Old 3rd June 2003, 20:27   #1  |  Link
Zarxrax
Weird blocks when vhq enabled
I have tried enabling vhq mode 1 and mode 4, and this feature always causes blocks very similar to the shit blocks that were in divx3.11a
I KNOW that I have read something about this back when vhq was first released, but I've searched, and nothing comes up. Also since everyone is saying vhq shouldnt negatively effect quality anymore, im not quite sure whats wrong. I'm using koepi's 14052003 build.
Zarxrax is offline   Reply With Quote
Old 3rd June 2003, 20:30   #2  |  Link
JohnMK
In dark places? Encode Star Wars: Attack of the Clones, 1 hour+43/44 minutes in, you should see some pretty horrible blocking. This was with VHQ4 enabled.
JohnMK is offline   Reply With Quote
Old 3rd June 2003, 22:35   #3  |  Link
Zarxrax
No, not in dark places, but in spots where there is lots of motion. Its like luma inverted blocks or something.
Old 3rd June 2003, 22:50   #4  |  Link
Defiler
Asker of Questions
Me too:
http://forum.doom9.org/showthread.php?s=&threadid=41616
"The real trick to optimizing color space conversions is of course to not do them." --trbarry, April 2002
Defiler is offline   Reply With Quote
Old 3rd June 2003, 23:37   #5  |  Link
Zarxrax
Ah, I didn't check that thread because the title made it sound like a different problem.
Mods delete this thread if you want.
Old 4th June 2003, 00:15   #6  |  Link
CruNcher
CruNcher's Avatar
@ all
this is a Trellis Quantization problem if you don't want it don't use it i got exactly the same problems a week ago and reported it in the channel
http://www.mufflastig.com/CruNcher/X...ellisquantbug/
It is about Time
Old 4th June 2003, 00:52   #7  |  Link
Defiler
Asker of Questions
You've verified that simply turning off Trellis is enough to prevent the problem?
Old 4th June 2003, 17:28   #8  |  Link
CruNcher
CruNcher's Avatar
@ Defiler
jep exactly but only for this encode and only for this special scene wich is a Strobo light effect Scene where Lights go off and on very quickly if i read now that also this problems can occour with VHQ i belive it could have something todo with the R-D cause VHQ also uses R-D now maybe there is some problems with Motion Estimation in such scenes i can't say that for sure but for this encode rurning off trellis helped and VHQ was still on Wide Search so its hard to tell if people now say it can also happen with only VHQ on what the problem is i would tip then in a logical manner on the R-D part both useing it but maybe Syskin can bring light into that
It is about Time
Old 4th June 2003, 17:42   #9  |  Link
Defiler
Asker of Questions
I experienced the same thing. Turning off Trellis, but leaving VHQ=4 solved my problem.
Has anyone seen them with Trellis enabled, VHQ off?
Old 4th June 2003, 22:05   #10  |  Link
Calculon
Trellis caused this problem for me as well. I just turned it off and encoded again(a captured episode of Sliders) and it was fine. I had VHQ 4 on both times.
Calculon is offline   Reply With Quote
Old 4th June 2003, 23:51   #11  |  Link
angelyote
The frumious Bandersnatch
angelyote's Avatar
Spirited Away
another me too post.
Noticed some ugly blocking in some of the dark solid areas, like peoples hair. Turned off Trellis and kept VHQ 4 and beauty once more. That's why it's in the debug section though.
Dave
angelyote is offline   Reply With Quote
Old 5th June 2003, 02:02   #12  |  Link
Animaniac
Animaniac's Avatar
I just encoded a 2 hour movie with VHQ 4 and R-D, and no weird blocking. I can safely say it's my best encode yet.
Animaniac is offline   Reply With Quote
Old 17th June 2003, 21:21   #13  |  Link
jrmillerUT
what do you mean by Trellis and R-D...
jrmillerUT is offline   Reply With Quote
Old 17th June 2003, 21:25   #14  |  Link
mf
mf's Avatar
Trellis: Trellis Quantization
R-D: Rate Distortion
Just look it up in google...
mf is offline   Reply With Quote
Old 19th June 2003, 06:22   #15  |  Link
soujir0u
If you're using ffdshow try using Xvid.dll to decode the video. I got this strange problem with one of my recent encodes...
soujir0u is offline   Reply With Quote
Old 19th June 2003, 10:36   #16  |  Link
BiaTch 5.0
Angel
BiaTch 5.0's Avatar
VHQ4 goes about 3x slower on my PC than VHQ1 so a movie that takes 2 hour to encode would take me 6 with VHQ4, is it worth the time?
Windows 2000 Pro
AthlonXP 1700+, ASUS/VIA KT266A, Seagate 80GB, Radeon 7000 VE, Creative Audigy, plexwriter 24/10/24A, Pioneer16 DVD.
BiaTch 5.0 is offline   Reply With Quote
Old 19th June 2003, 11:03   #17  |  Link
Gaia
Yes ofcourse but you have to try yourself. It's up to you. I don't care about speed.
Gaia is offline   Reply With Quote
Old 19th June 2003, 12:33   #18  |  Link
stax76
staxrip & mpv.net
I made a couple of compressibility tests using DVX which uses a complete different method than Gordian Knot. From VHQ 0 to VHQ 3 there was a constant increase of the compressibility but VHQ 3 and VHQ 4 had the same compressibility but VHQ 4 was a lot slower than VHQ 3 so my conclusion is VHQ 4 is a overkill
edit: I saw a note by a XviD developer that stated comp tests aren't the full truth
staxrip is in need of a new maintainer since I would like to retire.
Old 19th June 2003, 17:15   #19  |  Link
CruNcher
CruNcher's Avatar
@Dolemite
Vhq in the latest available koepi build is b0rked it has been fixed in the newest internal build and also in the cvs. Its in testing stage @ the moment, because it also contains syskins new ipb decission code which is not in cvs and needs to be tested first.
It is about Time
Old 19th June 2003, 17:29   #20  |  Link
stax76
staxrip & mpv.net
@CruNcher
thanks, I'm a XviD n00b using it since two weeks, currently reading all the guides and topics, quite a lot things to read
