Old 4th April 2003, 08:34   #1  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
The Wild Thornberry's Movie (R1) Widescreen or Fullscreen Cheat Sheet
The Wild Thornberry’s Movie [Region 1] Widescreen or Fullscreen Cheat Sheet
Courtesy of 2CL
This has been tested with success in IFOedit, PowerDVD, WinDVD, and my 2 standalones.
Tool I used
IFOedit 0.95
DVD Decrypter in File Mode and selecting certain files
Title Information
Title 1: VTS_02 contains your fullscreen movie
Title 2: VTS_04 contains your widescreen movie
__________________________________________________________
1. Create a folder named “TWTM” and a subfolder named “Files”.
2. Rip the following files for your desired aspect ratio to your “TWTM”folder.
WIDESCREEN: Rip all files except VTS_02_1.VOB to VTS_02_4.VOB
FULLSCREEN: Rip all files except VTS_04_1.VOB to VTS_04_4.VOB
3. Open VIDEO_TS.IFO with IFOedit and press “Get VTS Sectors” buttons to load other IFOs.
4. Region Free every IFO and save commands if region code commands were detected.
5. Backup all IFOs to “Files” subfolder. It’s a good practice to backup your original files prior to editing. In case you mess up, you can always copy over your these files over your badly edited one and then press your “Get VTS Sectors” button to refresh data in IFOedit.
6. Bypass Copyright Warnings
In VIDEO_TS.IFO / VMG Overview / Language Menu Unit 1, do a Delete Playback on the following menus. Select and press your Delete Playback button. If successful, your number of Programs and Cells should be zero and (uses VOB-IDs: #) should disappear.
Menu 2:...[entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 1) Copyright Warning
Menu 4:...[entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 2) Copyright Warning
Menu 6:...[entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 3) Copyright Warning
Menu 15:..[entry only]...(Programs: 1) (Cells: 1) (uses VOB-IDs: 5) PG Movie Rating
7. Save VIDEO_TS.IFO
8. Bypass Trailers Before the Menu
Go to VTS_05_0.IFO / VTS_PGCITI / VTS_PGC_3 / PGC Command Table. Edit the “Number of Pre Commands” value as value plus “Number of Post Commands” value. Edit as follows by double left clicking on value and enter sum value.
PGC Command Table:
OLD > Number of Pre Commands.....2
OLD > Number of Post Commands....2
NEW > Number of Pre Commands.....4
By doing this, all your Post Commands will shift up become Pre Commands and your PGC Video (Trailers) will not play. Your Main Menu will now display upon DVD insert.
9. Save VTS_05_0.IFO
10. Select your aspect ratio preference.
  • WIDESCREEN: Proceed to next step.
    FULLSCREEN: Go to step 25.
WIDESCREEN
11. Getting Rid of Aspect Ratio Menu
In VTS_04_0.IFO / VTS Overview / Menu Language Unit, delete playback on the following. Select and highlight line and press “Delete Playback” button.
Menu 11: [entry only]......................(Programs: 1) (Cells: 1) (uses VOB-IDs: 7)
12. Bypassing Movie Intros
Go to VTS_04_0.IFO / VTS_PGCITI / VTS_PGC_1 / Cell PlayBack:. Edit Cell_1’s entry point sector value as 12842, which is the exact value for Cell_4. Cell_4 is where the movie actually starts. Edit by double-left clicking on line and enter new value.
OLD > Cell_1: entry point sector 0
NEW > Cell_1: entry point sector 12842
13. Fixing Movie Resume After Root Menu Pressed During Movie Play
Go to VTS_04_0.IFO / VTSM_PGCI_UT / PGC-Menu_11 / PGC Command Table:. Hexedit Post Commands #6 and 12 as below. To hexedit, double left click on line, click in HexEditor Module, change value, and press OK.
OLD > 6.Post Command....If GPreg<6> == (cmp-val)<2> then (LinkPGCN) Link PGC 12....[20 a4 00 06 00 02 00 0c]
NEW > 6.Post Command....If GPreg<6> == (cmp-val)<0> then (LinkPGCN) Link PGC 12....[20 a4 00 06 00 00 00 0c]
OLD > 12.Post Command...If GPreg<6> == (cmp-val)<2> then (LinkPGCN) Link PGC 13....[20 a4 00 06 00 02 00 0d]
NEW > 12.Post Command...If GPreg<6> == (cmp-val)<0> then (LinkPGCN) Link PGC 13....[20 a4 00 06 00 00 00 0d]
14. Save VTS_04_0.IFO
15. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_1 / PGC Command Table. Edit the following Pre Commands #7 and 12 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 2 to 4.
OLD > 7.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, root-menu.[30 06 00 01 02 83 00 00]
NEW > 7.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, root-menu.[30 06 00 01 04 83 00 00]
OLD > 12.Pre Command.(JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, root-menu.[30 06 00 01 02 83 00 00]
NEW > 12.Pre Command.(JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, root-menu.[30 06 00 01 04 83 00 00]
16. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_3 / PGC Command Table. Edit the following Pre Command #7 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 2 to 4.
OLD > 7.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, angle-menu.[30 06 00 01 02 86 00 00]
NEW > 7.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, angle-menu.[30 06 00 01 04 86 00 00]
17. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_9 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 2 to 4.
OLD > 3.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, root-menu..[30 06 00 01 02 83 00 00]
NEW > 3.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, root-menu..[30 06 00 01 02 83 00 00]
18. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_10 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 2 to 4.
OLD > 3.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, angle-menu.[30 06 00 01 02 86 00 00]
NEW > 3.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, angle-menu.[30 06 00 01 04 86 00 00]
19. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_11 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change Title Nr. from 1 to 2.
OLD > 3.Pre Command..(JumpTT) Jump to Title: 1.........................................[30 02 00 00 00 01 00 00]
NEW > 3.Pre Command..(JumpTT) Jump to Title: 2.........................................[30 02 00 00 00 02 00 00]
20. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_14 / PGC Command Table. Edit the following Pre Command #8 as below. Right click on line and select “Edit Command”. Change TitleSet Nr. from 2 to 4.
OLD > 8.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 2, Title(ttn): 1, angle-menu.[30 06 00 01 02 86 00 00]
NEW > 8.Pre Command..(JumpSS VTSM) Jump to TitleSet(vts): 4, Title(ttn): 1, angle-menu.[30 06 00 01 04 86 00 00]
21. Go to VIDEO_TS.IFO / VMGM_PGCI_UT / PGC-Menu_11 / PGC Command Table. Edit the following Pre Command #3 as below. Right click on line and select “Edit Command”. Change Title Nr. from 1 to 2.
22. Save VIDEO_TS.IFO
23. Get VTS Sectors
24. Press DVDPlay button to preview and test. Test also in PowerDVD or WinDVD if you got it.
That’s for widescreen. Burn what works for you.
FULLSCREEN
25. Getting Rid of Aspect Ratio Menu
In VTS_02_0.IFO / VTS Overview / Menu Language Unit, delete playback on the following. Select and highlight line and press “Delete Playback” button.
Menu 11: [entry only]..............................(Programs: 1) (Cells: 1) (uses VOB-IDs: 7)
26. Bypassing Movie Intros
Go to VTS_02_0.IFO / VTS_PGCITI / VTS_PGC_1 / Cell PlayBack:. Edit Cell_1’s entry point sector value as 12842, which is the exact value for Cell_4. Cell_4 is where the movie actually starts. Edit by double-left clicking on line and enter new value.
OLD > Cell_1: entry point sector.0
NEW > Cell_1: entry point sector.16102
27. Fixing Movie Resume After Root Menu Pressed During Movie Play
Go to VTS_02_0.IFO / VTSM_PGCI_UT / PGC-Menu_11 / PGC Command Table:. Hexedit Post Commands #6 and 12 as below. To hexedit, double left click on line, click in HexEditor Module, change value, and press OK.
OLD > 6.Post Command...If GPreg<6> == (cmp-val)<2> then (LinkPGCN) Link PGC 12........[20 a4 00 06 00 02 00 0c]
NEW > 6.Post Command...If GPreg<6> == (cmp-val)<0> then (LinkPGCN) Link PGC 12........[20 a4 00 06 00 00 00 0c]
OLD > 12.Post Command..If GPreg<6> == (cmp-val)<2> then (LinkPGCN) Link PGC 13........[20 a4 00 06 00 02 00 0d]
NEW > 12.Post Command..If GPreg<6> == (cmp-val)<0> then (LinkPGCN) Link PGC 13........[20 a4 00 06 00 00 00 0d]
28. Save VTS_02_0.IFO
29. Get VTS Sectors
30. Press DVDPlay button to preview and test. Test also in PowerDVD or WinDVD if you got it.
That’s for fullscreen. Burn what works for you.
2COOL
