09   #19  |  Link
bill_baroud
i'm not sure you can mux ssa with mkvtoolunix ^^;;
you have to use Gabest Matroska Muxer and his Subtitle Source Filer
bill_baroud is offline
Old 24th June 2003, 03:11   #20  |  Link
ssjkakaroto
now you can
CCCP
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
