23rd February 2003, 12:10 | #1 | Link |
Retired AviSynth Dev ;)
BeSweet crash uding multiple AC3 for input.
Using the latest beta I get a crash:
Command: Code:
"C:\apps\BeSweet\BeSweet.exe" -core( -input "dune.lst" -output "dune128-kbit.mp3" -logfile "C:\apps\BeSweet\BeSweet.log" ) -ota( -G max ) -lame( --scale 1 -p --alt-preset 138 ) Code:
-core( -input "C:\temp\dune\dune01 AC3 T04 2_0ch 192Kbps DELAY 0ms.ac3" ) -core( -input "C:\temp\dune\dune02 AC3 T04 2_0ch 192Kbps DELAY 0ms.ac3" ) -core( -input "C:\temp\dune\dune03 AC3 T04 2_0ch 192Kbps DELAY 0ms.ac3" ) Code:
BeSweet v1.5b16 by DSPguru. -------------------------- Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu). Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org) Using lame_enc.dll v1.28 (4/6/2002), Engine 3.92 <http://www.mp3dev.org/>. Logging start : 02/23/03 , 12:03:22. C:\apps\BeSweet\BeSweet.exe -core( -input dune.lst -output dune128-kbit.mp3 -logfile C:\apps\BeSweet\BeSweet.log ) -ota( -G max ) -lame( --scale 1 -p --alt-preset 138 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\temp\dune\dune01 AC3 T04 2_0ch 192Kbps DELAY 0ms.ac3 [00:00:00:000] | Output: dune128-kbit.mp3 [00:00:00:000] | Floating-Point Process: Yes [00:00:00:000] | PostGain normalize to : 0.97 [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- LAME ------- [00:00:00:000] | 'abr 138' preset is used [00:00:00:000] +--------------------- I've tried several ways of listing files (tried plain filenames, quotes, no quotes), but with no luck. Only workaround for me is to decompress to WAVE files and encode them from there.
Regards, sh0dan // VoxPod |
23rd February 2003, 20:26 | #2 | Link |
BeSweet Author
10x !
btw - i believe v1.4 would work..
FAQs : BeSweet, Audio :readfaq: Homepage : DSPguru's Webpage http://dspguru.notrace.dk/cs.gif Guides : Multilingual Guides of my tools http://dspguru.notrace.dk/1zhelp.gif |
6th March 2003, 10:50 | #3 | Link |
Using list files with AVI's causes AV
I just tried using this list file with BeSweet 1.5b16:
the.ring.dvdrip.cd1.xvid-deity.avi the.ring.dvdrip.cd2.xvid-deity.avi When I start besweet it immidiatly crashes. The log file looks like this: BeSweet v1.5b16 by DSPguru. -------------------------- Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu). Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org) Logging start : 03/05/03 , 16:33:59. besweet -core( -input besweet.lst -2ch -output the.ring.dvdrip.cd2.xvid-deity_output.wav -logfile g:\besweet.log ) -azid ( -c normal )-ota ( -norm 0.95 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : the.ring.dvdrip.cd1.xvid-deity [00:00:00:000] | Output: the.ring.dvdrip.cd2.xvid-deity_output.wav [00:00:00:000] | Floating-Point Process: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +--------------------- I hope you can fix it for the next beta.
This is my signature |
24th March 2003, 00:01 | #4 | Link |
BeSweet crashes on lst-input
I downloaded BeSweet 1.5b16 (http://dspguru.notrace.dk/BeSweetv1.5b16.zip) VOBInput.dll v 1.3 (http://dspguru.notrace.dk/VOBInput.zip) Azid.dll 1.8 (http://mitglied.lycos.de/darkav/down...id_dll-1.8.rar) Unpacked all files in in C:\temp\BeSweet Tried to convert a VOB-file to mp3 - which works fine: C:\temp\BeSweet>C:\temp\BeSweet>besweet -core ( -input 01.VOB -output 01.mp3 -logfile test.log ) The log file looks like this: BeSweet v1.5b16 by DSPguru. -------------------------- Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org) Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu). Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using lame_enc.dll v1.22 (6/7/2001), Engine 3.89 <http://www.mp3dev.org/>. Logging start : 03/23/03 , 23:46:15. besweet -core ( -input 01.vob -output 01.mp3 -logfile test.log ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : 01.vob [00:00:00:000] | Output: 01.mp3 [00:00:00:000] | Substream ID: 0x80 [00:00:00:000] | Floating-Point Process: No [00:00:00:000] | A/V Delay found : 1413105msec [00:00:00:000] +-------- AZID ------- [00:00:00:000] | Input Channels Mode: 3/2, Bitrate: 448kbps [00:00:00:000] | Output Stereo mode: Dolby surround compatible [00:00:00:000] | Total Gain: 0.000dB, Compression: None [00:00:00:000] | LFE levels: To LR -INF, To LFE 0.0dB [00:00:00:000] | Center mix level: BSI [00:00:00:000] | Surround mix level: BSI [00:00:00:000] | Dialog normalization: No [00:00:00:000] | Rear channels filtering: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- LAME ------- [00:00:00:000] | Bitrate method : CBR [00:00:00:000] | MP3 bitrate : 128 [00:00:00:000] | Channels Mode : Joint Stereo [00:00:00:000] | Error Protection: No [00:00:00:000] +--------------------- [00:26:48:928] Conversion Completed ! [00:26:48:928] Actual Avg. Bitrate : 1536kbps [00:03:05:000] <-- Transcoding Duration Logging ends : 03/23/03 , 23:49:20. I then created the file C:\temp\BeSweet\vobs.lst with the following line in it: C:\temp\BeSweet\01.VOB (as suggested in http://dspguru.notrace.dk/list2.html) Tried to convert again: C:\temp\BeSweet>besweet -core ( -input vobs.lst -output 01.mp3 -lo) But then I get an error from Windows saying: BeSweet.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created. and BeSweet has exited :-( The log file is not very helpful: BeSweet v1.5b16 by DSPguru. -------------------------- Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu). Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org) Using lame_enc.dll v1.22 (6/7/2001), Engine 3.89 <http://www.mp3dev.org/>. Logging start : 03/23/03 , 23:51:34. besweet -core ( -input vobs.lst -output 01.mp3 -logfile test2.log ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\temp\BeSweet\01.VOB [00:00:00:000] | Output: 01.mp3 [00:00:00:000] | Floating-Point Process: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- LAME ------- [00:00:00:000] | Bitrate method : CBR [00:00:00:000] | MP3 bitrate : 128 [00:00:00:000] | Channels Mode : Joint Stereo [00:00:00:000] | Error Protection: No [00:00:00:000] +--------------------- That's all. Am I doing something wrong?! When I look at the two log files it seems that the Azid part of the successful log is missing from the log of the erroneous run?! The error happened on an AMD Athlon system running Windows 2000. Best regards, Jorgen |
24th March 2003, 00:20 | #5 | Link |
You need to download BeSweet 1.4 and extract it. Then extract the 1.5b16 and overwrite the files in it. You don't need to d/l the azid.dll, its already in besweet.
Intel Core i5-4250U, 8 GB Ram, Intel HD 5000 |
25th March 2003, 00:03 | #6 | Link |
Downloaded BeSweet 1.4. Removed C:\temp\BeSweet and recreated it. Unpacked BeSweet 1.4 Unpacked 1.5b16 (overwriting existing 1.4 files) Unpacked VOBInput.zip Tried again with a list file - same result as mentioned above ?!? BR Jorgen |
4th May 2003, 10:50 | #7 | Link |
BeSweet 1.5 beta bug
Since v1.5b4 (I don't remember exactly, it could be beta 5, 6 or 7...) and also with latest b17, BeSweet always crashes on my system when beginning the second pass (after searching maximun gain on first pass). With 1.4 it goes fine allways, never crashed. I allways use this command:
"C:\Archivos de programa\Ripping\BeSweet\BeSweet.exe" -core( -input "C:\Archivos de programa\Ripping\BeSweet\pelicula.lst" -output "d:\pelicula.wav" -substream 0x81 -2ch ) -azid( -z1 -b1 -equit -c normal -L -3db --maximize ) -profile( ~~~~~ Default Profile ~~~~~ ) Pelicula.lst is a list of original VOBs from DVD. I have VOBInput.dll v 1.3. Error happens with all DVDs, not only one. DVD is decrypted with smartripper 2.41 in backup mode. There's a pause after first pass and then BeSweet.exe crashes before beginning the second pass. My system is a laptop PIV 1700 (DELL Inspiron 8200), Windows XP SP1. I'm using DanniDin's GUI 0.6 b73. LOGFILE: --------- BeSweet v1.5b17 by DSPguru. -------------------------- Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu). Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org) Logging start : 05/03/03 , 11:57:29. C:\Archivos de programa\Ripping\BeSweet\BeSweet.exe -core( -input C:\Archivos de programa\Ripping\BeSweet\pelicula.lst -output d:\pelicula.wav -substream 0x81 -2ch -logfilea C:\Archivos de programa\Ripping\BeSweet\BeSweet.log ) -azid( -z1 -b1 -equit -c normal -L -3db --maximize ) -profile( ~~~~~ Default Profile ~~~~~ ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\Archivos de programa\Ripping\BeSweet\pelicula.lst [00:00:00:000] | Output: d:\pelicula.wav [00:00:00:000] | Substream ID: 0x81 [00:00:00:000] | Floating-Point Process: No [00:00:00:032] | A/V Delay found : -80msec GPF error: ------------- AppName: besweet.exe AppVer: 0.0.0.0 ModName: kernel32.dll ModVer: 5.1.2600.1106 Offset: 00013887 FILE appcompat.txt: --------------------- <?xml version="1.0" encoding="UTF-16"?> <DATABASE> <EXE NAME="BeSweet.exe" FILTER="GRABMI_FILTER_PRIVACY"> <MATCHING_FILE NAME="ac3enc.dll" SIZE="13824" CHECKSUM="0xB24DCC89" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x2" LINK_DATE="02/08/2003 13:28:22" UPTO_LINK_DATE="02/08/2003 13:28:22" /> <MATCHING_FILE NAME="azid.dll" SIZE="43008" CHECKSUM="0xF05A22B6" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="02/19/2002 21:57:46" UPTO_LINK_DATE="02/19/2002 21:57:46" /> <MATCHING_FILE NAME="azid.exe" SIZE="126976" CHECKSUM="0xB5806EF8" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="02/19/2002 21:58:23" UPTO_LINK_DATE="02/19/2002 21:58:23" /> <MATCHING_FILE NAME="BeSweet.exe" SIZE="54784" CHECKSUM="0xFD21CF6D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="04/29/2003 17:14:50" UPTO_LINK_DATE="04/29/2003 17:14:50" /> <MATCHING_FILE NAME="BeSweetGUIv0.6b73.exe" SIZE="199680" CHECKSUM="0xE0481998" BIN_FILE_VERSION="0.4.0.0" BIN_PRODUCT_VERSION="0.4.0.0" PRODUCT_VERSION="0.04" COMPANY_NAME="Danni" PRODUCT_NAME="BeSweet GUI" FILE_VERSION="0.04" ORIGINAL_FILENAME="BeSweetGUI.exe" INTERNAL_NAME="BeSweetGUI" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x4" UPTO_BIN_FILE_VERSION="0.4.0.0" UPTO_BIN_PRODUCT_VERSION="0.4.0.0" LINK_DATE="03/24/2003 12:11:49" UPTO_LINK_DATE="03/24/2003 12:11:49" VER_LANGUAGE="Inglés (Estados Unidos) [0x409]" /> <MATCHING_FILE NAME="hip.dll" SIZE="31744" CHECKSUM="0xA6364DBC" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x10013" LINK_DATE="02/15/2003 14:25:34" UPTO_LINK_DATE="02/15/2003 14:25:34" /> <MATCHING_FILE NAME="lame.exe" SIZE="196608" CHECKSUM="0x629FEBF4" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="12/03/2002 18:47:32" UPTO_LINK_DATE="12/03/2002 18:47:32" /> <MATCHING_FILE NAME="lame_enc.dll" SIZE="172032" CHECKSUM="0x11C735E8" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="12/03/2002 18:47:16" UPTO_LINK_DATE="12/03/2002 18:47:16" /> <MATCHING_FILE NAME="mp2enc.dll" SIZE="37888" CHECKSUM="0x93CD2115" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="05/23/2002 21:40:07" UPTO_LINK_DATE="05/23/2002 21:40:07" /> <MATCHING_FILE NAME="Shibatch.dll" SIZE="31232" CHECKSUM="0xE9705F4E" BIN_FILE_VERSION="0.2.4.0" BIN_PRODUCT_VERSION="1.2.9.0" PRODUCT_VERSION="1, 2, 9, 0" FILE_DESCRIPTION="A sample-rate-convertor and equalizer library" COMPANY_NAME="http://DSPguru.doom9.org" PRODUCT_NAME="Shibatch.dll" FILE_VERSION="0, 2, 4, 0" ORIGINAL_FILENAME="shibatch.dll" INTERNAL_NAME="shibatch" LEGAL_COPYRIGHT="Copyright © 2002" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x18" UPTO_BIN_FILE_VERSION="0.2.4.0" UPTO_BIN_PRODUCT_VERSION="1.2.9.0" LINK_DATE="03/04/2003 18:36:26" UPTO_LINK_DATE="03/04/2003 18:36:26" VER_LANGUAGE="Inglés (Estados Unidos) [0x409]" /> <MATCHING_FILE NAME="tooLame.dll" SIZE="66048" CHECKSUM="0x2798E1BB" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="04/23/2003 23:54:28" UPTO_LINK_DATE="04/23/2003 23:54:28" /> <MATCHING_FILE NAME="VOBInput.dll" SIZE="189440" CHECKSUM="0xF1A8E28F" BIN_FILE_VERSION="1.3.0.0" BIN_PRODUCT_VERSION="1.3.0.0" PRODUCT_VERSION="1.3.0.0" FILE_DESCRIPTION="" COMPANY_NAME="" PRODUCT_NAME="" FILE_VERSION="1.3.0.0" ORIGINAL_FILENAME="" INTERNAL_NAME="" LEGAL_COPYRIGHT="" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.3.0.0" UPTO_BIN_PRODUCT_VERSION="1.3.0.0" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" VER_LANGUAGE="Danés [0x406]" /> </EXE> <EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY"> <MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x65BBCB8E" BIN_FILE_VERSION="5.1.2600.1106" BIN_PRODUCT_VERSION="5.1.2600.1106" PRODUCT_VERSION="5.1.2600.1106" FILE_DESCRIPTION="DLL de cliente API BASE de Windows NT" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Sistema operativo Microsoft® Windows®" FILE_VERSION="5.1.2600.1106 (xpsp1.020828-1920)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="Copyright (C) Microsoft Corporation. Reservados todos los derechos." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFAB9A" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.1106" UPTO_BIN_PRODUCT_VERSION="5.1.2600.1106" LINK_DATE="09/09/2002 20:50:09" UPTO_LINK_DATE="09/09/2002 20:50:09" VER_LANGUAGE="Español (alfabetización internacional) [0xc0a]" /> </EXE> <EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY"> <MATCHING_FILE NAME="kernel32.dll" SIZE="983552" CHECKSUM="0x65BBCB8E" BIN_FILE_VERSION="5.1.2600.1106" BIN_PRODUCT_VERSION="5.1.2600.1106" PRODUCT_VERSION="5.1.2600.1106" FILE_DESCRIPTION="DLL de cliente API BASE de Windows NT" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Sistema operativo Microsoft® Windows®" FILE_VERSION="5.1.2600.1106 (xpsp1.020828-1920)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="Copyright (C) Microsoft Corporation. Reservados todos los derechos." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xFAB9A" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.1106" UPTO_BIN_PRODUCT_VERSION="5.1.2600.1106" LINK_DATE="09/09/2002 20:50:09" UPTO_LINK_DATE="09/09/2002 20:50:09" VER_LANGUAGE="Español (alfabetización internacional) [0xc0a]" /> </EXE> </DATABASE> Hope this helps. I'll continue using 1.4 until you fix this bug. Bye. |
6th May 2003, 11:56 | #9 | Link | |
BeSweet Author
Re: Crash Bug
i'm currently waiting for VOBInput.dll v1.31
13th May 2003, 19:06 | #10 | Link |
Same bug in b18
BeSweet 1.5b18 has exactly the same bug. It crashes like b17, b16... etc. on the second pass. I think you'll fix it with new vobinput 1.3.1, but with 1.4 it never crashes with vobinput 1.3.
Bye. |
13th May 2003, 19:22 | #11 | Link |
BeSweet Author
@ikerrg
thank you for your reports! please post your logfile and attach your listfile. 10x! Dg. ps, i'll be uploading a new binary in an hour with minor modifications. please redownload before feedbacking.
FAQs : BeSweet, Audio :readfaq: Homepage : DSPguru's Webpage http://dspguru.notrace.dk/cs.gif Guides : Multilingual Guides of my tools http://dspguru.notrace.dk/1zhelp.gif Last edited by DSPguru; 13th May 2003 at 19:59. |
13th May 2003, 20:08 | #12 | Link |
OK, I'll wait an hour and then I'll retry the process with new BeSweet (now I'm using SouthPark PAL DVD).
I forget: I've seen that I must have Ogg installed for b18 to run. I don't use Ogg, so I think BeSweet should not try to load ogg.dll. Bye. |
13th May 2003, 20:30 | #13 | Link |
BeSweet Author
it's up for quite some time now..
edit : regarding ogg, if it doesn't work, you could just put the libvorbis.dll in your BeSweet folder..
FAQs : BeSweet, Audio :readfaq: Homepage : DSPguru's Webpage http://dspguru.notrace.dk/cs.gif Guides : Multilingual Guides of my tools http://dspguru.notrace.dk/1zhelp.gif Last edited by DSPguru; 13th May 2003 at 20:47. |
13th May 2003, 21:02 | #14 | Link |
Same error.
AppName: besweet.exe AppVer: 0.0.0.0 ModName: kernel32.dll ModVer: 5.1.2600.1106 Offset: 00013887 BeSweet v1.5b18 by DSPguru. -------------------------- Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org) Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu). Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using libVorbis.dll v1.0 ( Apr 16 2003 ) by John33 (www.inf.ufpr.br/~rja00). Logging start : 05/13/03 , 21:52:53. C:\Archivos de programa\Ripping\BeSweet\BeSweet.exe -core( -input C:\Archivos de programa\Ripping\BeSweet\pelicula.lst -output d:\pelicula.wav -substream 0x81 -2ch -logfilea C:\Archivos de programa\Ripping\BeSweet\BeSweet.log ) -azid( -z1 -b1 -equit -c normal -L -3db --maximize ) -profile( ~~~~~ Default Profile ~~~~~ ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\Archivos de programa\Ripping\BeSweet\pelicula.lst [00:00:00:000] | Output: d:\pelicula.wav [00:00:00:000] | Substream ID: 0x81 [00:00:00:000] | Floating-Point Process: No [00:00:00:032] | A/V Delay found : -80msec I can't attach list file in this forum (Forum Rules). I copy and paste below exactly. It's made with notepad in XP. It has a return at the end of each line: g:\DVDs\SouthPark\VIDEO_TS\VTS_01_1.VOB g:\DVDs\SouthPark\VIDEO_TS\VTS_01_2.VOB g:\DVDs\SouthPark\VIDEO_TS\VTS_01_3.VOB g:\DVDs\SouthPark\VIDEO_TS\VTS_01_4.VOB |
13th May 2003, 21:24 | #15 | Link |
BeSweet Author
to me it seems like vobinput.dll crashes...
by the way, i believe you should pay your attention to q12 in the BeSweet faq
13th May 2003, 21:56 | #16 | Link |
I prefer Azid's 2-pass normalization because I think it gives more quality. I have never used OTA's PreGain, PostGain or HybridGain (thank you DanniDin for this GREAT and easy GUI).
Tomorrow more and better. Bye. |
13th May 2003, 21:59 | #17 | Link | |
BeSweet Author
14th May 2003, 11:55 | #18 | Link | |
n00b ever
vobinput + ota gain + timestamp
b17/b18 seems not to perform ota gain. any! tried pre/post/hyb. no sign anywhere, logfile complete, but the sound is unattenuated (15.6 db deficiency is clearly audible) no problem in b16. i have problems with timestamps 2. sometime the interval is simply ignored. dunno what's it depend on. can anyone explain me these ? maybe w89se is going down again? thx y |
14th May 2003, 13:57 | #19 | Link |
BeSweet Author
16th May 2003, 09:07 | #20 | Link |
n00b ever
... partly withdrawn
my former tests were a bit ... chaotic :-) so i went back to the roots.
- all stuff deleted, reg cleared (just for safe) - reinstall: - bs14 - bs15b18 - bsg06b75 -> vobinput works, postgain works, split not accepted (???) log : BeSweet v1.5b18 by DSPguru. -------------------------- Using VOBInput.dll v1.3 by DVD2SVCD (http://www.dvd2svcd.org) Using azid.dll v1.8 (b825) by Midas (midas@egon.gyaloglo.hu). Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net> Using lame_enc.dll v1.28 (4/6/2002), Engine 3.92 <http://www.mp3dev.org/>. Logging start : 05/15/03 , 19:39:28. C:\AUDIO\BESWEET\BeSweet.exe -core( -input e:\video\CF\vts_02.lst -output e:\video\CF\CF2_a.mp3 -substream 0x81 -logfile C:\AUDIO\BESWEET\BeSweet.log ) -azid( -z1 -b1 ) -ota( -G 0.99 ) -split( -start 0 -end 300 ) -lame( -q 0 --abr 128 -b 80 -B 320 ) -profile( ~~~~~ Default Profile ~~~~~ ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : e:\video\CF\vts_02.lst [00:00:00:000] | Output: e:\video\CF\CF2_a.mp3 [00:00:00:000] | Substream ID: 0x81 [00:00:00:000] | Floating-Point Process: Yes [00:00:00:000] | PostGain normalize to : 0.99 [00:00:00:032] | A/V Delay found : 0msec [00:00:00:000] +-------- AZID ------- [00:00:00:000] | Input Channels Mode: 3/2, Bitrate: 448kbps [00:00:00:000] | Output Stereo mode: Dolby surround compatible [00:00:00:000] | Total Gain: 0.000dB, Compression: None [00:00:00:000] | LFE levels: To LR -INF, To LFE 0.0dB [00:00:00:000] | Center mix level: BSI [00:00:00:000] | Surround mix level: BSI [00:00:00:000] | Dialog normalization: No [00:00:00:000] | Rear channels filtering: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- LAME ------- [00:00:00:000] | Bitrate method : ABR [00:00:00:000] | Avarege Bitrate : 128 [00:00:00:000] | MP3 Min bitrate : 80 [00:00:00:000] | MP3 Max bitrate : 320 [00:00:00:000] | Channels Mode : Joint Stereo [00:00:00:000] | Error Protection: No [00:00:00:000] +--------------------- [01:37:26:656] Gain of 18.0dB had been asserted to file. [01:37:26:656] Conversion Completed ! [01:37:26:656] Actual Avg. Bitrate : 117kbps [00:56:23:000] <-- Transcoding Duration Logging ends : 05/15/03 , 20:35:51. what am i still doing wrong? anyway, sound's beautiful! as usual :-) thx y ps just occured. formerly i kept besweet & beslice/besplit09b4 in the same folder. i checked the packs. different hip.dll versions are included (sweet:hip/03.02.15, split:hip/02.10.26). is it intentional? maybe, it was the source of the former faults. (???) |
