Old 10th March 2003, 00:28   #21  |  Link
WarpEnterprises
C64
WarpEnterprises's Avatar
Look here:
CHR.DLL
(has a CHR and a TIME function)
2.0 + 2.5
For the possible time formatting codes look into chr.cpp.
WarpEnterprises is offline   Reply With Quote
Old 10th March 2003, 06:50   #22  |  Link
DDogg
Retired, but still around
DDogg's Avatar
WarpEnterprises, thanks so much! I look forward to giving this a try tomorrow and will report back the reults and some more examples.
DDogg is offline   Reply With Quote
Old 10th March 2003, 08:28   #23  |  Link
WarpEnterprises
C64
Forgot to emphasize: the time is of course the LOAD TIME of the script (it cannot be used to imprint e.g. the current time on a video from start to the end, this would have to be done by a completely different function)
Old 11th March 2003, 02:53   #24  |  Link
DDogg
DDogg's Avatar
WarpEnterprises, those time functions in chr really work well and are very comprehensive and thought out. Thanks!
http://forum.doom9.org/showthread.ph...597#post276597
Note: I do understand it is the start time. I used it in the script as a place holder until I can figure out how to get the end time.
