Old 4th April 2003, 11:06   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Reindeer Games (R1) Widescreen or Fullscreen Cheat Sheet
Reindeer Games[Region 1] Widescreen or Fullscreen Cheat Sheet
Courtesy of 2CL
This has been tested with success in IFOedit, PowerDVD, WinDVD, and my 2 standalones.
Tool I used
IFOedit 0.95
DVD Decrypter in File Mode and selecting certain files
Title Information
Title 1: VTS_05 contains your widescreen movie
Title 2: VTS_04 contains your fullscreen movie
__________________________________________________________
1. Create a folder named “RG” and a subfolder named “Files”.
2. Rip the following files for your desired aspect ratio to your “RG”folder.
WIDESCREEN: Rip all files except VTS_04_1.VOB to VTS_04_4.VOB
FULLSCREEN: Rip all files except VTS_05_1.VOB to VTS_05_4.VOB
3. Open VIDEO_TS.IFO with IFOedit and press “Get VTS Sectors” buttons to load other IFOs.
4. Just in case, region Free every IFO and save commands if region code commands were detected. Just a habit of mine.
5. Backup all IFOs to “Files” subfolder. It’s a good practice to backup your original files prior to editing. In case you mess up, you can always copy over your these files over your badly edited one and then press your “Get VTS Sectors” button to refresh data in IFOedit.
6. Bypass Copyright Warnings
In VIDEO_TS.IFO / VMG Overview / Language Menu Unit 1, do a Delete Playback on the following menus. Select and press your Delete Playback button. If successful, your number of Programs and Cells should be zero and (uses VOB-IDs: #) should disappear.
Menu 12:..[entry only].......(Programs: 1) (Cells: 1) (uses VOB-IDs: 3) Modified Format Note
Menu 19:..[entry only].......(Programs: 1) (Cells: 1) (uses VOB-IDs: 4) FBI Warning 1
Menu 20:..[entry only].......(Programs: 1) (Cells: 1) (uses VOB-IDs: 5) FBI Warning 2
7. Save VIDEO_TS.IFO
8. Bypass Dimension Logo
Go to VTS_02_0.IFO / VTS_PGCITI / VTS_PGC_1 / PGC Command Table. Edit the “Number of Pre Commands” value as value plus “Number of Post Commands” value. Edit as follows by double left clicking on value and enter sum value.
PGC Command Table:
OLD > Number of Pre Commands.....3
OLD > Number of Post Commands....1
NEW > Number of Pre Commands.....4
If you want to know more about this technique, check out this GUIDE.
9. Save VTS_02_0.IFO
10. Bypass Trailers Before the Menu
Go to VTS_07_0.IFO / VTS_PGCITI / VTS_PGC_3 / PGC Command Table. Edit the “Number of Pre Commands” value as value plus “Number of Post Commands” value. Edit as follows by double left clicking on value and enter sum value.
PGC Command Table:
OLD > Number of Pre Commands.....2
NEW > Number of Pre Commands.....3
By doing this, all your Post Commands will shift up become Pre Commands and your PGC Video (Trailers) will not play. Your Main Menu will now display upon DVD insert.
11. Save VTS_07_0.IFO
12. Select your aspect ratio preference.
  • WIDESCREEN: Proceed to next step.
    FULLSCREEN: Go to step 17.
WIDESCREEN
13. Getting Rid of Aspect Ratio Menu
Go to VTS_05_0.IFO / VTS Overview / Menu Language Unit, delete playback on the following. Select and highlight line and press “Delete Playback” button.
Menu 7: [entry only]......................(Programs: 1) (Cells: 1) (uses VOB-IDs: 6)
14. Save VTS_05_0.IFO
15. Get VTS Sectors
16. Press DVDPlay button to preview and test. Test also in PowerDVD or WinDVD if you got it.
That’s for widescreen. Burn what works for you.
FULLSCREEN
17. Getting Rid of Aspect Ratio Menu
Go to VTS_04_0.IFO / VTS Overview / Menu Language Unit:, delete playback on the following. Select and highlight line and press “Delete Playback” button.
Menu 7: [entry only]................................(Programs: 1) (Cells: 1) (uses VOB-IDs: 6)
18. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_7 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change Title Nr. from 1 to 2.
OLD > 3.Pre Command (JumpTT) Jump to Title: 1 [30 02 00 00 00 01 00 00 ]
NEW > 3.Pre Command (JumpTT) Jump to Title: 2 [30 02 00 00 00 02 00 00 ]
19. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_10 / PGC Command Table. Edit the following Pre Command #7 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 5 to 4.
OLD > 7.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 5, Title(ttn): 1, angle-menu
NEW > 7.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, angle-menu
20. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_11 / PGC Command Table. Edit the following Pre Command #4 as below. Right click on line and select “Edit Command”. Change Title Nr. from 1 to 2.
OLD > 4.Pre Command (JumpTT) Jump to Title: 1 [30 02 00 00 00 01 00 00 ]
NEW > 4.Pre Command (JumpTT) Jump to Title: 2 [30 02 00 00 00 02 00 00 ]
21. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_13 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 5 to 4.
OLD > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 5, Title(ttn): 1, root-menu
NEW > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, root-menu
22. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_14 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 5 to 4.
OLD > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 5, Title(ttn): 1, angle-menu
NEW > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, angle-menu
23. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_15 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 5 to 4.
OLD > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 5, Title(ttn): 1, audio-menu
NEW > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, audio-menu
24. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_16 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 5 to 4.
OLD > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 5, Title(ttn): 1, sub-picture-menu
NEW > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, sub-picture-menu
25. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_17 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 5 to 4.
OLD > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 5, Title(ttn): 1, chapter-menu
NEW > 3.Pre Command (JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, chapter-menu
26. Save VIDEO_TS.IFO
27. Get VTS Sectors
28. Press DVDPlay button to preview and test. Test also in PowerDVD or WinDVD if you got it.
That’s for fullscreen. Burn what works for you.
2COOL
