Thread Tools Display Modes
Old 2nd May 2003, 03:16   #1  |  Link
avih
Capture, Deinterlace
avih's Avatar
mplayer (ported from linux) available for win32: stand alone (no codecs needed)
mplayer ( http://www.mplayerhq.hu ) is one of the best video players for linux.
now you can try it on win32 (beta). MANY codecs (audio/video) are built in, so it's great as a reference player. very handy.
get it from ftp://ftp.mplayerhq.hu/MPlayer/relea...2003-03-24.zip
it's about 6M but also includes mencoder as a bonus...
(at the same directory there's also a more recent version, marked as 'dev' without mencoder, but when i tried it, i couldn't get OSD, which is important for ff/rw when there's no gui).
to play a clip, just drag-n-drop it onto the mplayer executable or run from the command line: mplayer <clip_name>.
mplayer does have GUI and skins, but these are not included in the basic package. i didn't try using skins on win32 (on linux i managed the task quite easily). so we're talking command line app here. (if you try and have success, posting your experience here would be nice).
here are some shortcut keys for controlling the playback:
(you can find these and many command line options at ftp://ftp.mplayerhq.hu/MPlayer/relea...a/mplayer.html )
<- and ->
seek backward/forward 10 seconds
up and down
seek backward/forward 1 minute
pgup and pgdown
seek backward/forward 10 minutes
< and >
backward/forward in playlist
HOME and END
go to next/previous playtree entry in the parent list
INS and DEL
go to next/previous alternative source (asx playlist only)
p / SPACE
pause movie (any key unpauses)
q / ESC
stop playing and quit
+ and -
adjust audio delay by +/- 0.1 second
/ and *
decrease/increase volume
9 and 0
m
mute sound
f
toggle fullscreen
w and e
decrease/increase panscan range
o
toggle between OSD states: none / seek / seek+timer
d
toggle frame dropping
v
toggle subtitle visibility
j
switch subtitle language
z and x
adjust subtitle delay by +/- 0.1 second
r and t
adjust subtitle position
i
set EDL mark
enjoy and keep handy
E8400/P43, 4G, GTX260+, FastCom TV+FM (BT878, Philips tuner, PAL), XP32/SP3.
Get Firefox. Get SmoothWheel Firefox extension.
avih is offline   Reply With Quote
Old 2nd May 2003, 04:58   #2  |  Link
BoNz1
BoNz1's Avatar
Wow, amazing. Thats all I can say. I never thought this would happen since mplayer devs are so anti redhat not to mention windows . mplayer is in my opinion the best player on the planet so it is sweet that we can now enjoy this beauty in a windows environment.
EDIT: Just as a side note. Imagine how nice this will be to put this onto a cd and have it autoplay. No need to install any codecs. Perfect to give to your friends who may not know too much about this video encoding. Only problem is that it is a little big, but you wouldn't need mencoder I guess. Just one more thing, I wonder if it supports matroska since the mplayer plugin was added to the cvs. Time to find out I guess.
BoNz1 is offline   Reply With Quote
Old 2nd May 2003, 05:58   #3  |  Link
BoNz1
BoNz1's Avatar
I compiled the simple gui for users who may not like the command line, I don't think it is available as an exe on the ftp. Just put it in the same directory. Now time to see if I can make some of those nice new skins work.
Old 2nd May 2003, 13:03   #4  |  Link
JimiK
just me
Did you attach this GUI? I'm just asking, because if so, then it hasn't been aproved for 6 hours (I don't mean to push anyone, I know that the mods have a life outside this forum).
What about your matroska tests? I won't be home for the weekend, so I won't be able to test it myself, still I would be very interested in this feature.
Best regards,
JimiK
JimiK is offline   Reply With Quote
Old 2nd May 2003, 13:46   #5  |  Link
avih
avih's Avatar
the compiled GUI (i didn't see the attachment either, but i compiled it myself. sources are at the same directory as the download) is very naive, partially broken imho, and doesn't give something the shortcut keys i mentioned on my 1st post can't do.
if you wanna try it, just memorize:
ESC: quit
space: pause (toggle)
f: full screen (toggle)
0,9: volume
+,-: adjust audio delay by 0.1 sec
right/left : ff/rw 10 sec
up/down: ff/rw 1 min
PgUp/PgDn: ff/rw 10 mins
and give it a try. the current win32 gui does more harm than good atm imho. otoh, mplayer skins are something to look for (they give the full GUI as it was ment to be). so again, any experience with skins on win32 will be a welcome addition to this thread.
Old 2nd May 2003, 17:04   #6  |  Link
BoNz1
BoNz1's Avatar
@avih, if it does more harm than good I can just remove it. I am not sure why all the buttons don't work but it seemed to compile ok. Probably most people would just memorize all the buttons anyway so it may be useless.
@JimiK, I will test for matroska support and post back.
EDIT: Matroska doesn't seem to work, I know there is support for it if you checkout from the cvs and build it, but there is no support for it in 0.9. I am not sure when mosu added support for it but maybe 2003 03 24 isn't recent enough.
Old 2nd May 2003, 17:10   #7  |  Link
avih
avih's Avatar
it's ok to stay online, although obviously u've encountered the same problems as me i'll try to make the skins work. don't hold your breath though...
Old 2nd May 2003, 18:20   #8  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
ftp://ftp.mplayerhq.hu/MPlayer/relea...CVS-030422.zip (from 2003-04-22)
Mr_Khyron is offline   Reply With Quote
Old 4th May 2003, 00:31   #9  |  Link
avih
avih's Avatar
after a short test (for the version i posted in the 1st post here), it seems the version is compiled WITHOUT gui support. that means no skins for this version. i didn't check the other (and later) version since it doesn't have OSD, as i mentioned.
on the good side though, the version i tested supports VCD/SVCD/AVI/OGM out of the box, which is pretty cool imho. i think it should also work for DVD, but i didn't test that. it does NOT seems to support XCD.
Old 4th May 2003, 21:49   #10  |  Link
BoNz1
BoNz1's Avatar
avih, that is what I assumed too that it was not compiled with gui support, I tried for about 1hr to get it to work but it wouldn't. So, I also tried the later one too and it didn't work either.
Old 6th May 2003, 23:38   #11  |  Link
slavickas
I'm Shpongled
slavickas's Avatar
have u tried http://movix.sf.net ?
slavickas is offline   Reply With Quote
Old 6th May 2003, 23:57   #12  |  Link
Sirber
Sirber's Avatar
Does it supports RV9?
download RealAnime and Bencos
Sirber is offline   Reply With Quote
Old 7th May 2003, 00:21   #13  |  Link
avih
avih's Avatar
i don't think it does as it is. however, there's a codec pack available for download. i didn't test it too much. i guess that any experience with formats playable with this player under win32 will be a welcome addition to this thread. including relevant setup of course.
Old 7th May 2003, 00:24   #14  |  Link
Sirber
Sirber's Avatar
If you use UPX on all files, MPlayer is 6 Mo.
I'll try the codec pack.
Old 7th May 2003, 00:25   #15  |  Link
BoNz1
BoNz1's Avatar
Yes, its very nice indeed, I really like it, but you do have to boot up a tiny version of linux which might not be too great for giving to friends.
Old 7th May 2003, 00:32   #16  |  Link
Sirber
Sirber's Avatar
Don't work if I get the codec pack. I put these where mplayer.exe is.
2001-04-10 15:39 61ÿ952 acelpdec.ax
2002-01-06 19:00 38ÿ912 alf2cd.acm
2001-01-21 20:49 88ÿ064 asusasv2.dll
1999-09-09 13:12 35ÿ840 asusasvd.dll
2000-08-02 01:28 150ÿ016 ativcr2.dll
2001-02-14 19:00 95ÿ292 atrac3.acm
2002-12-09 22:20 73ÿ766 atrc3260.dll
2002-04-20 19:58 312ÿ832 CLRVIDDC.DLL
2002-04-20 19:52 135ÿ168 clrviddd.dll
2002-12-09 22:20 65ÿ575 cook3260.dll
2002-04-21 05:22 81ÿ920 CtWbJpg.DLL
2002-06-24 19:40 681ÿ984 cygiconv-2.dll
2002-09-20 05:16 14ÿ848 cygintl-2.dll
2001-06-20 18:14 11ÿ264 cygintl.dll
2003-02-08 18:12 365ÿ384 cygwin1.dll
2002-01-20 20:42 24ÿ064 cygz.dll
2002-12-09 22:21 102ÿ437 drv13260.dll
2002-12-09 22:22 176ÿ165 drv23260.dll
2002-12-09 22:24 208ÿ935 drv33260.dll
2002-12-09 22:27 217ÿ127 drv43260.dll
2002-06-23 15:38 335ÿ694 freetype.dll
2000-03-09 15:15 110ÿ592 iccvid.dll
2001-05-03 09:29 307ÿ200 icmw_32.dll
2000-12-17 20:32 98ÿ304 imc32.acm
2000-07-13 23:52 199ÿ168 ir32_32.dll
1997-07-07 05:32 739ÿ328 ir41_32.dll
2000-03-09 15:17 755ÿ200 ir50_32.dll
2002-11-30 18:55 90ÿ112 jp2avi.dll
2003-05-06 18:13 876 keys.txt.txt
2002-04-21 14:13 338ÿ432 LCodcCMP.dll
2002-04-21 05:09 33ÿ040 lhacm.acm
2002-11-12 04:53 422ÿ912 m3jp2k32.dll
2003-03-24 22:26 2ÿ400ÿ741 mencoder.exe
2003-03-24 22:26 2ÿ531ÿ895 mplayer.exe
2000-07-30 00:36 17ÿ920 msadp32.acm
1999-05-05 17:22 10ÿ752 msg711.acm
1999-05-05 17:22 25ÿ088 msgsm32.acm
1999-04-15 14:10 424ÿ960 msms001.vwp
2001-10-11 09:10 79ÿ872 msnaudio.acm
2001-12-07 09:27 76ÿ112 msscds32.ax
2001-03-23 14:30 30ÿ208 msvidc32.dll
1999-04-15 14:10 218ÿ624 mvoiced.vwp
2002-12-22 15:56 36 NOTE
2002-04-20 21:30 49ÿ664 nsrt2432.acm
2001-11-16 15:10 45ÿ056 pclepim1.dll
1996-12-15 19:00 34ÿ304 qpeg32.dll
2002-04-20 21:32 299ÿ008 rt32dcmp.dll
2002-12-09 22:20 102ÿ439 sipr3260.dll
2002-09-09 14:01 131ÿ072 sp5x_32.dll
2003-05-06 18:32 0 test.txt
2002-04-23 09:51 175ÿ616 tm20dec.ax
2002-06-09 13:34 49ÿ152 tokr3260.dll
2002-04-21 08:38 110ÿ592 tsccvid.dll
2002-04-20 20:56 9ÿ488 tssoft32.acm
2001-07-03 10:01 241ÿ664 ubv263d+.ax
2002-11-07 14:13 94ÿ208 upx.exe
2002-03-12 09:23 76ÿ800 vgpix32d.dll
2001-05-03 09:34 122ÿ880 vivog723.acm
1999-04-15 10:10 56ÿ320 voxmsdec.ax
2001-09-22 09:17 462ÿ848 vp31vfw.dll
2002-10-29 12:03 409ÿ720 wma9dmod.dll
2002-10-28 10:11 410ÿ216 wmadmod.dll
2002-10-28 10:12 486ÿ504 wmspdmod.dll
2002-11-20 17:03 807ÿ032 wmv9dmod.dll
2002-10-28 10:12 807ÿ528 wmvdmod.dll
Also, mplayer.exe uses 100% CPU when playing a file...
Old 7th May 2003, 00:35   #17  |  Link
avih
avih's Avatar
actually, under the directory 'old', you'll be able to find mingw compiled versions (not so old at all btw), that are only 1M. and 850K with upx. worked for me, but it doesn't have osd when searching through the clip.
Old 7th May 2003, 07:05   #18  |  Link
Malow
In bytes we trust
Malow's Avatar
on my movies, it uses 100% of cpu too, is "normal"?
in a xp2000 , using low or hi resolutions movies in window mode..
with xvid and mp3..
Malow
Malow is offline   Reply With Quote
Old 7th May 2003, 08:01   #19  |  Link
FredThompson
FredThompson's Avatar
Maybe this will help you:
http://movix.sourceforge.net/
Curator of links at http://neuron2.net
(Yes, I know it's woefully out of date...)
Collecting 9/11, Afghan/Iraq, Mail Call, Trains, Cooking, Woodworking, Fighting Illini
FredThompson is offline   Reply With Quote
Old 7th May 2003, 08:28   #20  |  Link
slavickas
I'm Shpongled
slavickas's Avatar
it's not that scary to boot movix
btw tried http://videolan.org
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
