#1 | Link |
Matrix mixer (allows to upmix stereo movies to multichannel at playback time)
I've started a new project that allows simple stereo to multichannel upmix for any stereo source. I need your opinions about this thing...
http://matrix-mixer.sourceforge.net (homepage) http://prdownloads.sourceforge.net/m...a.exe?download (direct download) |
#2 | Link |
DVD Rebuilder!
Wow... nice filter,
It's just like the http://www.trombettworks.com/directshow.php Can't wait to test it ![]() Edit: I think there is a problem while playing vorbis files, I use the "ancient" Tobias's OggDS 0.9.9.5, and the MPC 6.4.3.5. is stopped. Last edited by ookzDVD; 18th March 2003 at 10:41. |
#4 | Link |
mmm, what's the difference between the matrix-mixer and the Moonlight Odio Dekoda?
#6 | Link |
it's a very nice filter
![]() made a couple of tests of the 2ch->5.1ch upmix using avi-s with mp3 VBR soundtrack. the ones encoded at 128kbps (DSPguru preset of BeSweetGUI)sound very good to me. havent checked higher bitrates yet, but should be even better. I also checked another one at 96kbps (downmixed from ac3 most probably by GraphEdit and iviaudio). it is still OK, hoever there is slight noice and crackling from the C, SR, and SL speakers - just slight, and only from time to time. Pretty nice for a 96kbps mp3 ![]() I remember DSPguru recommending to encode mp3s at 160+ in order to preserve the surround information in the audio. Can you recommend BeSweet settings for better upmix 2ch->5.1 during playback? Last edited by ohliuv; 19th March 2003 at 10:15. |
#8 | Link |
Who is encoding MP3 without --alt-preset standard nowadays???
O.K., did anyone test yet a file that was encoded with -s surround2 in BeSweet? I will do it myself these days but unfortunately I don't have very much time at the moment. The question is if the surround image get's reproduced correctly for example in an action movie where a bullet flies from the left to the right (or vice versa). Regards, tiki4 |
#9 | Link |
I tried the matrixmixer with a movie containing 128kbit mp3(fast&furious) & it works perfectly! I used it with an nforce2 motherboard/DD51 encoding and the sound was really good! Much better than the usual mp3-PCM-spdif-DPL_decode via amp mode!
Valex, thank you very much ! |
#11 | Link |
Matroska Team
/me is looking forward to be able to play DPL2 encoded stereo tracks on his PC, encoded with MPC at 180 - 190 kbps, with nice and clean surround sound coming out of his surround system
.... reminds me i finally have to buy a new soundcard now ...
#13 | Link |
Excellent filter - love the sound difference.
Is it possible to have the option for stereo for FL & FR matched with the Same Stereo source for RR & RL. This will effectively give me Music in 2 locations using my receiver & speakers and also create a better amplified environment when in the same room. Also, how hard is it to implement Stereo to AC3 realtime encoding with the functionality similar to this Matrix mixer. I would love the capability of the NForce2 Sound system without having to buy the actual motherboard. Ive noticed there is a realtime encoder on sourceforge, but it is at an early stage. Anyway keep up the good work! Azz
Choose life.... |
#15 | Link |
This is it arty http://sourceforge.net/projects/ac3encode
Cheers.
Choose life.... |
#18 | Link | |
@DIggedy:
mikeson |
#20 | Link | |
