#1 | Link |
AvisynthEditor 0.3 beta
# .def files replaced with DVX .xml files (great work Dolemite/Seewen !) # 'Save As' bug should be fixed # Comment/Uncomment block (need some fixes) # Recent files # Filter description/help window # Filter Treeview modes: Plugins and Categories # commandline args: # -i: input filename # -ot: opener title (for external call) # -oh: opener text handle (use Spy++ to test) # Example: # "C:\Program files\AvisynthEditor\AvisynthEditor.exe" -i "C:\tmp\script.avs" -ot "VirtualDubMod" -oh 001059C # -> Start AvisynthEditor, edit script then click "Back to VirtualDubMod". @sh0dan: I still have problem with TAB key, I'll try to find a way to handle your request ![]() have fun !! Screenshot: http://www.lalternative.org/img/AvisynthEditor.gif Download: http://www.lalternative.org Best regards,
akabob mailto:akabob@lalternative.org x2real - AvisynthSwitcher - AvisynthEditor http://www.lalternative.org http://www.autorv9.fr.st Last edited by akabob; 25th March 2003 at 09:18. |
#2 | Link | |
Avisynth 3.0 Developer
Since we are considering to have 3.0 export its filters info as xml (you will probably like it ) can you tell me more ?
#3 | Link |
Retired, but still around
Problem report:
XP/SP1 - Right click on avisynth script > select open with avisyntheditor > avisyntheditor opens, but with a blank script Old problems tested: XP/SP1 "Save AS" problem seems fixed
#4 | Link | ||
#5 | Link |
DDogg: as AvisynthEditor now takes commandline args, it's necessary to add '-i ' flag to open a file.
This should be the case if you register .avs files from the AvisynthEditor\Options menu. (will update registry) Then, double-click on an .avs to open it. @Dolemite: This would be great that developpers include .xml files. But it's quite simple to create such ones. Maybe Doom9 community could help us ?
akabob mailto:akabob@lalternative.org x2real - AvisynthSwitcher - AvisynthEditor http://www.lalternative.org http://www.autorv9.fr.st |
#6 | Link | |
#7 | Link | |
As far as I know a lot plugin authors adopted Donald Graft's way to describe the plugin in a htm file which is very good. Maybe if popular authors start to provide a XML file others will follow them users should coordinate with seewen, I will ask him how they can contact him |
#8 | Link |
Next AvisynthEditor release may also include an xmldef editor
#9 | Link | |||
Nonetheless, the concept behind all this is really a good idea, for instance with a graphical building of the filter chain (a la Khoros or Graphedit, depending on your taste ![]() EDIT Quote:
![]() (but I don't recall having those details in the parameters, yet it makes more sense) Which makes me think that whenever possible, plugin authors should include a ressource file to specify the dll version, so that it can be retrieved (by a program or by a user using an old version Last edited by Kurosu; 31st March 2003 at 21:28. |
#11 | Link | |
#12 | Link | |
#14 | Link | |
#15 | Link | |
VDubMod Devel
Re: AvisynthEditor 0.3 beta
![]() It will probably not work atm from external apps due to the way memory allocation/deallocation is handled, but I will try to change that for 1.5.
VirtualDubMod [SourceForge : Tracker/DL] (FAQ, Some rules) Be sure to also download the latest DLL package or get the all inclusive package! Before you post questions, please read the VirtualDub and/or VirtualDubMod FAQ. If you have a bug report or feature request for VirtualDubMod, be sure to read the rules first. We give 100% of your donations to the Open Source community |
#16 | Link |
In fact, using -oh with VirtualDubMod is just an example (the first I thought about lol), I haven't tested it yet.
I've only tested -oh with NotePad and Scite (www.scintilla.org)
#17 | Link |
I've been looking around at the editor and it's cool.
I'm a novice with avisynth, I can use it for my needs. I have a couple of questions. I've played around with adding some of the core function calls into the core xml file. And XML does suck to write by hand... is there some editor plugin for the rules descriptors? Any plans to add features for colorspace requirements or did I miss that? For example special rules for parameters is specific color spaces, like YU12/YUY2 even boundries for clips and such? Plugins which only work in specific colorspaces, etc. Is the helpfile tag suppose to link you to the helpfile on the avisynth.org webpage correct? Lastly, how is this suppose to be used? # Resize: 1:1 | 1:33(4:3) | 1:66 | 1:77 | 1:85 | 2:35 | Free w/keep AR I couldn't understand exactly what this is for. Is it ment to do the same as a filter macro function, ResizeTo-PreserveAspect-AddBorder, etc? Thanks! Last edited by Jeff D; 15th April 2003 at 09:13. |
#18 | Link | |
#19 | Link |
Posts: n/a
hi Dolemite
akabob posted "External XMLPlugin Editor is almost complete and should be released as a single file later this week" in AvisynthEditor 0.4 thread: http://forum.doom9.org/showthread.php?s=&threadid=51110 ! |
#20 | Link |
I didn't do much yet, I was just playing around, only like 3 calls.
If you want I'll do more while while I'm waiting on the PC to do other things. Although I wasn't sure about what to do for parameter specs, for example I tried AddBorders which had the requirements of even pixel values for left and right when in YU12/YUY2 colorspaces. The tag for step didn't seem to make any change in the function description. Is that tag like the help tag and not yet fully supported? Or am I doing something wrong? BTW, I really like the reload defs option! |
| Thread Tools | |
| Display Modes | |
