#1 | Link |
Dizzin It Fizzast Fo Yizz
New Major Release: DoItFast4U! 1.1.0
DoItFast4U! v.1.1.0 is now available at http://doitfast4u.doom9.org/DoItFast4U.v.1.1.0.exe.
Changes in version 1.1.0: - Revamped GUI uses Tree format to display DVD contents. - Added ability to select non-contiguous PGCs for demuxing. - Added audio delay to .ac3 filenames. - Added End PGC duration info to the VTS Attributes section. - Calculates bitrate needed for main movie VTS depending on the bitrate you choose for extras VTSes. - Fixed PAL .sst bug. - .sst converter is given full path of .idx to remove compatibility issues. - Added control for user to choose bitrate to encode extras VTSes. - If a VIDEO_TS is created it creates a CCEdata.txt containing a list of all .avses and all calculated bitrates. For use with DoCCE4U from BBWoof! - Reduced CPU usage while waiting for apps to finish. - Added ability to get size of assets in subdirectories with the DVDCalc. - Right-click on VTS now opens the corresponding .ifo in ifoedit. - Vobid subs/cc demux fixed. (cc closes automatically now). - Vobid subs/cc demux fixed. (VTSes missing _0.vob files still demux). - Vobid subs/cc demux fixed. (.idx with language not specified still demux). - Clicking on a PGC changes focus to corresponding VTS. - HDD Demux now outputs files to <workingdirectory>\Demux. - HDD Demux now does multiple VTSes. - VobID Sub ripping no longer gives empty .idx/.sub. - Sub processing now removes any .ssts that do not contain bitmaps - (referred to in log window as 'empty .ssts'). - Stream selection now available for Audio and Subs (Per VTS). - GUI Resized to fit 800 x 600 desktops. - Pure interlaced NTSC detection implemented, .avs still uses - Decomb/Telecide/Decimate but possibility is there to use a better .avs.. - Audio files diagnosed for bitrate which is then added to the filename. - Improved memory usage. - Multiple Main Movie VTSes detected (episodic DVDs, etc). - Ability to cancel and close opened applications during mid-demux added. - Added an AVS Editor for customizing the .avs scripts. (use #NOPULL in the script to specify to add ".nodrop" to the filenames). - Create VIDEO_TS no longer locks the main window while executing. - Added settings for adjusting number of passes to use in CCE for main VTS and extras VTSes. - VobID Demux no longer gives multiple audio for the same VobID. - Added more Integration with DoCCE4U, including ability to open/start automatically. - Basic User Guide rewritten. - Added audio notification for completion/errors. - Bitrate calculation used the last chosen DVD Size from the DVD Calc for it's computations. - VobID Demux uses intelligent filesize detection to determine incomplete vobids to delete. - CCE Chapter list now forced to output always. - Log file always output to root of project. Known Issues: - In some instances, 4:3 VTSes from PAL DVDs cause the sub demux to crash. If anyone experiences this, please email me with the exact title of the DVD that is doing it! If someone could donate an original DVD that has this problem, that would also be helpful!
"Those that can't... butcher. Those that can... DoItFast4U!" DoItFast4U! v.1.4.7 now available with: • Lightning fast subripping (up to 100x faster) •Choice of DoCCE4U/BatchCCE •DVD2AVIdg useable by ReAuthorist •Bitrate control for use with NuMenu4U •Extras Bitrate applied to smaller PGCs in Main VTS •ScenAid integration •Right-Click Menus •Minimize to Systray •Improved Deinterlace Scripts See: http://www.doitfast4u.com. Use the donation link on the above URL or the app itself to make a $15+ donation and join the VIP list today! Last edited by Eyes`Only; 24th March 2003 at 02:52. |
#2 | Link |
ScenAid
![]() Join Date: Mar 2003
For those of you who can't download:
http://doitfast4u.doom9.org/DoItFast4U.v.1.1.0.exe not http://doitfast4u.doom9.org/DoItFast4U.v.1.1.0.exe. |
#3 | Link |
w00psie! Well, ain't this a nice beginning to the thread! LOL
"Those that can't... butcher. Those that can... DoItFast4U!" DoItFast4U! v.1.4.7 now available with: • Lightning fast subripping (up to 100x faster) •Choice of DoCCE4U/BatchCCE •DVD2AVIdg useable by ReAuthorist •Bitrate control for use with NuMenu4U •Extras Bitrate applied to smaller PGCs in Main VTS •ScenAid integration •Right-Click Menus •Minimize to Systray •Improved Deinterlace Scripts See: http://www.doitfast4u.com. Use the donation link on the above URL or the app itself to make a $15+ donation and join the VIP list today! |
#4 | Link |
Germanicus
servus...
First of all, congratulations for 1.1.0.0 ![]() Testet DIF4U with StarWars EP2. MultiPGC movie with a lot of subtitle and 2 Angle. I think the right movie for testing performance of newer version ![]() (singlePGC aren´t a problem for DIF4U, so I decided a more pretentious movie for testing )Just selected VTS01 for DIF4U: (6 subtitle; 3 audio in every PGC; mounted ISO) Vobsub PGC: all Split by VobID Well, it´s work, but very slow ![]() PGC 1 have a lenght about 2 hours, so a longer vobsub duration is ok. But PGC 2-13 are just a view seconds and duration nearly as long as PGC 1! So the overall duration are about 2.5 hours! If I check +CC too, this overall duration will rise up dramaticly! I don´t know why it takes so much time, but I think ripping subtitle manualy by SubRip will take less time than this one. Do you have any ideas why vobsub need so much time for extract subtitles/+cc ? Hardware P4 2.4 Ghz 512MB Ram and fast HDDs. Second run: Without subtitle/+cc and vobsubPGC creation, Only split by VobID selected. Overall duration: 25 minutes! BTW about the green progress beam: This is for every step new, right? A new progress beam for full duration would be great ![]() New Bug: Could you use IFOEdit 0.95 for DIF4U? My version corrupt sometimes, cause 0.94 on system. http://forum.doom9.org/showthread.ph...t=ifoedit+0.94
cya fourtyfour Last edited by fourtyfour; 24th March 2003 at 15:02. |
#5 | Link |
As usual, the big intent was to get functionality working first, then work on speed improvements. VobID has long had a history of not working completely correct, so I attempted to get that fixed as well as I could (new detection of duplicate vobids and their sizes, etc).
Vobsubbing takes a while because it goes byte by byte through the file, for complete accuracy. Although it does take a while, I think you'll find there's not a more accurate utility like this out there in the world! Oh as for ifoedit, simply replace the ifoedit.exe in the DoItFast4U install directory with whatever version you desire, keeping the filename the exact same. I'll add a newer version to future rlses. I do plan to do more detection and not vobsub if you demux a duplicate vobid, but that's tricky and I didn't want to delay 1.1.0 by tackling that first. Just FYI: To-Do List= - PGC size threshold (automatically deselect PGCs that are smaller than xxx mb) - AVS 2.5 support (oooh this one should be a nice bit of fun) - (possible feature, not sure yet) ability to configure per-PGC instead of VTS. This one could make it a lot more lengthy of a process to configure DIF4U before hitting "Do It!" though ![]() - Better detection for when to vobsub and when not to. - Think of more wacky ideas to make life better for us perfectionists!
#6 | Link |
quote from me in the other thread:
right just finnished my first rip with, do it fast 4 u, do CCE 4 u and reauthorist. And heres what I got to say: The main movie of spiderman turned out bad(not terrible though, stilll quite good), too blocky. I don't think there is enough room in 4.3gbs to keep the extras and the main film. oh.. just had a tought, what about resizing the extras to 352x576???? that would really save bitrate, and maybe a bit of temporal smoother at 2,2. we could probably get the extras down to an avg of 1000 and still get them looking great. As for the extras!! Well ALL the extras were in interlaced format and do cce for you dosn't have an interlaced button so they came out very very bad! However I think we shall find a way around this. Surely it must say in the ifo file or something that the video is interlaced as I think the dvd player needs to know this to play back the file properly. Ah yes, and Also about the CCE-no-avs thingy... I will re-rip T2 later today to see if it does do this. Baker ----------------------------------------- Well first off I am a bit dissapointed you never replied to this as obviously detecting interlaced material is a big thing to use pal users... And I would like your opinion on re-encoding the extras also.(perhaps I should be bringing the progressive option up with bb woof first though....) Anyway the real reason I am posting this is to tell you that the AVS from the still frame thingy is called "VTS__04_P02.16~9_1" and has no indictation that it should not be re-encoded. baker Last edited by baker; 24th March 2003 at 19:49. |
#7 | Link | ||
I didn't respond to your previous posting on purpose, as when I get irritated, it's really better off if I don't post. I'm calmed down a bit now so...
The quality issues show lack of knowledge of how to do things, not something I can control. Users that have been using this tool and our methods know that our results far surpass anything you can do with DVD2One or the like. So when you say your quality was terrible, that shows that you did something wrong. What? I don't know, but I have an idea. Spiderman is a very complex DVD with a lot of reused vobids. Reauthoring by vobid is the only way to get the correct size/quality from it, as far as I remember. Quote:
That still frame was one frame? The flag to not cce is attached to the .avs file usually (avs-no.cce). Please attach or email to me and I'll see why it wasn't flagged.
"Those that can't... butcher. Those that can... DoItFast4U!" DoItFast4U! v.1.4.7 now available with: • Lightning fast subripping (up to 100x faster) •Choice of DoCCE4U/BatchCCE •DVD2AVIdg useable by ReAuthorist •Bitrate control for use with NuMenu4U •Extras Bitrate applied to smaller PGCs in Main VTS •ScenAid integration •Right-Click Menus •Minimize to Systray •Improved Deinterlace Scripts See: http://www.doitfast4u.com. Use the donation link on the above URL or the app itself to make a $15+ donation and join the VIP list today! Last edited by Eyes`Only; 24th March 2003 at 21:45. |
#8 | Link |
Germanicus
servus...
Hey buddie, your tool works perfect. ![]() That´s all minor things. ![]() About the ToDo: Maybe an "advanced section" could help. So everyone who don´t know exactly what he can do could set vobsub all etc. and start ´do it´. If someone will have more possibilities for faster processing, he can use advanced options like to choose PGCs (the VTS/PGC Tree visible/unvisible with advanced button) So everyone can choose what he want. ![]() About Ifoedit: OK, I thought there is some code in DIF4U for opening the 0.94 ![]() A optical bug: Could you rename these file: VTS__01_-81V01-448K-[0ms]-ch6Deutsch.AC3 to VTS__01_-81-V01-448K-[0ms]-ch6Deutsch.AC3 ? It´s better if you have more than one PGC. That´s all for the moment
cya fourtyfour Last edited by fourtyfour; 24th March 2003 at 23:20. |
#11 | Link |
my 2 cents...
I must admit, I wasnt a fan of this program when it first came out, but once it started using CCE I changed my mind quickly
. Congrats on a great program !.My idea is to implement templates for the ripping, for instance, one could choose how they want the DVD ripped. Example : 1. Main Movie only 2. Main Movie + Menus 3. Main Movie + All Extras (complete) And then maybe an advanced options for the templates, so one can simply select streams to strip, and/or Extras to skip. As for me, I would like to get the Main Movie, with sterams I want, and the Menu . I am all quality hehe.Hope this post gives you some ideas on improvement. Anyways, good luck in your programming .v/r F4T4L
F4T4L 3RR0R |
#12 | Link |
Super duper
Re:
Thanks for a great program... and keep up the good work! I feel this is the way to go with reauthoring DVD's the right way (didn't take me long to toss IC and D21)!
Thanks again! (now if I could only figure out how to reauthor Mallrats) - Jeremy |
#13 | Link |
cce.txt file glitch
ok i was doing a movie and i set extras to 5 and main movie to 4 and noticed when the process completed ripping that the cce.txt file was saying all of the pgcs was on 5 pass even the main movie...
correct me if im wrong but on the movie shouldnt it be 4 pass if i set it to it.... Congrads on a masterpice of software...... D.. |
#14 | Link |
cont
forgot to ask what does this mean in the doit fast 4 u subtitles section
instead of a language it shows this (..) does this man it doesnt know it or is this a forced sub....or what could someone please explain what it means..... thanx D.. |
#15 | Link | |
Tuna of the Dirt
http://www.kisdigital.com |
#16 | Link | |||||
Thanks for all the support guys. Reminder.. If anyone has one of those 2 items I am looking for on my homepage lying around, I could really use them!
![]() Quote:
(Buffy lingo on purpose) 'nuff said!Quote:
OK I've answered all the postings, time for some eggs and bacon... *yawn*
"Those that can't... butcher. Those that can... DoItFast4U!" DoItFast4U! v.1.4.7 now available with: • Lightning fast subripping (up to 100x faster) •Choice of DoCCE4U/BatchCCE •DVD2AVIdg useable by ReAuthorist •Bitrate control for use with NuMenu4U •Extras Bitrate applied to smaller PGCs in Main VTS •ScenAid integration •Right-Click Menus •Minimize to Systray •Improved Deinterlace Scripts See: http://www.doitfast4u.com. Use the donation link on the above URL or the app itself to make a $15+ donation and join the VIP list today! Last edited by Eyes`Only; 25th March 2003 at 21:01. |
#17 | Link |
ok quick ???
ok for those subs i was telling you about (..) there was like um 20 of them but there wasnt anything in them.......they were empty subs....
one thing i like is thta you incorporatewd the forced sub.....sst script that is cool the other thing is that doitf4u and docce4u calculate the whole project to be the right size in the end.... i noticed in the guides from doom and tril;ight that they do extras seperately and the movie seperately in scenarist because of the different aspect ratios... but my question is can you do everyhting in scenarist even the extras and main movie in one go and compile a final project of vob files even if the aspect ratio is different between the extras and main movie....coz when u set up scenarist it ask are you doing a 16.9 film or 4.3 film...... this is one major concern for me.... thankyou D |
#18 | Link |
From what I can tell, that aspect ratio it asks is only for menus.. Scenarist diagnoses all your m2vs and labels them the correct aspect ratio. Yes, you can do multiVTS in Scenarist without issues, I do it all the time.
#19 | Link |
cont
just a curiosity....i did training day and all worked great in the machine and on power dvd and ifoedit but when i burnt it to disk it doesnt play properly... i think i must have done somehting wrong and i was checking pgc audio and noticed that the starting sector on all audios were on 0.....so im guessing i must have did a wrong calculation somewhere
quickky ?? what setting should i use on ifo update.... |
| Thread Tools | |
| Display Modes | |
