Old 9th May 2003, 23:33   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Extreme OPS (Region 1) WideScreen or FullScreen Cheat Sheet
Extreme OPS [Region 1] WideScreen or FullScreen (Disabling Aspect Ratio Menu)
Courtesy of 2CL
Tools I used
IFOedit 0.95
DVD Decrypter in File Mode and selecting certain files
Title Information
Title 1: VTS_03 contains your WideScreen movie
Title 2: VTS_04 contains your FullScreen movie
__________________________________________________________
1. Create a folder named “XOPS” and a subfolder named “Files”.
2. Rip the following files for your desired aspect ratio to your “XOPS” folder.
  • WIDESCREEN: Rip all files except VTS_04_1.VOB to VTS_04_4.VOB
    FULLSCREEN: Rip all files except VTS_03_1.VOB to VTS_03_4.VOB
3. Open VIDEO_TS.IFO with IFOedit and press “Get VTS Sectors” buttons to load other IFOs.
4. Region Free every IFO and save commands if Region Code Encoding (RCE) is detected. I do this out of habit especially if I decided to use SmartRipper instead.
5. Backup all IFOs to “Files” subfolder. It’s a good practice to backup your original files prior to editing. In case you mess up, you can always copy over your these files over your badly edited one and then press your “Get VTS Sectors” button to refresh data in IFOedit.
6. Bypass Unwanted Stuff
In VIDEO_TS.IFO / VMG Overview / Language Menu Unit 1, do a Delete Playback on the following menus. Select and press your Delete Playback button. If successful, your number of Programs and Cells should be zero and (uses VOB-IDs: #) should disappear.
Language Menu Unit 1: [English]
Menu 4: [entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 1) English Copyright Warnings
Menu 5: [entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 2) English Disclaimer
Menu 6: [entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 3) French Copyright Warnings
Menu 7: [entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 4) French Disclaimer
7. Select your aspect ratio preference.
  • WIDESCREEN: Proceed to next step.
    FULLSCREEN: Go to step 15.
WIDESCREEN
8. Displaying Main Menu for Widescreen
Go to VIDEO_TS.IFO / VMGM_MAT / First Play PGC / PGC Command Table. Edit first jump command, which is Pre Command #2, as follows. Right click and select “ Edit Command” and pick (JumpSS_VTSM) Jump to Titleset Menu. Title Nr.: 1, TitleSet Nr.: 3, and Menu: root.
OLD > 2.Pre Command...(JumpSS VMGM) Jump to VMG PGC: 14..................................[30 06 00 0e 00 c0 00 00]
NEW > 2.Pre Command...(JumpSS VTSM) Jump to TitleSet(vts): 3, Title(ttn): 1, root-menu...[30 06 00 01 03 83 00 00]
Details: Each aspect ratio movie has its own menus so we just went to the one we want to keep.
9. Save VIDEO_TS.IFO and BUP
10. Bypassing the Aspect Ratio Menu
Go to VTS_03_0.IFO / VTSM_PGCI_UT / PGC-Menu_13 / PGC Command Table. Change the value of “Number of Pre Commands” the same as “Number of Post Commands”. Also change the “Number of Post Commands” to a value of zero. Double left click on values to edit. Below is the before and after results.
OLD>
Number of Pre Commands...........0................................................[0000]
Number of Post Commands..........6................................................[0006]
NEW>
Number of Pre Commands...........6................................................[0006]
Number of Post Commands..........0................................................[0000]
Details: By doing this, your Post Commands now are converted to Pre Commands and you will now bypass your video play which is your Aspect Ratio Menu. If you want to know about this method,I documented that in this thread.
11. Bypassing the Movie Rating before Movie
While in VTS_03_0.IFO, go to VTS Overview / Menu Language Unit and do a “delete playback” on following.
Menu 14: [entry only].......(Programs: 1) (Cells: 1) (uses VOB-IDs: 6)PG-13 Movie Rating
12. Save VTS_03_0.IFO & BUP
13. Get VTS Sectors
14. Press DVDPlay button to preview and test. Test also in PowerDVD or WinDVD if you got it.
That’s it for WideScreen. Burn what works for you.
FULLSCREEN
15. Displaying Main Menu for Widescreen
Go to VIDEO_TS.IFO / VMGM_MAT / First Play PGC / PGC Command Table. Edit first jump command, which is Pre Command #2, as follows. Right click and select “ Edit Command” and pick (JumpSS_VTSM) Jump to Titleset Menu. Title Nr.: 1, TitleSet Nr.: 4, and Menu: root.
NEW > 2.Pre Command...(JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, root-menu...[30 06 00 01 04 83 00 00]
16. Displaying Correct Menu after Previews
Go to / VMGM_PGCI_UT / PGC-Menu_9 / PGC Command Table. Right click on Pre Command #3 and change TitleSet Nr. from 3 to 4.
3.Pre Command...(JumpSS VTSM) Jump to TitleSet(vts): 3, Title(ttn): 1, root-menu.....[30 06 00 01 03 83 00 00 ]
3.Pre Command...(JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, root-menu.....[30 06 00 01 04 83 00 00 ]
Details: After your previews are done, it jumps to your Wide screen menu. We want it to go back to our fullscreen menu.
17. Save VIDEO_TS.IFO and BUP
18. Bypassing the Aspect Ratio Menu
Go to VTS_04_0.IFO / VTSM_PGCI_UT / PGC-Menu_13 / PGC Command Table. Change the value of “Number of Pre Commands” the same as “Number of Post Commands”. Also change the “Number of Post Commands” to a value of zero. Double left click on values to edit. Below is the before and after results.
Now we also want our movie to play when we click the Play Button instead of displaying the movie rating so while you are still here, edit Post Command #6 to jump to Title 1.
OLD >
Number of Pre Commands...........0..............................................[0000]
Number of Post Commands..........6..............................................[0006]
6.Post Command...(JumpVTS_TT) Jump to Title: 3..................................[30 03 00 00 00 03 00 00]
NEW >
Number of Pre Commands...........6..............................................[0006]
Number of Post Commands..........0..............................................[0000]
6.Pre Command...(JumpVTS_TT) Jump to Title: 1...................................[30 03 00 00 00 01 00 00]
Details: By doing this, your Post Commands now are converted to Pre Commands and you will now bypass your video play which is your Aspect Ratio Menu. If you want to know about this method,I documented that in this thread. Also, changing to Title 1 will play, Title 1 from this Titleset, not Title 1 from VIDEO_TS.IFO.
19. Bypassing the Aspect Ratio Menu in Scene Selection Menus
Go to VTS_04_0.IFO / VTSM_PGCI_UT / PGC-Menu_5 / PGC Command Table. Right click on Post Command #1 (below) and select “Delete Command”.
1.Post Command...If GPreg<15> == (cmp-val)<0> then (LinkPGCN) Link PGC 11.....[20 a4 00 0f 00 00 00 0b ]
20. Save VTS_04_0.IFO & BUP
21. Get VTS Sectors
22. Press DVDPlay button to preview and test. Test also in PowerDVD or WinDVD if you got it.
That’s it for FullScreen. Burn what works for you.
2COOL
