Thread Tools Display Modes
Old 19th May 2003, 17:45   #1  |  Link
nomax
Instant Copy 7.1.1 update is out!
Elbys upcoming CloneDVD is breathing on Pinnacle developers neck ))
http://www.pinnaclesys.com/docsuppor...py&page_id=711
Important
This patch can only be used with Instant Copy 7.0, 7.01 or 7.02.
Do not use this patch to update Instant CD/DVD.
Bug Fixes/Improvements:
Better usage of destination disk capacity
Optimized video quality
Overall speed improvements
"Phantom cell sets" fixed
Still picture problem fixed (occured in menus with sound)
Demux errors fixed (aka SID error)
What is new in this version 7.1.1:
The main improvements are a significant speed increase for the DVD transcoding (approx. 30%-50% faster) and a new analyze method for better target disk size usage.
Various registry settings were added. For more information, please report to our support Knowledge Base.
Key combinations (no support available for this function)
F5 : Enable the OK button ignoring all size issues
F6 : Saves the currently selected percentages/titles/streams for this DVD
F7 : Load (if previously saved) settings for this DVD
Batch Processing functionnality. For more information, please report to our support Knowledge Base.
nomax is offline   Reply With Quote
Old 19th May 2003, 18:53   #2  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
I also noticed a new reg settings on this page HERE
DWORD: DVDDestSize Default: 4424
Size InstantCopy tries to reach for the destination medium in MB
DWORD: DVDDestDisplaySize Default: 4424
Size InstantCopy uses to determine if the contents of the disc
fit or wont fit on a recordable disc in MB
DWORD: DVDVideoSaveBorder Default: 2
Unsecurity in percent of the transcoding process
[/B]
DVDVideoSaveBorder is interesting cos it looks like a black bar issue, trying it on Road To Perdition now
p.s. LOL "Phantom cell sets" fixed , like the quotes round Phantom Pinnacle, whatever gave you that idea?
MackemX is offline   Reply With Quote
Old 19th May 2003, 19:38   #3  |  Link
mrbass
I'm just gonna assume this is cumulative like update2 was.
Do let us know how Road to Perdition comes out MackemX.
www.mrbass.org DVDShrink | DVD2DVD | DVDFAB | Mac guides
mrbass is offline   Reply With Quote
Old 19th May 2003, 20:01   #4  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
batch processing now available HERE
download the file HERE
the missing MB's do now work on my example DVD I sent them
not so sure with other DVD'S tho, cos it looks the same as before
a known problem DVD showing 6.77Gb instead of 7.05Gb still shows 6.77Gb
if you wanna get it to set to the max for a blank DVD (4489MB)automatically then set the reg settings to these
DWORD: DVDDestSize Default: 1189 (4489)
DWORD: DVDDestDisplaySize Default: 1189(4489)
you could set them lower to be safer, but I like a risk
Old 19th May 2003, 20:22   #5  |  Link
homey
Excellent news! I've been checking their site almost daily. I miss a couple of days and here it is. Thanks for the update! I've got a three movies to backup that I'll be trying this with.
HDC
homey is offline   Reply With Quote
Old 19th May 2003, 22:06   #6  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
exactly the same undersizing result with Road To Perdition
came out at 3.38GB
it did predict 4.37Gb with menu @50% and Title 1 at 86% with 5.1 sound (nothing else) but got nowhere near
gonna adjust the DVDVideoSaveBorder setting and see what happens
but this is no good cos what if other titkes are different ratios ????????
not the sizing fix I was expecting
Old 19th May 2003, 22:06   #7  |  Link
mrbass
to be safe (even though it's a crap shoot with IC7 anyway) I'd go for 4480MB
Blank DVD-R 4,489MB 4,706,074,624 bytes or 4.383GB
Blank DVD+R 4,483MB 4,700,372,992 bytes or 4.377GB
road to perdition: keep trying MackemX.. We/I appreciate your efforts.
Old 19th May 2003, 22:22   #8  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
the saving the settings don't work either
you save the settings (F6) and when you reload them (F7) it remembers which titles and audio/subs you selected but not the percentages
it just does an automatic resize and equally distributes the reduction on the menu/titles
so far, not so good an update as what I initially thought it was gonna be
Old 19th May 2003, 22:38   #9  |  Link
mrbass
you mean F7 to load settings not F8 right? typo
o F5 : Enable the OK button ignoring all size issues
o F6 : Saves the currently selected percentages/titles/streams for this DVD
o F7 : Load (if previously saved) settings for this DVD
Old 19th May 2003, 22:47   #10  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
DOH!
edited post
trying a setting of 10 with the DVDVideoSaveBorder setting with RTP
Old 19th May 2003, 23:01   #11  |  Link
jippiejajee
somebody noted that this new version registers everytime it starts a regtool application to run at start-up in startup folder of windows. If you look to properties of shortcut you will see that target is your serial number.....
O yeah registry entry DVDsavequality is also gone...
mmmm... wonder why they do this
jippiejajee is offline   Reply With Quote
Old 20th May 2003, 00:38   #12  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
I tried a DVDVideoSaveBorder of 50 and it came out at 3.30Gb with exactly the same % settings as before
so its smaller!!! cos the default of 2 produced 3.38Gb
oh well, maybe next time
Old 20th May 2003, 01:06   #13  |  Link
jhmac
jhmac's Avatar
Has anyone noticed a 30-50% increase in speed?
jhmac is offline   Reply With Quote
Old 20th May 2003, 01:51   #14  |  Link
mrbass
yes.... it took me 1 hour and 45mins for 6.2GB main movie only. Usually that'd take about 3 hours. So I say yes to the 33% increase in speed.
Old 20th May 2003, 04:45   #15  |  Link
jzaman
With the "main movie only" scenario:
Was the sizing closer to 4.37? Any visual improvements?
jzaman is offline   Reply With Quote
Old 20th May 2003, 05:36   #16  |  Link
mrbass
actually it was 6.9GB main movie only not 6.2 like I thought.. it came out to 4.20GB so I guess not too bad.
Old 20th May 2003, 09:12   #17  |  Link
MackemX
..DVD GOD..
MackemX's Avatar
it's faster but at what cost?
as for sizing, how come Pinnacle have released it saying beter use of 4.37Gb yet it don't work
it may give better results for 1.85:1 etc but not 2.35:1. We'll see
Old 20th May 2003, 11:00   #18  |  Link
snotuk
I'v try'd the same film three times.ENOUGH 16:9 anamorphic.
1st time i left all extras in ect,a full 1:1 copy setting the slide bar to 4.31.Size when finished 4.7.
2nd time move only leaving the slide bar at 4.31 came out at 4.40
3rd time same as the 1st full 1:1 but dropped the slide bar down to 4.2,size it can out 4.24.
So now instead of oversizing to get a nice tight fit,i'm having to undersize to get it some where near.
I,m gonna try another disc to see what happens there.
Jesus Hits Like An Atom Bomb
snotuk is offline   Reply With Quote
Old 20th May 2003, 11:37   #19  |  Link
tgferg67
You got to be kidding, It's been 3 months after this program has been released and it still can't size accurately
Have they not noticed their competitors programs size within 5%
I give up all hope with these people.
tgferg67 is offline   Reply With Quote
Old 20th May 2003, 13:40   #20  |  Link
wumpi
You FAIL to forget that IC does not apply constant transcoding quality to the movie but adjusts it according to the complexity of each part of the mpeg stream. It is easy to calculate the space required when you use constants, but it is not that easy when you don't know in advance exactly how much transcoding is used for the entire mpeg stream.
wumpi is offline   Reply With Quote
Thread Tools
[IMG] code is Off
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
