#1 | Link |
I'm afraid we've to stop
![]() Join Date: Mar 2003
GK 0.28.5 is out - see main forum
For those who wonder what's new in 0.28.5:
1) new smart bob (DGBob()) deinterlace filter 2) Queue window changed a bit 3) lots of languages (12) included with GK 4) comp test for xvid & brames uses "extended method" 5) Subs manual auto split added on subs tab ------------- Changes in GK 0.28.4 beta (only an upgrade for 0.28.3 which has to be installed first): 1) DVD2AVI 1.76 moved into separate dir 2) added support for different languages (option tab) - big thanks to the glouch all you have to do now is to put gk_youlanguage.ini in GK folder to make GK see new language 3) memory leak when splitting is on fixed 4) mpeg2dec3.dll updated to version 1.0.8 (memory leaks should be fixed there as well) 5) some minor bugfixes Many changes in the rippack were done for 0.28.3, so not just exe installer this time - you have to download new rippack, sorry. ![]() (updates: 1. GK itself 2. Avisynth 2.5.2 3. mpeg2dec3.dll 1.0.6 4. decomb.dll 5.0.0b5 5. DVD2AVI 1.77.3 6. lame.dll (latest) 7. azidts.exe 8: besweet.dll 1.5b18 9. Besweet 1.5.b18 10. DTSSource.ax 11. vsfilter.dll (latest) ) Changes in GK 0.28.3 beta: - added DTS support via azidts (azidts requires WinDVD to be installed, everything else comes with installer) - still testing - added any DVD2AVI project support (works with 1.76, 1.77, 1.83) - attention: GK now works only with mpeg2dec3.dll provided - added command line interface which automatically openes video, audio and other files: /video"videofile" /audio1"audiofile" /audio2"audiofile" /files"otherfile1;otherfile2" - added support for non-english characters in video/audio files - minor bugfixes Changes in GK 0.28.2 beta 2: - Fixed bugs (that I remember ): 1) VDubMod path wasn't saved 2) second audio CBR encoding problems fixed 3) Log file can reside in the root of the drive... 4) something else... - Path to the plugin dir of avisynth introduced - GK now shows only codec selected on bitrate tab (on encoder window) - new fixed VDubMod supplied (for handling files > 2Gb) Changes in GK 0.28.2 beta: - lots of bugs of 0.28 fixed (I don't have enough time to search for what I fixed during last week). Lets just say I fixed every single bug I know. So if you still find something not working that you reported already, then post it here or better at SF. - Paths settings instroduced (testing required). They have been moved from Encoder window to main window. - Some cosmetic improvements (from SF request section mainly) Changes in Rippack: - Besweet 1.5b17 - GK 0.28.2 beta - VdubMod 1.5.1.1a + fix by Suirys P.S. it's important to upgrade VdubMod (if you're upgading from 0.28), so just exe upgrade will not work (you have to get full rip-pack or wait for upgrade provided).
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ Last edited by len0x; 22nd June 2003 at 21:09. |
#2 | Link |
![]() Join Date: Nov 2001
its great that we have program paths now but the possibility to define an avisynth plugin path will also be very nice!!!
thanks anyway!
#5 | Link | |
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
#6 | Link | |
[HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth] "plugindir2_5"="path to plugin dir" if this is not what you need maybe use avs script like this SetWorkingDir("path to plugin dir") LoadPlugin("mpeg2dec3.dll") |
#7 | Link | |
#8 | Link | |
#9 | Link | |
#10 | Link |
so, beta 2 is out
It still lacks two features though:
1) DTS support (and DVD2AVI 1.77) 2) subtitles splitting First very probably will go into 0.28.2 final Second - I have some thoughts about it: I can't easily make it automatic process (those files are just not part of the job). But how about having another button on Subs tab to select the file and split the subs according to ready made avi ? (i.e. just getting length of the file and split according to that)
#11 | Link |
@lenox
can't you just add a tab "add subtitle" nearby "Audio A","Audio B", "Files", and add a check box "Split subtitles" nearby the check box of "Split final file into CDs" and then automate it (and maybe rar them like r4r does) after the split of the avi's ? * edited twice * another feature that might be cool: rename of the final files like: add 2 text boks of "Final avi's name" and pattern box. the pattern box example: "%movie_name% [%part_num%of%total_parts_num%]" and in movie box name: "The Matrix 2 - Reloaded" so the final output will be: The Matrix 2 - Reloaded [1of2].avi The Matrix 2 - Reloaded [1of2].idx The Matrix 2 - Reloaded [1of2].rar The Matrix 2 - Reloaded [2of2].avi The Matrix 2 - Reloaded [2of2].idx The Matrix 2 - Reloaded [2of2].rar thats how I name my movies... p.s.: I don't have really the matrix reloaded yet... Last edited by idanm19; 19th May 2003 at 16:41. |
#12 | Link | |
P.S. in general adding anything into GK job now - it's the same as adding support for a new codec (apart from visual part). I might be overreacting here a little, but it sounds more complex than you think... (that's why I think automatic manual split after job's done sounds much easier for me and more usefull for the ppl who make split manually)
#14 | Link |
DVD Rebuilder!
@len0x,
I think the naming 0.28.2 beta 2 is confusing, imho better use 0.28.3. PS. I think the "Program Paths" is still buggy, it will not be updated after I "Locate" the path. I have to click "Don't Check" twice to get the path entered. Last edited by ookzDVD; 20th May 2003 at 09:44. |
#15 | Link | ||
(I don't seem to have this problem...)
#17 | Link | |
#19 | Link | |
But anyway - we know how to solve it
| Thread Tools | |
| Display Modes | |
