Old 14th June 2003, 16:02   #1  |  Link
Smart bob filter: DGBob() 1.6.0: Now with slow motion
Lots of people use SmoothDeinterlacer() by Gunnar Thalin (ported to Avisynth by Xesdeeni). But it is very slow. So I have written my own take on smart bobbing. Like SmoothDeinterlacer(), it attempts with some success to mitigate flutter, but it is much faster than SmoothDeinterlacer().
DGBob() can also be used as a simple deinterlacer (does not create frames from fields). It can also produce a fluid 50% slow motion effect.
It supports RGB, YUY2, and YV12 color spaces.
Please get the filter from my website as linked below. You can find it under Mine/Avisynth. Source code is available there as well.
Feedback will be appreciated.
Old 14th June 2003, 16:56   #2  |  Link
Dark-Cracker
Dark-Cracker's Avatar
very nice work as always smoothdeint it's a very usefull filter happy to see he have now a little brother i will test it as soon as possible on PAL material.
Bye
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec.
AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles.
Dark-Cracker is offline   Reply With Quote
Old 14th June 2003, 17:36   #3  |  Link
wotef
wotef's Avatar
what does the "smart" designate over non-smart bobbing?
wotef is offline   Reply With Quote
Old 14th June 2003, 18:33   #4  |  Link
I just described it in my journal, but I will summarize it here.
When you make a frame from a field, you have to create all the missing lines. If you simply interpolated all the missing pixels from the current field, that is a dumb bob, even if you use some fancy interpolation like cubic bsplines.
But if you distinguish static from moving areas of the picture, and then interpolate in moving areas, while using the previous field data for static areas, that is a smart bob.
Smart bobbing allows you to retain the original picture detail in static areas.
Really smart bobbers, such as SmoothDeinterlace() and now DGBob() also attempt to mitigate the effects of flutter, which often results from bobbing. Flutter occurs when the field alternation causes detail to be present in one field but not the next. The simplest case is a single-pixel-high horizontal line. Without anti-flutter mitigation, it will disappear in every other bobbed frame.
Old 14th June 2003, 21:24   #5  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
Absolutely brilliant!
So simple - and yet so effective! I'm looking so much forward to the YV12 version!
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 14th June 2003, 21:52   #6  |  Link
Thanks, sh0dan. Coming from you, that is really good for my ego.
Still, it's a first release. It needs a blend mode. And it can be faster with some optimization. I'm going to finish this one off before returning to Decomb 5, because I need it for my swimming videos.
Old 15th June 2003, 04:55   #7  |  Link
DDogg
Retired, but still around
DDogg's Avatar
This is good news! Any special secrets or recommendations for a ntsc DV source script using this filter?
DDogg is offline   Reply With Quote
Old 15th June 2003, 05:12   #8  |  Link
Just be sure to get the field order correct. Please report on your results.
Old 15th June 2003, 10:46   #9  |  Link
sh0dan
sh0dan's Avatar
@neuron2: You could default to the fieldorder given by GetParity. This would allow users to use assumetff()/assumebff(), as with other filters.
This should also allow for clips with different field orders to be deinterlaced properly.
Old 15th June 2003, 11:03   #10  |  Link
mf
mf's Avatar
Sweet! Now let's see how smart this one is . I hope it really will be- I already have some ideas .
mf is offline   Reply With Quote
Old 15th June 2003, 14:05   #11  |  Link
jorel
Posts: n/a
oh yes,is faster(too big)!
edited:
sorry, wrong words for big project!
neuron2,receive my excuses.
manono, thanks for advise.
Old 15th June 2003, 16:14   #12  |  Link
manono
Hi jorel-
I know you sometimes have difficulty expressing yourself in English, and there's certainly no shame in that. But you have to be real careful with what you say so that it isn't taken the wrong way. To me that comment, besides adding nothing to the discussion, comes off as a completely gratuitous insult to one of the most valuable and respected members of this site. Didn't you get into trouble with some previous comments, and isn't that why you haven't been around for awhile? If you really were just joking, I'd say it was in bad taste and not at all funny. Please watch what you say in the future, unless you just don't care any more. In which case, I'm sure someone will be only too happy to put you out of your misery. Perhaps an apology is in order before it's too late.
Old 15th June 2003, 18:11   #13  |  Link
JohnMK
Is it easier to program within the YUY2 colorspace than in YV12?
JohnMK is offline   Reply With Quote
Old 15th June 2003, 19:57   #14  |  Link
sh0dan
sh0dan's Avatar
@JohnMK: Both have their own advantages. YV12 is "cleaner", as you don't have components mixed, whereas some operations are easier on YUY2, as you have chroma and luma at the same place.
Old 15th June 2003, 22:15   #15  |  Link
bilu
bilu's Avatar
How effective is this? Does it work nicely on both AVI and MPEG-2 sources? Does it return information on every frame or just at beginning?
What a nice contribuition to this thread it may be ( I hope ).
Bilu
bilu is offline   Reply With Quote
Old 15th June 2003, 23:06   #16  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
Hello. Are there plans to build in some threshold-parameters for deinterlacing?
At this time I am not able to get comb-free videos with dgbob.
Small or low-contrast objects are not deinterlaced.
It seems, like there is a temporal mask, which needs some time to apply the new picture contents.
(Sorry, I can't describe this better with my actual english knowledge)
btw. I can't attach a Picture here
scharfis_brain is offline   Reply With Quote
Old 16th June 2003, 05:01   #17  |  Link
Deinterlacing is harder in YV12 due to the vertical chroma subsampling. You can finesse that by deinterlacing the planes independently, but that is theoretically inadequate. To do it right, you have to couple the motion maps of the luma and chroma planes. All these problems don't arise for YUY2. But as sh0dan correctly points out, other applications are easier and faster in YV12.
Old 16th June 2003, 05:11   #18  |  Link
Sure, I can expose them to the user. I just chose hard-coded values for the first version. There are two thresholds. The first is equivalent to dthreshold in Decomb 4. It is already set very low, 4 or 5 IIRC. The more problematic one is the one that compares the pixels in the previous and following fields. If their difference is within this threshold I say the corresponding pixel in the current frame is static and I weave it. The problem is that if you make that one too low, you start losing your flutter mitigation (because normal noise variance starts making pixels get bobbed instead of weaved). I am aware of this issue and am exploring ways to better detect static areas. However, the whole reason for making DGBob() is to have a faster smart bob. I have to be careful not to lose that advantage.
Old 19th June 2003, 01:35   #19  |  Link
New version provides much better results
DGBob() version 1.1.0 is now available at my website. It greatly improves the motion detection (with no performance loss!) and thus produces much better results. The motion detection threshold is now exposed in the user interface ('thresh' parameter) to allow tweaking the tradeoff between flickering and residual combing/artifacts.
This version greatly reduces the artifacting resulting from single-field pixel changes. I'm just off to my journal to describe how it was done. I hope you all are as pleased with it as I am now. This final little finesse has made smart bobbing really viable, where previously I thought it was barely acceptable (due to the artifacting).
Next is YV12 support and a "show motion map" option, and maybe cubic interpolation and/or edge-directed interpolation for the interpolated pixels.
I don't often engage in hyperbole, but this filter kicks butt.
Old 19th June 2003, 13:18   #20  |  Link
RGB and YV12 support added
I cranked out DGBob 1.2.0 over my morning coffee. It adds support for RGB and YV12 color spaces. I also described the algorithmic improvement in my website journal.
Woohoo, the only YV12 smart bob filter!
