Old 28th February 2003, 19:12   #1  |  Link
hayami
Packed Bitsream of B-frame...
Is it still not working?
I've tried to encode a clip with bframe and PB on, it seems there is no problem. (kinda sick of that black screen whenever playback of file with bf)
What's the problem with it? e.g. not compatible with Divx5 or the stream it produce is not MPEG-4 compliant?
Just being curious, since the last update on it was like half a year ago
hayami is offline   Reply With Quote
Old 28th February 2003, 23:05   #2  |  Link
Morbo
I Will Destroy You!!
Morbo's Avatar
B-frames are still buggy(depends alot here on source),I noticed in IAGO's guide it says NOT to select it(if memory serves).
Cheers!!!
Jesus Saves,but Buddah makes incremental backups!
Morbo is offline   Reply With Quote
Old 1st March 2003, 11:27   #3  |  Link
sysKin
sysKin's Avatar
Could you explain more? Currently, the following bframe related bugs are known:
- max and min i-frame interval don't work
- when lumimasiking is used, they sometimes have strange quantizers
- well yes, packed bitstream doesn't work - anyone needs it?
...and that's it.
If you are refering to something which isn't here _please_ tell me. I'm far from knowing everything
Radek
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
Old 4th March 2003, 14:21   #4  |  Link
symonjfox
IUUULEEEENZ
symonjfox's Avatar
It's important to me to know if B-Frames created using XviD version from 11/2002 to now are or not MPEG 4 compilant.
I explain: I started using XviD from November and I always used B-Frames. They worked fine for me, but I'd like to know if one day, while converting these AVI to MP4, I will get any kind of compatibility issues.
And again, is it there an MP4 Transmuxer that support B Frames? I know that Mp4ip cannot at this moment.
PC1:AMD Athlon II x4, 4GB DDR2, Ati Radeon 4830, 4 hard disks
symonjfox is offline   Reply With Quote
Old 4th March 2003, 17:25   #5  |  Link
DaveEL
Radek
Yes everyone as it should mean we can decode b-frames in avis without any delays (as long as the encoder knows how to drop the frames used as padding to deal with vfw expecting 1 frame in 1 frame out).
DaveEL
DaveEL is offline   Reply With Quote
Old 4th March 2003, 17:33   #6  |  Link
Rober2D2
I have used packed bitstream in short tests. I found no problems when using XVID decoder, but ffdshow and divx decoder can't handle them correctly. I seems they playback frames in wrong order.
If virtualdub is able to handle packed bitstream correctly it should be easier to edit films with B-Frames.
Rober2D2 is offline   Reply With Quote
Old 8th April 2003, 11:22   #7  |  Link
kilg0r3
! - User - !
kilg0r3's Avatar
Is this a de- or an encoding issue?
Keep your tone warm and your sigs decent!
kilg0r3 is offline   Reply With Quote
Old 8th April 2003, 11:43   #8  |  Link
Isibaar
...and that's it.
Radek [/B]
Could someone please explain why packed bitstreams don't work? I've fixed this half a year ago and packed bitstream worked back then. But it's of course possible that packed bitstream is broken again...
Anyway, please keep in mind that packed bitstream did not work with ffdshow when I checked it (half a year ago), but I think this was not my fault because DivX 5.0.2 played XVID packed bitstream without a problem.
If DivX cannot play XVID packed bitstream avis correctly, this can have two reasons:
a) DivX uses a strange versioning system. XVID tried to imitate this in order to make playback possible with DivX, but I'm not sure if we have updated this to match DivX versions > 5.0.2
b) DivX has often problems correctly playing XVID streams that make use of 4 vector mode. This is also not our fault, but a bug/incompatibility of the DivX decoder. To check if this is the problem, make a test encode with XVID and switch to motion search precision 4 (high). This disables 4 MV search, so if DivX then still incorrectly plays this XVID stream, it could indeed be our problem ;-))
Isibaar is offline   Reply With Quote
Old 8th April 2003, 12:41   #9  |  Link
kilg0r3
! - User - !
kilg0r3's Avatar
i can only say that it doesnot work with ffdshow. -> not xvid's fault
