Old 2nd June 2003, 23:54   #1  |  Link
Dark-Cracker
Dark-Cracker's Avatar
Besweet bugs : ABR/Preset MP3 & ogg -6ch ( 3 bugs )
Besweet : ABR/presets MP3 bugs & OGG -6ch bug.
hi,
@Dspguru
there is still some bugs (already reported a few mounth ago) i hope u can find the time to fix them :
(tested with the latest lame_enc.dll and libvorbis.dll on rarewares)
- ogg and -ch6 at a bitrate upper than 192 :
working for a bitrate=191 kbps with an Actual Avg. Bitrate : 213kbps
but not working for 192 kbps, it encode at 128 kbps (without -6ch switch no problem).
logfile :
BeSweet v1.5b18 by DSPguru.
Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu).
Using libVorbis.dll v1.0 ( Apr 16 2003 ) by John33 (www.inf.ufpr.br/~rja00).
Logging start : 06/02/03 , 19:24:56.
C:\WINDOWS\BUREAU\BESWEE~1.5B1\BESWEET.EXE -core( -input H:\testvob\out.ac3 -output H:\raspoutine\toto.ogg -logfile besweet.log ) -ogg( -b 192 -6ch ) -split( -start 0 -end 10)
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : H:\testvob\out.ac3
[00:00:00:000] | Output: H:\raspoutine\toto.ogg
[00:00:00:000] | Floating-Point Process: Yes
[00:00:00:000] +-------- AZID -------
[00:00:00:000] | Input Channels Mode: 2/0, Bitrate: 192kbps
[00:00:00:000] | Total Gain: 0.000dB, Compression: None
[00:00:00:000] | LFE levels: To LR -INF, To LFE 0.0dB
[00:00:00:000] | Center mix level: BSI
[00:00:00:000] | Surround mix level: BSI
[00:00:00:000] | Dialog normalization: No
[00:00:00:000] | Rear channels filtering: No
[00:00:00:000] | Source Sample-Rate: 48.0KHz
[00:00:00:000] +-------- OGG --------
[00:00:00:000] | Avarege Bitrate : 192
[00:00:00:000] +---------------------
[00:00:10:048] Conversion Completed !
[00:00:10:048] Actual Avg. Bitrate : 128kbps
[00:00:20:000] <-- Transcoding Duration
Logging ends : 06/02/03 , 19:25:16.
there is an another problem with the lame_enc.dll file and the --abr switch.
if u use a bitrate under 77 kbps the encode failed "with a lame_enc.dll failed msg".
working for --arb 77 :
log file :
Using lame_enc.dll v1.32 (11/5/2003), Engine 3.94 <http://www.mp3dev.org/>.
Logging start : 06/02/03 , 19:31:31.
C:\WINDOWS\BUREAU\BESWEE~1.5B1\BESWEET.EXE -core( -input H:\testvob\out.ac3 -output H:\raspoutine\toto.mp3 -logfile besweet.log ) -lame( --abr 77 )
[00:00:00:000] | Output: H:\raspoutine\toto.mp3
[00:00:00:000] | Output Stereo mode: Dolby surround compatible
[00:00:00:000] +-------- LAME -------
[00:00:00:000] | Bitrate method : ABR
[00:00:00:000] | Avarege Bitrate : 77
[00:00:00:000] | MP3 Min bitrate : 32
[00:00:00:000] | MP3 Max bitrate : 320
[00:00:00:000] | Channels Mode : Joint Stereo
[00:00:00:000] | Error Protection: No
[00:01:00:032] Conversion Completed !
[00:01:00:032] Actual Avg. Bitrate : 71kbps
[00:00:21:000] <-- Transcoding Duration
Logging ends : 06/02/03 , 19:31:52.
and crashed for a bitrate < 77 (tested with 76,80,64,32..)
Logfile :
Logging start : 06/02/03 , 19:34:34.
C:\WINDOWS\BUREAU\BESWEE~1.5B1\BESWEET.EXE -core( -input H:\testvob\out.ac3 -output H:\raspoutine\toto.mp3 -logfile besweet.log ) -lame( --abr 76 )
Error 47: Error with LAME dll!
Quiting...
[00:00:00:000] Conversion Completed !
Logging ends : 06/02/03 , 19:34:34.
and another problem is with the bitrate limitation and the preset :
if u try to use the max bitrate limitation in a preset it automaticly encode in cbr 128 kbps
exemple , if u use : --alt-preset standard -B 96 it does work and i finaly have a cbr 128 kbps while normaly it's possible to use the max bitrate limitation with presets.
logfile :
Logging start : 06/02/03 , 19:35:50.
C:\WINDOWS\BUREAU\BESWEE~1.5B1\BESWEET.EXE -core( -input H:\testvob\out.ac3 -output H:\raspoutine\toto.mp3 -logfile besweet.log ) -lame( --alt-preset standard -B 96 ) -split( -start 0 -end 10)
[00:00:00:000] | 'alt standard' preset is used
[00:00:06:000] <-- Transcoding Duration
Logging ends : 06/02/03 , 19:35:56.
PS: a little mistake in the word "average" written "avarage" in the ogg ouput msg.
Ps2: problem with path name and space seems to be fixed.
i hope u could find time to finish to fix these bugs.
Bye.
keep up good work.
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec.
AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles.
Dark-Cracker is offline   Reply With Quote
Old 3rd June 2003, 01:29   #2  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
10x. i didn't forget. you might have noticed that the links to your bug-reports are already a part of the openned issues list.
DSPguru is offline   Reply With Quote
Old 3rd June 2003, 02:49   #3  |  Link
Dark-Cracker
damn sorry
i have post this thread in the end of another thread it for that i have post again these bugs
i only want to be sure there were always in your eradiquate bugs list
happy to see u are come back.
PS: don't kick my ass it's my birthday.
Bye.
