Old 6th March 2003, 02:58   #1  |  Link
harry349
ifoupdate 0.69 - error 424
I recently upgraded to IFOUpdate 0.69.
When I run it I get the window:
IFOUpdate
Run-time error '424':
Object required
[OK]
So I cannot get into the program at all. I did not have any problem with the version I previously had installed, which I think was version 0.67, but don't remember for sure. Has anyone else seen similar behavior? Any idea what might be causing it / how to fix it?
Thanks,
harry349
harry349 is offline   Reply With Quote
Old 9th March 2003, 05:25   #2  |  Link
harry349
Unforuntately I don't have an answer to my own question, was simply posting this hoping that someone with more of a clue than myself might see it again and respond.
TIA,
harry349
Old 9th March 2003, 10:37   #3  |  Link
Abnormal
Posts: n/a
You should Delete the ifoupdate.ini File as it is pointing to a IFO location that does not exist.
Old 9th March 2003, 13:02   #4  |  Link
harry349
*smacks head*
Yeah, should have thought of that, and sure enough it worked, thanks.
Old 6th May 2008, 11:47   #5  |  Link
Krazy Kat
Piece of **** editor.
I deleted it but I'm still crashing out. Al this piece of **** does is keep creating a files with ...
"[Flags]
Mode=1"
... and nothing else.
Krazy Kat is offline   Reply With Quote
Old 6th May 2008, 14:29   #6  |  Link
blutach
Country Member
blutach's Avatar
@Krazy Kat
You know you have revived a thread that is 5 years old, right?
Irrespective, I will ask you to mind your language please. See rule 4.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 7th May 2008, 07:20   #7  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
You might try to use PgcEdit's Replace VTST Titles instead of the old Ifoupdate method. It's easier, and (I hope) there will be no bug!
r0lZ
