Old 11th May 2003, 22:28   #1  |  Link
Nic
MPEG2Dec3 v1.10
New version of MPEG2Dec3.dll for AviSynth 2.5+
http://nic.dnsalias.com/MPEG2Dec3v110.zip
http://nic.dnsalias.com/MPEG2Dec3v110_src.zip
New Features:
  • Crop now works (uses AviuSynth's Crop)
  • trbarry's optimisations (Add_Block, Block Decoding (for SSE2))
  • Uses AviSynth's BitBlt for optimised memory copying
  • No more memory leaks
  • Two new iDCT's (Skal's v.fast and the v. accurate SimpleiDCT from XviD (now with trbarry's optimisations!))
  • General Speed optimisations
  • Accepts both dvd2avi 1.77.3 & 1.76 d2v files
  • Adds support for MPEG2Dec3.dll to be used as an external DLL without AviSynth (see GetPic example in sourcecode).
  • Bugfixing & Better Stability
  • Luminance Filter added back in (was taken out by Marc)
Cheers,
-Nic
edit: Updated post to latest version
Nic is offline   Reply With Quote
Old 12th May 2003, 06:46   #2  |  Link
Pasqui
@Nic
Thanks a lot for this release. But why did not you used MPEG2Dec3 1.0 as an origin for your changes ? Maybe the source code was not available ?
Pasqui is offline   Reply With Quote
Old 12th May 2003, 09:18   #3  |  Link
Nic
Id once read: http://forum.doom9.org/showthread.ph...1.0#post264517
So Id thought there was no difference, and Id forgotten about the 1.0 release, but there was a difference.
So forget the above posts and use below for the fixed memory alloc bug:
(Link Removed)
Sorry about that.
-Nic
ps
MPEG2Dec3 v1.0 didnt have the debug output that .94 had so that had already been taken care of. My Bad
(still might be useful for Jonny: )
http://forum.doom9.org/showthread.ph...ory#post274437
Old 12th May 2003, 09:20   #4  |  Link
Kyo
Anime Team!
Kyo's Avatar
Thanks Nic for taking the time... Great Job
...testing
Old time lurker
Kyo is offline   Reply With Quote
Old 12th May 2003, 10:22   #5  |  Link
Wilbert
There already exists a version 1.0.1.: http://forum.doom9.org/showthread.ph...hreadid=49994. Could you include his changes and name it 1.0.2?
Old 12th May 2003, 10:26   #6  |  Link
jonny
jonny's Avatar
Nice surprise, many thanks Nic!
jonny is offline   Reply With Quote
Old 12th May 2003, 10:45   #7  |  Link
Nic
@Wilbert: Damn it, this is very bad of me not to notice such things...trbarry did'nt say his exact changes either (very unlike him) But I think its only in getbit.c
Ill update soon.
-Nic
Old 12th May 2003, 10:54   #8  |  Link
Nic
Done...finally.
Ill work on it more to see if theres any other improvements to make.
Sorry for the complete mess up:
(link removed)
-Nic
Old 12th May 2003, 10:55   #9  |  Link
bond
great!!!
nic
perhaps you can update your hp with this mpeg2dec3 so that more people recognize that it exists
Ogg Theora | Ogg Vorbis
Old 12th May 2003, 12:34   #10  |  Link
Nic
Ok, for my mistakes, ive added the ability to read both dvd2avi 1.76 and 1.77.3 D2V files.
http://nic.dnsalias.com/MPEG2Dec3v103.zip
http://nic.dnsalias.com/MPEG2Dec3v103_src.zip
-Nic
Old 12th May 2003, 15:58   #11  |  Link
RB
Retired
Thanks Nic, works like a charm. Any chance you could get speed up to the MPEGDecoder.dll level?
RB is offline   Reply With Quote
Old 12th May 2003, 16:03   #12  |  Link
Nic
Getting there...just released 1.04
-Nic
Old 12th May 2003, 16:42   #13  |  Link
trbarry
trbarry's Avatar
Nic -
IIRC, the only change I made was to find the right PID numbers for HDTV. You got that one in Getbit, right?
- Tom
trbarry is offline   Reply With Quote
Old 12th May 2003, 16:47   #14  |  Link
trbarry
trbarry's Avatar
I replaced the aligned memory functions & compiled in ICL7 (well, apart from one file).
It still uses some sort of aligned_malloc, right? That's needed for SSE2 support, and probably faster on other boxes.
- Tom
Old 12th May 2003, 17:27   #15  |  Link
RB
Retired
@Nic
Thanks for the update. Here is a quick speed comparison between MPEGDecoder v2.03 and mpeg2dec3 v1.04 (idct=5). AVISynth 2.5.1 RC2, P4 2.4 GHz FSB 533, 512 MB PC266 DDR, simple script to frameserve PAL 720x576 video @ 25 fps with no filters except ConvertToYUY2, CCE 2.66.01.07.
mpeg2dec3 v1.04: 1.72
MPEGDecoder v2.03: 1.89
Maybe still a little room for improvement
Old 12th May 2003, 18:10   #16  |  Link
OBcecado
LuLz
Thanks for this update, I'm having a small speed boost (+4 fps)
Stay well.
OBcecado is offline   Reply With Quote
Old 12th May 2003, 22:21   #17  |  Link
Nic
@trbarry: yup I saw that in getbit. Yup its using aligned memory, it uses the functions xvid uses.
@OBcecado: Good to know
@RB: Always room for improvement, mpeg2dec3 does alot of copying memory about, if I can lower that it would be good (it shouldnt need to do as much as it was doing in the YUY2 version, but it still is). If anyone else fancies taking a look, look into assemble_frame is used, copyall (which is basically a memcpy) and Add_Block.
From profiling it with the AMD tools it seems to spend as much time copying memory blocks as it does iDCT (!? Surely thats not right, but ill look into it)
-Nic
ps
If I made a version, that didnt pay attention to fields correctly like MPEGDecoder doesnt, then it would speed along even faster (it would cut down on the memcpy's significantly).
(but thats not a good idea )
Old 13th May 2003, 01:48   #18  |  Link
trbarry
trbarry's Avatar
Nic -
I just took a look at Add_Block, mostly because I sort of remembered it. It could be made a bit faster in a couple ways, but not done away with.
I'm not really sure why the AMD profiler points that out as a major problem. It's usually inlined but maybe not so when profiling? Can you say what percentage of time Add_Block and the other main offenders are using? I had a trial copy of Vtune when I was first playing with this a year ago but it's since expired.
Also it looks like most of the SSE2 support is turned off in MPEG2DEC3. I don't know what the effects of that are, but it certainly can't help P4 performance.
- Tom
Old 13th May 2003, 06:39   #19  |  Link
int 21h
Still Laughing
int 21h's Avatar
I never saw a significant leap on my P4 with all of those enabled anyways, I think they may have made for better accuracy though.
int 21h is offline   Reply With Quote
Old 13th May 2003, 08:12   #20  |  Link
alx
My test
Hi, because iīm a newbie in avisynt use, i will try to explain all the details of my test.
SCRIPT
LoadPlugin("C:\UTILS\DVD\avisynth2\PLUGINS\MPEG2DEC3-25.dll") --> NICīs mpeg2dec3 1.04, of course
LoadPlugin("C:\UTILS\DVD\avisynth2\PLUGINS\Unfilter-25.dll")
LoadPlugin("C:\UTILS\dvd\AviSynth2\plugins\UNDOT-25.DLL")
mpeg2source("G:\zzzprueba\1.d2v",cpu=6)
Crop(8,66,-4,-68)
LanczosResize(640,336)
UnFilter(-5,-5)
UnDot()
I used avisynth_100503 with Virtual Dub Mod 1.5.1a for the test on my WXP with SP 1.0a installed.
I have an Athlon 2100xp with 512mb. ram.
Clip is "Hollow Man" trailer......2:27 min length
XviD.Alpha.05.05.2003.1100 settings were:
VHQ=4
Croma Motion
B-Frames=2
Quantizer=2
all other settings=default
Elapsed time: 5:05 m
All the same settings and script, but this time with MarcFD 1.00 mpeg2dec3.dll
Elapsed time: 4:45 m
Both clips play ok.
Hope this help.
Alx.
BTW, if someone see that the order of filters in the script is incorrect, please let me know, because i just began with avisynth and all advices are welcome.
And, NIC, when are you planning to launch DVD2Avi_Nic ??? hope you had time in this last 2 years...he he he
alx is offline   Reply With Quote
